高手帮我看看这个是什么问题?编译环境是IAR FOR ARM
2628|3
 楼主| tqtxk 发表于 2010-12-17 18:51 | 显示全部楼层 |阅读模式
Building configuration: Point Clock - Debug
Updating build tree...
main.c
Linking
Error[e16]: Segment CODE (size: 0x207c align: 0x2) is too long for segment definition. At least 0x1d4 more bytes needed. The problem occurred while processing the
segment placement command "-Z(CODE)CODE=ROMSTART-ROMEND", where at the moment of placement the available memory ranges were
"CODE:40000158-40001fff"
   Reserved ranges relevant to this placement:
   40000000-4000003b    INTVEC
   4000003c-40000157    ICODE
   40000158-40001fff    CODE
Total number of errors: 1
Total number of warnings: 0
hgjinwei 发表于 2010-12-19 21:51 | 显示全部楼层
代码空间不够
 楼主| tqtxk 发表于 2010-12-21 09:18 | 显示全部楼层
怎么解决 啊 ?
XZL 发表于 2010-12-21 15:01 | 显示全部楼层
精简代码吧!要不就换芯片
个人签名:坚持就是胜利
