STM32101CB仿真,程序目标代码大于64K时,不能下载
4286|7
 楼主| xddl 发表于 2011-2-21 16:30 | 显示全部楼层 |阅读模式
使用J-LINK,程序目标代码大于64K时,不能下载
为什么?
香水城 发表于 2011-2-21 16:31 | 显示全部楼层
不能下载是什么意思?提示信息是什么?芯片选择对吗?
 楼主| xddl 发表于 2011-2-21 16:38 | 显示全部楼层
提示信息如下:
全部debug log
Mon Feb 21 16:41:30 2011: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 5.50\arm\config\flashloader\ST\FlashSTM32F10xxx.mac
Mon Feb 21 16:41:33 2011: JLINK command: ProjectFile = C:\prj\yjv3\timertest\settings\timertest_PROTOCOL_TEST.jlink, return = 0
Mon Feb 21 16:41:33 2011: JLINK command: device = STM32F10xx8, return = 0
Mon Feb 21 16:41:33 2011: DLL version: V4.14
Mon Feb 21 16:41:33 2011: Firmware: J-Link ARM V8 compiled Dec  1 2009 11:42:48
Mon Feb 21 16:41:33 2011: JTAG speed is initially set to: 32 kHz
Mon Feb 21 16:41:33 2011: TotalIRLen = 9, IRPrint = 0x0011
Mon Feb 21 16:41:33 2011: Found Cortex-M3 r1p1, Little endian.
Mon Feb 21 16:41:33 2011: TPIU fitted.
Mon Feb 21 16:41:33 2011:   FPUnit: 6 code (BP) slots and 2 literal slots
Mon Feb 21 16:41:34 2011: Hardware reset with strategy 0 was performed
Mon Feb 21 16:41:34 2011: Initial reset was performed
Mon Feb 21 16:41:34 2011: Found 2 JTAG devices, Total IRLen = 9:
Mon Feb 21 16:41:34 2011:  #0 Id: 0x3BA00477, IRLen:  4, IRPrint: 0x1 CoreSight JTAG-DP
Mon Feb 21 16:41:34 2011:  #1 Id: 0x16410041, IRLen:  5, IRPrint: 0x1 STM32 Boundary Scan
Mon Feb 21 16:41:34 2011: -I- execUserFlashInit!
Mon Feb 21 16:41:35 2011: 456 bytes downloaded and verified (0.73 Kbytes/sec)
Mon Feb 21 16:41:35 2011: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 5.50\arm\config\flashloader\ST\
FlashSTM32F10xxxRAM10K.out
Mon Feb 21 16:41:35 2011: Target reset
Mon Feb 21 16:41:35 2011: Writing outside flash memory at address 0x801F800
 楼主| xddl 发表于 2011-2-21 16:42 | 显示全部楼层
程序没这么大,多出来的是数据。把数据删掉一些,只要超过64K,就报告同样的错误
 楼主| xddl 发表于 2011-2-21 16:43 | 显示全部楼层
使用ST的ISP下载程序falsh loader demo,就可以下载
 楼主| xddl 发表于 2011-2-21 16:56 | 显示全部楼层
找到原因了
没注意编译的主选项。
谢谢版主的提醒
winloop 发表于 2011-2-21 17:28 | 显示全部楼层
这种基本错误太闹人了
dfsa 发表于 2011-2-21 20:25 | 显示全部楼层
的确是很基本,不过初学者很容易犯的
