芯唐串口ISP固定波特率的弊端
3293|5
 楼主| hotpower 发表于 2010-12-21 07:45 | 显示全部楼层 |阅读模式
由于ISP V1.10采用57600BPS,所以可以链接并下载程序
但ISP V1.20/V1.32后都是采用固定115200BPS,故针对有些串口特别是USB转串口通讯误码无法联机。
昨晚菜农在群里讲了无波特率自适应和BIN通讯格式的弊端,以至于差点遭到群殴,很是晕沉!!!
现将V1.32拦截数据贴附如下,供分析,俺要上班了
0 0.06486516 NuMicro ISP Pro IRP_MJ_CREATE MosChipSerial11 SUCCESS Options: Open
1 0.00001152 NuMicro ISP Pro IOCTL_SERIAL_GET_BAUD_RATE MosChipSerial11 SUCCESS
2 0.00000370 NuMicro ISP Pro IOCTL_SERIAL_GET_LINE_CONTROL MosChipSerial11 SUCCESS
3 0.00000321 NuMicro ISP Pro IOCTL_SERIAL_GET_CHARS MosChipSerial11 SUCCESS
4 0.00000307 NuMicro ISP Pro IOCTL_SERIAL_GET_HANDFLOW MosChipSerial11 SUCCESS
5 0.00000335 NuMicro ISP Pro IOCTL_SERIAL_GET_BAUD_RATE MosChipSerial11 SUCCESS
6 0.00000293 NuMicro ISP Pro IOCTL_SERIAL_GET_LINE_CONTROL MosChipSerial11 SUCCESS
7 0.00000279 NuMicro ISP Pro IOCTL_SERIAL_GET_CHARS MosChipSerial11 SUCCESS
8 0.00000300 NuMicro ISP Pro IOCTL_SERIAL_GET_HANDFLOW MosChipSerial11 SUCCESS
9 0.06477946 NuMicro ISP Pro IOCTL_SERIAL_SET_BAUD_RATE MosChipSerial11 SUCCESS Rate: 115200
10 0.00284010 NuMicro ISP Pro IOCTL_SERIAL_SET_RTS MosChipSerial11 SUCCESS
11 0.00296958 NuMicro ISP Pro IOCTL_SERIAL_SET_DTR MosChipSerial11 SUCCESS
12 0.00290749 NuMicro ISP Pro IOCTL_SERIAL_SET_LINE_CONTROL MosChipSerial11 SUCCESS StopBits: 1 Parity: NONE WordLength: 8
13 0.00000838 NuMicro ISP Pro IOCTL_SERIAL_SET_CHAR MosChipSerial11 SUCCESS EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
14 0.00306296 NuMicro ISP Pro IOCTL_SERIAL_SET_HANDFLOW MosChipSerial11 SUCCESS Shake:1 Replace:40 XonLimit:2048 XoffLimit:512
15 0.00001271 NuMicro ISP Pro IOCTL_SERIAL_SET_WAIT_MASK MosChipSerial11 SUCCESS Mask: RXCHAR TXEMPTY
16 0.00000454 NuMicro ISP Pro IOCTL_SERIAL_SET_QUEUE_SIZE MosChipSerial11 SUCCESS InSize: 1024 OutSize: 128
17 0.00000510 NuMicro ISP Pro IOCTL_SERIAL_SET_TIMEOUTS MosChipSerial11 SUCCESS RI:200 RM:0 RC:0 WM:0 WC:0
18 0.00001034 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: TXABORT RXABORT TXCLEAR RXCLEAR
19 0.00001103 NuMicro ISP Pro IOCTL_SERIAL_SET_TIMEOUTS MosChipSerial11 SUCCESS RI:20 RM:0 RC:0 WM:0 WC:0
20 0.00271012 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
21 0.00674890 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: AE 0A 0D 0A 0D 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
22 0.00033636 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
23 0.00006314 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
24 0.00249291 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
25 0.00291364 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2B 0A 0D 7C 20 20 20 20 20 20 20 20 20 20 20 20 20 20
26 0.00593337 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
27 0.00432918 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
28 0.00003178 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
29 0.00257505 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 0.00263183 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 20 5B 31 5D 20 7C 0A 0D 7C 20 49 72 44 41 20 66 75 6E 74 69
31 0.00595509 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 5B 32 5D 20 7C 0A 0D 7C 20 52 53 34 38 35 20 52 65 63 65 69
32 0.00333073 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
33 0.00005895 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
34 0.00151870 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
35 0.00379259 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 2D 20 5B 34 5D
36 0.00495901 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
37 0.00533727 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
38 0.00003415 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
39 0.00153700 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 0.00388785 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
41 0.00507083 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
42 0.00420843 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
43 0.00002822 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
44 0.00256513 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
45 0.00280350 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D
46 0.00475312 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 7C 20 55 41 52 54 20 66 75 6E 63
47 0.00532945 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
48 0.00002759 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
49 0.00254537 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 0.00276062 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 2D 20 5B 32 5D 20 7C 0A 0D 7C 20 52 53 34 38 35
51 0.00592296 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 2D 20 5B 33 5D 20 7C 0A 0D 7C 20 52 53 34 38 35 20
52 0.00434685 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
53 0.00002933 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
54 0.00256681 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 0.00284394 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 7C 20 51 75
56 0.00594768 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 2D 20 5B 45 53 43 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D
57 0.00335378 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
58 0.00005070 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
59 0.00349688 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0.00172298 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
61 0.00571099 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 55 41 52 54 20 53 61 6D
62 0.00434483 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
63 0.00003373 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
64 0.00185973 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
65 0.00340008 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2B 0A 0D 7C 20 55 41 52 54 20 66 75 6E 63 74 69 6F 6E 20 74
66 0.00577406 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 7C 0A 0D 7C 20 49 72 44 41 20 66 75 6E 74 69 6F 6E 20 74 65 73
