[其他ST产品] 问题急请教STR710:用SPI驱动EEPROM型号为AT25128
5233|3
 楼主| zhangqiqing 发表于 2011-2-24 09:51 | 显示全部楼层 |阅读模式
求教各位大虾,谢谢帮忙:
我用STR710F的SPI接口驱动EEPROM型号为AT25128,调试了很长时间了,实在没办法了,这是我的电路连接图
file:///C:/Documentsfile:///C:/Documents
现在读出来全是0,不知写进去了没.下面是我的调试结果  截屏file:///C:/Documentsfile:///C:/Documents
下面是我的部分程序
# define __AT251_H__
#include  "bspi.h"
#define SPI_SS_Pin (//0x0001<<8)
#define err 0x00
#define  EEPROM_CAPACITY   0x3fff        // EEPROM capacity (bytes)
#define WREN  0x06
#define WRDI  0x04
#define RDSR  0x05
#define WRSR  0x01
#define READ  0x03
#define WRITE 0x02
#define READY 0x01
#define BUSY  0x02
#define WR_EN 0x03
#define WR_DI 0x04
extern void AT251_init(void);
extern u8 CheckStatus(enum AT25_STATUS State);
extern void AT251_CmdWrite(u8 cmd);
extern u8 AT251_readbyte(u16 addr);
extern void AT251_AddrWrite(u16 addr);
extern void AT251_ByteWrite(u16 addr,u8 data );//void AT251_DataByteWrite(u16 addr,u8 data);
extern u8 AT251_DataWrite(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts);//void AT251_DataStrWrite(u8 *String,u16 addr,u8 len );
extern void AT251_DataRead(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts);//extern void AT251_DataRead(u8 *buf,u16 addr,u8 n);
#endif
/**************************C文件****************************/
#include "at251.h"
//#include  "bspi.h"
void BSPI1_init(void)
  GPIO_Config(GPIO0, 0x0070, GPIO_AF_PP);// GPIO_Config(GPIO0, 0x00F0, GPIO_AF_PP); //Configure GPI00 on mode Alternate function Push Pull
  GPIO_Config(GPIO0, 0x0080, GPIO_OUT_PP);
  BSPI_Init(BSPI1);
  BSPI_ClockDividerConfig(BSPI1, 8);  //Configure Baud rate Frequency :-->APB1/8
  BSPI_Enable(BSPI1, ENABLE);    //Enable BSPI1
  BSPI_MasterEnable(BSPI1, ENABLE);
  BSPI_ClkActiveHigh(BSPI1, ENABLE);  //Configure the clock to be active high
  BSPI_ClkFEdge(BSPI1, DISABLE);   //Enable capturing the first Data sample on the first edge of SCK
  BSPI_8bLEn(BSPI1, ENABLE);    //Set the word length to 8 bit
  BSPI_RcFifoDepth(BSPI1, 7);    //Configure the depth of receive to 5 word
   BSPI1_init();
   GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  u8 buf;
  GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  BSPI_WordSend(BSPI1,READ);
  AT251_AddrWrite(addr);
  buf=BSPI_WordReceive(BSPI1);
  return(buf);
    BSPI_WordSend(BSPI1, cmd);
BSPI_WordSend(BSPI1,(u8)(addr>>8));
BSPI_WordSend(BSPI1,(u8)addr);
void AT251_ByteWrite(u16 addr,u8 data )//指定地址写一个字节
{int i;
AT251_CmdWrite(WREN);//WRITE ENABLE
GPIO_BitWrite(GPIO0,0x07,0);//ss=0;AT251_CmdWrite(WRITE);
BSPI_WordSend(BSPI1,WRITE);
BSPI_WordSend(BSPI1,data);
AT251_CmdWrite(WRDI );//写禁止
for(i=0;i<40;i++);
u8 CheckStatus()
{ u8 S;
  //AT251_CmdWrite(WREN);//WRITE ENABLE
  BSPI_WordSend(BSPI1,RDSR);
  S=BSPI_WordReceive(BSPI1);
  GPIO_BitWrite(GPIO0,0x07,1);//ss=0;
  return S;
void AT251_DataRead(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts)//指定地址读取指定个数据
u16 j,m;
u16 dataword;
for(j=addr1;j<addr2;j++)
   BSPI_WordSend(BSPI1,READ);//AT251_CmdWrite(READ);
