红外解码+1602显示只是出00000000  求解
3364|5
 楼主| ligouning 发表于 2011-2-25 11:09 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint  unsigned int
int hightime, lowtime;
uchar m,inok,h,i,j;
uchar table[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
uchar mun[8];
uchar we[4];
sbit IRIN=P3^3;
sbit wlen=P2^7;
sbit wlrs=P2^5;
sbit RW=P2^6;
/*......................................延时程序,延时1ms................*/
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
/*......................................1602命令函数.....................*/
void write_com(uchar com)
wlrs=0;      //写命令0/写数据1
RW=0;     //读0/写1
P0=com;     //给1602送命令
delay(5);
wlen=1;
delay(5);
wlen=0;
/*......................................1602数据函数.....................*/
void write_date(uchar date)
wlrs=1;
RW=0;
P0=date;
delay(5);
wlen=1;
delay(5);
wlen=0;
/*......................................1602初始化........................*/
void inint()
wlen=0;
write_com(0x38);   //显示模式设置
write_com(0x0f);   //光标显示设置
write_com(0x06);   //光标闪动设置
write_com(0x80);   //数据清零
/*......................................1602解码显示......................*/
void Function()
// uchar h,g;
mun[0]=we[0]/16;
mun[1]=we[0]%16;
mun[2]=we[1]/16;
mun[3]=we[1]%16;
mun[4]=we[2]/16;
mun[5]=we[2]%16;
mun[6]=we[3]/16;
mun[7]=we[3]%16;
for(h=0;h<8;h++)
//  m=mun(h);
  write_date(table[mun[h]]);
  delay(5);
/*....................................红外解码............................*/
bit my(void)
uchar temp;
// int i,j;
for(i=0;i<4;i++)    //4组数据:高用户码、低用户码、操作码、操作反码
  temp=0;
  for(j=0;j<8;j++)   //每组码有八位数据
   temp=temp>>1;   //数据的按位左移
   TH1=0;
   TL1=0;
   TR1=1;
   while(IRIN==0);
   TR1=0;
   lowtime=TH1*256+TL1; //接收到低电平的时间
   TH1=0;
   TL1=0;
   TR1=1;
   while(IRIN==1);
   TR1=0;
   hightime=TH1*256+TL1;  //接收到高电平的时间
   if((lowtime<370)||(lowtime>640))  //是不是在0.56us左右,是不是由此遥控器发出的
    return 0;         //不是返回0
   if((hightime<640)&&(hightime>370))  //高电平在0.56左右,这位是0
    temp=temp&0x7f;       //该位置0
   if((hightime<1800)&&(hightime>1300))   //高电平在1.685左右,这位是1
    temp=temp|0x80;        //置1
  we[i]=temp;       //求出的值给四个数组
  // if(we[2]=~we[3])
   return 1;   //解码完成,返回1
void main()
// m=0;
inint();
  IE=0x84;
TCON=0x04;
TMOD=0x10;
TR1=1;
IRIN=1;
while(1);
  if(inok)
   P0=mun[m];
   if(m>8)
    m=0;
/*......................................外部中断1..............*/
void IR_IN() interrupt 2     //当遥控器有键按下,下降沿触发进入中断
EX1=0;         //关外部中断1,
TH1=0;         //定时器设初值
TL1=0;
TR1=1;
while(IRIN==0);       //如果还是低电平,在此循环
TR1=0;         //低电平结束,关定时器
hightime=TH1*256+TL1;     //算低电平持续的时间
TH1=0;
TL1=0;
TR1=1;
while(IRIN==1);
if((hightime>7800)&&(hightime<8800)&&(lowtime>3600)&&(lowtime<4700))   //是不是此遥控器的引导码
  if(my()==1)    //解码是否完成
   write_com(0x80);
   Function();
IE=0x84;    //为下次解码开中断
 楼主| ligouning 发表于 2011-2-25 23:14 | 显示全部楼层
自己顶上!!!!!纠结
honglanjiang 发表于 2011-2-25 23:38 | 显示全部楼层
这个是挺纠结
 楼主| ligouning 发表于 2011-2-27 22:49 | 显示全部楼层
悲剧只有我来上演吗??
654991568 发表于 2011-10-26 14:33 | 显示全部楼层
这个lowtime
我想应该一直等于hightime都等于0
这个lowtime
