简单的PWM波形输出配置
2242|0
绿眼孤狼|  楼主 | 2011-1-29 22:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stm32f10x_lib.h"
#include "stm32f10x_conf.h"
u16                CCR1_Val = 250;
u16                CCR2_Val = 500;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void TIM_Configuration(void);
int main(void)
        RCC_Configuration();
        GPIO_Configuration();
        NVIC_Configuration();
        TIM_Configuration();
        while(1);
        ErrorStatus                HSEStartUpStatus;
        RCC_DeInit();
        RCC_HSEConfig(RCC_HSE_ON);
        HSEStartUpStatus = RCC_WaitForHSEStartUp();
        if(HSEStartUpStatus == SUCCESS)
                 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
                FLASH_SetLatency(FLASH_Latency_2);
                RCC_HCLKConfig(RCC_SYSCLK_Div1);
                RCC_PCLK2Config(RCC_HCLK_Div1);
                RCC_PCLK1Config(RCC_HCLK_Div4);
                RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
                RCC_PLLCmd(ENABLE);
                while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
                RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
                while(RCC_GetSYSCLKSource() != 0x08);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitTypeDef        GPIO_InitStructure;
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        #ifdef VECT_TAB_RAM
                NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
        #else
                NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0X0);
        #endif
        TIM_TimeBaseInitTypeDef                TIM_TimeBaseStructure;
        TIM_OCInitTypeDef                        TIM_OCInitStructure;
                TIM3的内部时钟频率为36MHz,每个PWM通道的频率经
        (TIM_Period + 1)后为36KHz.
                输出的占空比为:
                        duty cycle = TIM_Pulse/(TIM_Period + 1) * 100%
        TIM_TimeBaseStructure.TIM_Period                = 999;
        TIM_TimeBaseStructure.TIM_Prescaler                = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision        = 0;
        TIM_TimeBaseStructure.TIM_CounterMode        = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        //------------- 占空比为 50% 输出波形 ----------------
        TIM_OCInitStructure.TIM_OCMode                = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState        = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse                = CCR1_Val;
        TIM_OCInitStructure.TIM_OCPolarity        = TIM_OCPolarity_High;
        TIM_OC1Init(TIM3, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
        //------------- 占空比为 25% 输出波形 ---------------
        TIM_OCInitStructure.TIM_Pulse                = CCR2_Val;
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM3, ENABLE);
        TIM_Cmd(TIM3, ENABLE);
#ifdef                DEBUG
void assert_failed(u8 *file, u32 line)
        while(1);
#endif