   dataword=(j-1);//dataword=32*(j-1);
   AT251_AddrWrite(dataword);
   buf[(j-addr1)]=BSPI_WordReceive(BSPI1);
   //for(m=0;m<8;m++);
u8 AT251_DataWrite(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts)//指定地址读取指定个数据
{   u8 j,m ;
   u8 databyte ;
   u16 dataword ;
    { databyte=CheckStatus(READY_BUSY);
      if(databyte) return(1);
      dataword=(j-1);
   BSPI_WordSend(BSPI1,buf[j-addr1]);
   //for(m=0;m<8;m++);
  return(0);
/**********************主函数如下:***************************/
#include "71x_lib.h"
#include "at251.h"
#include "uart.h"
#define UART2_Rx_Pin (0x0001<<13)  // TQFP 64: pin N?5  , TQFP 144 pin N?9
#define UART2_Tx_Pin (0x0001<<14)  // TQFP 64: pin N?6  , TQFP 144 pin N?10
#define UART3_Rx_Pin (0x0001<<1)   // TQFP 64: pin N?52 , TQFP 144 pin N?123
#define UART3_Tx_Pin (0x0001<<0)   // TQFP 64: pin N?53 , TQFP 144 pin N?124
#define Use_UART3
#ifdef Use_UART3
#define UARTX UART3
#define UARTX_Rx_Pin UART3_Rx_Pin
#define UARTX_Tx_Pin UART3_Tx_Pin
#endif  /*Use_UART2 */
char buf_TX[22]="aaaaaaaaaaaaaaaaaaaaa";
char buf_RX[22]="11111111111111111111\n";
void def_extclock(void);
void MY_UART_init3(void);
void Main(void)
int i;
#ifdef DEBUG
debug();
#endif
      def_extclock(); //将CKOUT 分为 48 Mhz
      MY_UART_init3(); //UART初始化,包括管脚设置,波特率设置,及发送或接收使能等
      AT251_init();
  while(1)
   AT251_DataWrite((u8 *)buf_TX,1,10,0);
   for(i=0;i<50000;i++);
      AT251_DataRead((u8 *)buf_RX,1,10,0);
   UART_DataSend(UARTX, (u8 *)buf_RX,20);
 楼主| zhangqiqing 发表于 2011-2-24 09:56 | 显示全部楼层
  1. #include "at251.h"
  2. //#include  "bspi.h"
  3. /////////////////////////////////////////////////////////////////////////
  4.
  5. void BSPI1_init(void)
  6. {
  7.   GPIO_Config(GPIO0, 0x0070, GPIO_AF_PP);// GPIO_Config(GPIO0, 0x00F0, GPIO_AF_PP); //Configure GPI00 on mode Alternate function Push Pull
  8.   GPIO_Config(GPIO0, 0x0080, GPIO_OUT_PP);
  9.   BSPI_Init(BSPI1);
  10.   BSPI_ClockDividerConfig(BSPI1, 8);  //Configure Baud rate Frequency :-->APB1/8
  11.   BSPI_Enable(BSPI1, ENABLE);    //Enable BSPI1
  12.   BSPI_MasterEnable(BSPI1, ENABLE);
  13.   BSPI_ClkActiveHigh(BSPI1, ENABLE);  //Configure the clock to be active high
  14.   BSPI_ClkFEdge(BSPI1, DISABLE);   //Enable capturing the first Data sample on the first edge of SCK
  15.   BSPI_8bLEn(BSPI1, ENABLE);    //Set the word length to 8 bit
  16.   BSPI_RcFifoDepth(BSPI1, 7);    //Configure the depth of receive to 5 word
  17. }
  18. /////////////////////////////////////////////////////////////////////////////
  19. void AT251_init(void)
  20. {
  21.    BSPI1_init();
  22.    GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  23. }
  24. /////////////////////////////////////////////////////////////////////////////////////
  25. u8 AT251_readbyte(u16 addr)
  26. {
  27.   u8 buf;
  28.   GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  29.   BSPI_WordSend(BSPI1,READ);
  30.   AT251_AddrWrite(addr);
  31.   buf=BSPI_WordReceive(BSPI1);