67 0.00477582 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 7C 20 52 53 34 38 35 20 52 65 63 65 69 76 65 20 66 75 6E
68 0.00001390 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
69 0.00227047 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 0.00281621 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20 20 20 20
71 0.00574417 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
72 0.00126029 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
73 0.00002591 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
74 0.00150110 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
75 0.00151625 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 09 20 20 20 20 2D 20 5B 45 53 43 5D 20 7C 0A
76 0.00484426 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D
77 0.00519116 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
78 0.00003317 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
79 0.00178270 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 0.00315005 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 55 41 52 54 20 53 61 6D 70 6C 65
81 0.00491298 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
82 0.00438226 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
83 0.00002836 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
84 0.00155076 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
85 0.00381759 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 20 5B 31 5D 20 7C 0A 0D 7C 20 49 72 44 41 20 66 75 6E 74 69
86 0.00474138 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 5B 32 5D 20 7C 0A 0D 7C 20 52 53 34 38 35 20 52 65 63 65 69
87 0.00535305 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
88 0.00003150 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
89 0.00253845 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0.00284149 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 2D 20 5B 34 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D
91 0.00571777 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 7C 20 51 75 69 74 20 20 20 20
92 0.00338793 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
93 0.00003255 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
94 0.00254236 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
95 0.00290658 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
96 0.00597925 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
97 0.00431354 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
98 0.00003003 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
99 0.00254034 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 0.00283639 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
101 0.00476338 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 55 41 52 54 20 66 75 6E 63 74 69 6F 6E 20 74 65 73 74 20 20 20
102 0.00531283 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
103 0.00003136 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
104 0.00248167 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
105 0.00284268 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 7C 20 52 53 34 38 35 20 52 65 63 65 69 76 65 20 66 75 6E
106 0.00583070 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0D 7C 20 52 53 34 38 35 20 54 72 61 6E 73 6D 69 74 20 66 75 6E
107 0.00325495 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
108 0.00002437 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
109 0.00150599 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 0.00383750 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 7C 20 51 75
111 0.00488351 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 2D 20 5B 45 53 43 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D
112 0.00533573 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
113 0.00002738 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
114 0.00154307 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
115 0.00383401 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
116 0.00583405 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 55 41 52 54 20 53 61 6D 70 6C 65 20 50 72 6F 67 72 61 6D
117 0.00329511 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
118 0.00002326 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
119 0.00254753 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 0.00282899 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2B 0A 0D 7C 20 55 41 52 54 20 66 75 6E 63 74 69 6F 6E 20 74 65
121 0.00589523 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 7C 20 49 72 44 41 20 66 75 6E 74 69 6F 6E 20 74 65 73 74
122 0.00407845 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
123 0.00002270 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
124 0.00253328 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
125 0.00286356 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 33 5D 20 7C 0A 0D 7C 20 52 53 34 38 35 20 54 72 61 6E 73 6D 69
126 0.00578838 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
127 0.00425019 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
128 0.00002291 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
129 0.00253119 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 0.00286664 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 5B 45 53 43 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
131 0.00474921 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2B 0A 0D 50 6C 65 61 73 65 20 53 65 6C 65 63
132 0.00436711 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
133 0.00002710 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
134 0.00153909 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
135 0.00384574 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 55 41 52 54 20 53 61 6D 70 6C 65 20
136 0.00494700 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
137 0.00535655 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
138 0.00002284 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
