谁用DSPic系列的DSP搞过电机控制
2867|2
 楼主| t2230510 发表于 2010-12-28 20:46 | 显示全部楼层 |阅读模式
在PIC的官网上找到 电机控制的 电压空间矢量算法 (代码名SVM.C  和sinusoidalBLDC v1.2.c)。大部分都看懂了。
把此代码移植到我手头的板子上,有PWM输出了,但电机没反应。
我想确认下,这2个代码真能实现 SVPWM?
有大侠若买过DSPic的开发板,肯定知道。帮帮忙,谢谢啦!
 楼主| t2230510 发表于 2010-12-28 20:56 | 显示全部楼层
if(angle < VECTOR2)
        angle2 = angle - VECTOR1;                // Reference SVM angle to the current
                                    // sector
        angle1 = SIXTY_DEG - angle2;        // Calculate second angle referenced to
                                    // sector
        t1 = sinetable[(unsigned char)(angle1 >> 6)];        // Look up values from
                                                    // table.
        t2 = sinetable[(unsigned char)(angle2 >> 6)];
        // Scale t1 to by the volts variable.
        t1 = ((long)t1*(long)volts) >> 15;
        // Scale t1 for the duty cycle range.
        t1 = ((long)t1*(long)tpwm) >> 15;
        // Scale t2 time
        t2 = ((long)t2*(long)volts) >> 15;
        t2 = ((long)t2*(long)tpwm) >> 15;
        half_t0 = (tpwm - t1 - t2) >> 1;                // Calculate half_t0 null time from   / period and t1,t2
        // Calculate duty cycles for Sector 1  (0 - 59 degrees)
        PDC1 = t1 + t2 + half_t0;
        PDC2 = t2 + half_t0;
        PDC3 = half_t0;
 楼主| t2230510 发表于 2010-12-28 20:58 | 显示全部楼层
2楼为 SVM.C中的部分代码。百度里,很难搜到跟这相关的。看来,用DSPic搞电机控制的不多啊!