  32.   GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  33.   return(buf);
  34. }
  35. //////////////////////////////////////////////////////////////////////////////////
  36. void AT251_CmdWrite(u8 cmd)
  37. {
  38.     GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  39.     BSPI_WordSend(BSPI1, cmd);
  40.     GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  41. }
  42. ////////////////////////////////////////////////////////////////////////////////
  43. void AT251_AddrWrite(u16 addr)
  44. {
  45. BSPI_WordSend(BSPI1,(u8)(addr>>8));
  46. BSPI_WordSend(BSPI1,(u8)addr);
  47. }
  48. //////////////////////////////////////////////////////////////////////
  49. void AT251_ByteWrite(u16 addr,u8 data )//指定地址写一个字节
  50. {int i;
  51. AT251_CmdWrite(WREN);//WRITE ENABLE
  52. GPIO_BitWrite(GPIO0,0x07,0);//ss=0;AT251_CmdWrite(WRITE);
  53. BSPI_WordSend(BSPI1,WRITE);
  54. AT251_AddrWrite(addr);
  55. BSPI_WordSend(BSPI1,data);
  56. GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  57. AT251_CmdWrite(WRDI );//写禁止
  58. for(i=0;i<40;i++);
  59. }
  60. //////////////////////////////////////////////////////////////////////////////////
  61. u8 CheckStatus()
  62. { u8 S;
  63.   //AT251_CmdWrite(WREN);//WRITE ENABLE
  64.   GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  65.   BSPI_WordSend(BSPI1,RDSR);
  66.   S=BSPI_WordReceive(BSPI1);
  67.   GPIO_BitWrite(GPIO0,0x07,1);//ss=0;
  68.   return S;
  69.
  70. }
  71. /////////////////////////////////////////////////////////////////////////////////////
  72. void AT251_DataRead(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts)//指定地址读取指定个数据
  73. {
  74. u16 j,m;
  75. u16 dataword;
  76. //AT251_CmdWrite(WREN);
  77. for(j=addr1;j<addr2;j++)
  78.   {
  79.    GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  80.    BSPI_WordSend(BSPI1,READ);//AT251_CmdWrite(READ);
  81.    dataword=(j-1);//dataword=32*(j-1);
  82.    AT251_AddrWrite(dataword);
  83.    buf[(j-addr1)]=BSPI_WordReceive(BSPI1);
  84.    //for(m=0;m<8;m++);
  85.    GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  86.   }
  87.
  88. }
  89. ///////////////////////////////////////////////////////////////////////////////////////////////
  90. u8 AT251_DataWrite(u8 *buf,u16 addr1,u16 addr2,u16 lastcounts)//指定地址读取指定个数据
  91. {   u8 j,m ;
  92.    u8 databyte ;
  93.    u16 dataword ;
  94.     for(j=addr1;j<addr2;j++)
  95.     { databyte=CheckStatus(READY_BUSY);
  96.       if(databyte) return(1);
  97.       AT251_CmdWrite(WREN);
  98.       GPIO_BitWrite(GPIO0,0x07,0);//ss=0;
  99.       BSPI_WordSend(BSPI1,WRITE);
  100.       dataword=(j-1);
  101.    AT251_AddrWrite(dataword);
  102.    BSPI_WordSend(BSPI1,buf[j-addr1]);
  103.    //for(m=0;m<8;m++);
  104.
  105.    GPIO_BitWrite(GPIO0,0x07,1);//ss=1;
  106.     }
  107.
  108.   return(0);
  109. }
我看时序也对,不知哪里有错误,先顶一下,望各位帮忙看看
 楼主| zhangqiqing 发表于 2011-2-28 14:13 | 显示全部楼层
没人帮忙:(
周浩飞123 发表于 2015-4-16 11:06 | 显示全部楼层
你好,你有AT25128的读写程序吗?我遇到和你差不多的情况,写不进去数据。
