[产品供应] 雷凌 ralink rt3070 WIFI模块/无线网卡
2877|1
 楼主| tongtongkk 发表于 2011-1-8 14:55 | 显示全部楼层 |阅读模式
雷凌 ralink rt3070 WIFI模块/无线网卡,适合应用于多媒体高清播放器/IP TV网络电视/机顶盒等
Standards
IEEE802.11b, 802.11g and , 802.11n Draft
Operating Frequency
USA (FCC): 2.412GHz ~ 2.462GHz ISM band (channel 1 – 11)
Europe (CE): 2.412GHz ~ 2.472GHz ISM band (channel 1 – 13)
Channel Bandwidth
20/40MHz
Protocols
802.11b: CCK, QPSK, BPSK
802.11g: OFDM
Draft-11n: BPSK, QPSK, 16-QAM, 64-QAM
Antenna
PCB Antenna or IPEX socket for External Antenna.  For details, please refer to ordering information.
Security
WPA/WPA2, 64/128/152-bit WEP, WPS
Transmit Output Power
11b: 16±1.5dBm @ 11Mbps
11g: 13±1.5dBm @ 54Mbps
11n: 12.5±1.5dBm
Receive Sensitivity
11b: -82dBm @ 11Mbps (Typical)
11g: -68dBm @ 54Mpbs (Typical)
11n: -68dBm (Typical)
Operating Voltage
5.0V DC ± 5%
Power On/Off
External On/Off switch support. For details, please refer to ordering information.
Bus Interface
A-type USB 2.0 Connector or 4-pin 2mm pitch Pin header depends on option.
Antenna Port Impedance
50 ohm
shyfr@sina.com
13670257125同工
 楼主| tongtongkk 发表于 2011-1-8 14:56 | 显示全部楼层