139 0.00155606 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140 0.00382102 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 72 44 41 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20
141 0.00485711 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 34 38 35 20 52 65 63 65 69 76 65 20 66 75 6E 74 69 6F 6E 20 74
142 0.00426591 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
143 0.00002403 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
144 0.00252337 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
145 0.00284708 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 2D 20 5B 34 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D
146 0.00593958 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 7C 20 51 75 69 74 20 20 20 20 20
147 0.00439909 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
148 0.00002368 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
149 0.00247273 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150 0.00293215 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2B 0A 0D 50 6C 65 61 73 65 20
151 0.00580898 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
152 0.00418224 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
153 0.00002647 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
154 0.00253712 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
155 0.00285602 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
156 0.00592750 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 74 65 73 74 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
157 0.00336621 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
158 0.00002389 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
159 0.00131581 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160 0.00382604 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 7C 20 52 53 34 38 35 20 52 65 63 65 69 76 65 20 66 75 6E
161 0.00485285 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0D 7C 20 52 53 34 38 35 20 54 72 61 6E 73 6D 69 74 20 66 75 6E
162 0.00527763 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
163 0.00002668 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
164 0.00150257 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
165 0.00384274 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2B 0A 0D 7C 20 51 75 69 74 20 20 20 20 20 20 20 20 20 20
166 0.00496914 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
167 0.00434112 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
168 0.00002535 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
169 0.00253943 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170 0.00284917 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
171 0.00482778 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 55 41 52 54 20 53 61 6D 70 6C 65 20 50 72 6F 67 72 61
172 0.00524662 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
173 0.00002186 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
174 0.00151919 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
175 0.00384958 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 75 6E 63 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20 20 20 20 20
176 0.00495070 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20 20 20 20 20 20 20
177 0.00536367 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
178 0.00002598 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
179 0.00285923 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180 0.00177292 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 38 35 20 54 72 61 6E 73 6D 69 74 20 66 75 6E 74 69 6F 6E 20 74
181 0.00489559 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
182 0.00430124 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
183 0.00003073 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
184 0.00171614 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
185 0.00283241 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 45 53 43 5D 20 7C 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
186 0.00594447 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2B 0A 0D 50 6C 65 61 73 65 20 53 65 6C 65 63 74 20
187 0.00434015 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
188 0.00002919 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
189 0.00190066 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190 0.00275580 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 54 20 53 61 6D 70 6C 65 20 50 72 6F 67 72 61 6D 20 20 20 20 20
191 0.00519396 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
192 0.00417351 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
193 0.00005245 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
194 0.00127614 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
195 0.00276984 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 44 41 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20 20
196 0.00481898 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 38 35 20 52 65 63 65 69 76 65 20 66 75 6E 74 69 6F 6E 20 74 65
197 0.00534055 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
198 0.00003464 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
199 0.00281886 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
200 0.00178661 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
201 0.00592925 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 51 75 69 74 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
202 0.00439644 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
203 0.00003248 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
204 0.00263015 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
205 0.00001055 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 50 6C 65 61 73 65 20 53 65 6C 65 63 74 20 6B 65 79 20 28
206 0.00275007 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
207 0.00439497 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
208 0.00003541 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
209 0.00094244 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
