请教圈圈和各位网友:HID报告描述符中的集合问题
3125|0
 楼主| SwPwr 发表于 2010-12-10 10:08 | 显示全部楼层 |阅读模式
买了本<圈圈教你玩USB>,对于报告描述符中集合的应用总是有些问题不太了解,请教下圈圈及大家
问题:
1:集合表示的是什么? 看协议上讲表示一些主条目的集合;
2:一般是在usage()后面就要开一个集合吗?还是在什么情况下需要开集合?
3:什么usage属于application或physical集合,这个是如何知道的?虽然协议中有如下定义,但还是弄不懂
Collection  1010 00 nn  0x00    Physical  (group of axes)
                                  0x01    Application (mouse, keyboard)
                                  0x02    Logical (interrelated data)
                                  0x03   Report
                                  0x04   Named Array
                                  0x05   Usage Switch
                                  0x06   Usage Modifier
                                  0x07-0x7F Reserved
                                  0x80-0xFF Vendor-defined
4:如下面描述符所示,为什么还要开两个集合呢?
Usage Page (Generic Desktop),          ;Use the Generic Desktop Usage Page
Usage (Mouse),
  Collection (Application),     ;Start Mouse collection
Usage (Pointer),
Collection (Physical),        ;Start Pointer collection
    Usage Page (Buttons)
    Usage Minimum (1),
    Usage Maximum (3),
    Logical Minimum (0),
    Logical Maximum (1),            ;Fields return values from 0 to 1
    Report Count (3),
    Report Size (1),                ;Create three 1 bit fields (button 1, 2, & 3)
    Input (Data, Variable, Absolute),  ;Add fields to the input report.
    Report Count (1),
   Report Size (5),        ;Create 5 bit constant field
  Input (Constant),         ;Add field to the input report
    Usage (X),
  Usage (Y),
    Logical Minimum (-127),
    Logical Maximum (127),            ;Fields return values from -127 to 127
    Report Size (8),
    Report Count (2),                ;Create two 8 bit fields (X & Y position)
    Input (Data, Variable, Relative),  ;Add fields to the input report
  End Collection,         ;Close Pointer collection
End Collection           ;Close Mouse collection
