PCB Matrix IPC-7351 LP软件
4234|3
 楼主| wolftc 发表于 2010-11-27 15:44 | 显示全部楼层 |阅读模式
PCB Matrix IPC-7351 LP软件  能生成Protel 99 的库吗?
CAD output:选Protel 99SE;
Options--PADS ASCII Version:3.5
create 后, 生成  **.asc 文件,不是DDB文件。 怎么打开?
pa2792 发表于 2010-11-27 15:47 | 显示全部楼层
可以。
 楼主| wolftc 发表于 2010-11-27 15:57 | 显示全部楼层
2# pa2792
 楼主| wolftc 发表于 2010-11-27 21:49 | 显示全部楼层
Protel Design System: PADS PowerPCB To Protel 99 SE Translator Report
PCB ASCII File : Wizard
Date           : 27-Nov-2010
Time           : 21:46:18
Load Errors : 92
Error loading label visibility attribute from line: 104
Expected number in line: 105 at position 0 and found this: **CRLF**
Expected integer in line: 105 at position 0
Error loading label mirrored attribute from line: 105
Error loading label text justification attributes from line: 105
Error loading label right-reading attribute from line: 105
Error loading label visibility attribute from line: 106
Expected number in line: 106 at position 5 and found this: Type
Expected number in line: 107 at position 0 and found this: **CRLF**
Expected integer in line: 107 at position 0
Error loading label mirrored attribute from line: 107
Error loading label text justification attributes from line: 107
Error loading label right-reading attribute from line: 107
Expected number in line: 108 at position 0 and found this: Ref.Des.
Expected number in line: 109 at position 0 and found this: **CRLF**
Invalid pin data discarded.
'PAD' expected in line: 279
Expected integer in line: 279 at position 0
导入有错误。。。