210 0.00290246 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
211 0.00492507 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 74 65 73 74 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
212 0.00538839 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
213 0.00003352 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
214 0.00250667 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
215 0.00081756 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 65 69 76 65 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20
216 0.00572014 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 73 6D 69 74 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20
217 0.00321095 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
218 0.00002912 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
219 0.00178109 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
220 0.00158288 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2B 0A 0D 7C 20 51 75 69 74 20 20 20 20 20 20 20 20 20 20 20
221 0.00572608 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0A 0D 2B 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
222 0.00421625 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
223 0.00003911 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
224 0.00278709 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
225 0.00082217 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
226 0.00567963 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 65 20 50 72 6F 67 72 61 6D 20 20 20 20 20 20 20 20 20 20 20 20
227 0.00441488 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
228 0.00003674 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
229 0.00268882 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
230 0.00001173 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
231 0.00444142 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
232 0.00414054 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
233 0.00002808 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
234 0.00247601 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
235 0.00000992 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 35 20 54 72 61 6E 73 6D 69 74 20 66 75 6E 74 69 6F 6E 20 74 65
236 0.00269105 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
237 0.00528147 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
238 0.00003611 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
239 0.00091918 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
240 0.00388925 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
241 0.00355304 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 65 20 53 65 6C 65 63 74 20 6B 65 79 20 28 31 7E 34 29 3A 20 00
242 0.00322604 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
243 0.00002836 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
244 0.00218631 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
245 0.00180274 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 53 61 6D 70 6C 65 20 50 72 6F 67 72 61 6D 20 20 20 20 20 20
246 0.00484775 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
247 0.00511545 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
248 0.00003080 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
249 0.00169309 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
250 0.00179883 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 65 73 74 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
251 0.00488519 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20 20 20 20 20 20
252 0.00509785 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
253 0.00003660 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
254 0.00191728 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
255 0.00179199 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
256 0.00489720 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
257 0.00380097 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
258 0.00003080 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
259 0.00236776 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
260 0.00083230 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 0D 50 6C 65 61 73 65 20 53 65 6C 65 63 74 20 6B 65 79 20 28 31
261 0.00483413 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
262 0.00285951 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
263 0.00003450 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
264 0.00281670 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
265 0.00178905 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
266 0.00583859 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
267 0.00127495 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 CANCELLED Length 64
268 0.00003094 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
269 0.00183864 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AE 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
270 0.00280643 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 69 76 65 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20
271 0.00573704 NuMicro ISP Pro IRP_MJ_READ MosChipSerial11 SUCCESS Length 64: 6D 69 74 20 66 75 6E 74 69 6F 6E 20 74 65 73 74 20 20 20 20 20
272 0.00001369 NuMicro ISP Pro IOCTL_SERIAL_PURGE MosChipSerial11 SUCCESS Purge: RXABORT RXCLEAR
273 0.00001083 NuMicro ISP Pro IOCTL_SERIAL_SET_TIMEOUTS MosChipSerial11 SUCCESS RI:200 RM:0 RC:0 WM:0 WC:0
274 0.00137825 NuMicro ISP Pro IRP_MJ_WRITE MosChipSerial11 SUCCESS Length 64: AB 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
275 0.00000691 NuMicro ISP Pro IRP_MJ_CLEANUP MosChipSerial11 SUCCESS
276 0.01834011 NuMicro ISP Pro IRP_MJ_CLOSE MosChipSerial11 SUCCESS
无冕之王 发表于 2010-12-21 18:07 | 显示全部楼层
这代码:dizzy:
xsgy123 发表于 2010-12-21 21:53 | 显示全部楼层
这个咋分析呢
杜_U_ME 发表于 2010-12-21 22:42 | 显示全部楼层
看不懂啊
X-Hawk 发表于 2010-12-21 23:35 | 显示全部楼层
大叔还是很厉害的
yybj 发表于 2010-12-22 21:48 | 显示全部楼层
菜农能给分析分析这些代码吗
