那位高手帮忙看下CCS2000的这两条错误是什么意思??
2316|0
 楼主| jiaxin1 发表于 2011-2-11 18:41 | 显示全部楼层 |阅读模式
Can't Remove Breakpoint: Error 0x0000000A/-1153 Error during: Memory, Break ;Point,  The memory at 0x003F87C1 continually indicated it was 'not ready' All memory operations currently in progress were aborted in order to regain control of the processor. This is considered a catastrophic event, but the debugger should  still be able to access memory and CPU registers. System state has been altered.  It is strongly advised that the processor should be reset before resuming execution,
Breakpoint Manager: An error was encountered attempting to clear a breakpoint used
for end of program detection.
2812软件复位时出现:
Failed Software Reset: Error 0x00000020/-1150 Error during: Execution,  JTAG protocol reset.  t 0x003F87C1 continually indicated it was 'not ready' All memory operations currently in progress were aborted in order to regain control of the processor. This is considered a catastrophic event, but the debugger should  still be able to access memory and CPU registers. System state has been altered.  It is strongly advised that the processor should be reset before resuming execution,
请问这两种故障是什么原因造成的
