中文user module datasheet
2994|5
 楼主| Go_PSoC 发表于 2011-1-4 17:38 | 显示全部楼层 |阅读模式
 楼主| Go_PSoC 发表于 2011-1-4 17:40 | 显示全部楼层
另外我把标题贴出来供大家参考,因为比较多,我就不一一贴在这里了,假如那位需要,并且下载不方便的话,我也可以帮忙
User Module Datasheet: 8-Bit UART Data Sheet, UART V 5.3 (CY8C29/27/24/22/21xxx, CY8C23x33, CY7C64215, CYWUSB6953, CY8CLED02/04/08/16, CY8CLED03D/04D, CY8CNP102, CY8CTST110, CY8CTMG110, CY8CTST120, CY8CTMG120, CY8CTMA120, CY8C21x45, CY8C22x45, CY8CTMA30xx, CY8C28x45, CY8CPLC20, CY8CLED16P01, CY8C28x43, CY8C28x52) - chinese New
Not yet rated
12/29/10
User Module Datasheet: I2C Bootloader Data Sheet, BOOTLDRI2C (CY8C20x96, CY8C20x66, CY8C20x46, CY8C20x36, CY7C643/4/5xx, CY7C60413, CY7C60424, CY7C6053x, CY8CTST200, CY8CTMG200, CYONS2xxx, CYONSFN2xxx, CYONSTB2010, CYONSTB2011, CY8CTMA30xx) - Chinese New
Not yet rated
12/27/10
User Module Datasheet: Autotuning CapSense® Sigma-Delta Data Sheet, CSDAUTO V 1.1(CY8C20x66, CY8C20x36, CY8C20336AN, CY8C20436AN, CY8C20636AN, CY8C20x46, CY8C20x96, CY7C645xx, CY7C643/4/5xx, CY7C60424, CY7C6053x, CYONS2110, CYONS21L1T, CYONSFN2162) - Chinese New
Not yet rated
12/27/10
Enhanced 16-Bit Dead Band PWM Data Sheet - Chinese
Not yet rated
12/16/10
Enhanced 8-Bit PWM Dead Band Data Sheet - Chinese
Not yet rated
12/16/10
User Module Datasheet: CapSense® Successive Approximation Data Sheet, CSAAUTO (CY8C20x34/24/66/36/46/96, CYONSFN2053/2061/2151/2161/2162) - chinese
Not yet rated
12/15/10
User Module Datasheet: 13-Bit Timer Data Sheet, Timer13 (CY8C20x34, CY8C20x24) - Chinese
Not yet rated
09/22/08
User Module Datasheet: 16-Bit Crc Generator Data Sheet , CRC16 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 16-Bit Pseudo Random Sequence Generator Data Sheet, PRS16 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 16-Bit Pulse Width Modulator Data Sheet, PWM16 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 16-Bit Pwm Dead Band Generator Data Sheet, PWMDB16 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 16-Bit Timer Data Sheet, Timer16 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 24-Bit Counter Data Sheet, Counter - Chinese
Not yet rated
09/22/08
User Module Datasheet: 24-Bit Pseudo Random Sequence Generator Data Sheet, PRS24 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 24-Bit Timer Data Sheet, Timer24 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 32-Bit Counter Data Sheet, Counter - Chinese
Not yet rated
09/22/08
User Module Datasheet: 32-Bit Pseudo Random Sequence Generator Data Sheet, PRS32 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 32-Bit Timer Data Sheet, Timer32 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 4 To 1 Analog Multiplexer Data Sheet , AMUX4 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 7-Segment LED Controller Data Sheet, LED7SEG - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8 To 1 Analog Multiplexer Data Sheet , AMUX8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Counter Data Sheet, Counter - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Pseudo Random Sequence Generator Data Sheet, PRS8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Pulse Width Modulator Data Sheet, PWM8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Pwm Dead Band Generator Data Sheet, PWMDB8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Serial Receiver Data Sheet, RX8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Serial Transmitter Data Sheet, TX8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: 8-Bit Timer Data Sheet, Timer8 - Chinese
Not yet rated
09/22/08
User Module Datasheet: CapSense Successive Approximation Data Sheet, CSA - Chinese
Not yet rated
09/22/08
User Module Datasheet: Digital Buffers Data Sheet, DIGBUF - Chinese
Not yet rated
09/22/08
User Module Datasheet: Digital Inverter Data Sheet, DIGINV - Chinese
Not yet rated
09/22/08
User Module Datasheet: I2C Bootloader Data Sheet, BOOTLDRI2C - Chinese
Not yet rated
09/22/08
User Module Datasheet: Ir Optical Receiver Data Sheet, IRDARX - Chinese
Not yet rated
09/22/08
User Module Datasheet: Ir Optical Transmitter Data Sheet, IRDATX - Chinese
Not yet rated
09/22/08
User Module Datasheet: LED Data Sheet, LED - Chinese
Not yet rated
09/22/08
User Module Datasheet: Single Slope 10-Bit ADC Data Sheet, ADC10 - Chinese
Not yet rated
09/22/08
User Module Datasheet: Sleeptimer Data Sheet, SLEEPTIMER - Chinese
Not yet rated
09/22/08
User Module Datasheet: UART Data Sheet, UART - Chinese
Not yet rated
09/22/08
PSOC菜鸟 发表于 2011-1-5 18:06 | 显示全部楼层
支持中文!
lzerof 发表于 2011-1-10 13:16 | 显示全部楼层
2044 有没有中文的?
jxin 发表于 2011-1-10 13:27 | 显示全部楼层
 楼主| Go_PSoC 发表于 2011-12-4 22:32 | 显示全部楼层
