在移植官方例程的时候,发现当采用例程所用的DMACHN2 TIM2 ,可以输出文档所描述的波形。但如果用TIM1 DMACHN5 却不能够输出波形。而且,定时器好像变慢了,调试时进入DMA中断要等很久。不知道是为什么?希望各位大侠能够帮忙。谢谢!
能够正常运行的设置
中断配置
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_IRQChannel ;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
#define TIM2_ARR_Address 0x4000002C
定时器与DMA设置
/* GPIOA Configuration:TIM2 Channel1 in Output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* TIM2 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
TIM2 Configuration: Output Compare Toggle Mode:
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period =60000;
TIM_TimeBaseStructure.TIM_Prescaler = 2;
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Output Compare Toggle Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_Toggle;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM2, ENABLE);
/* TIM enable counter */
TIM_Cmd(TIM2, ENABLE);
DMA1 configuration
/* DMA1 channel2 configuration ----------------------------------*/
DMA_DeInit(DMA1_Channel2);
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM2_ARR_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SRC_Buffer_INC;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = BufferSize;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel2, &DMA_InitStructure);
/* Enable DMA1 Channel2 Transfer Complete interrupt */
DMA_ITConfig(DMA1_Channel2, DMA_IT_TC, ENABLE);
/* Enable DMA1 Channel2 */
DMA_Cmd(DMA1_Channel2, ENABLE);
/* Enable TIM2 DMA update request */
TIM_DMACmd(TIM2,TIM_DMA_Update, ENABLE);
中断服务程序
void SysTickHandler(void)
/* Change the DMA_MemoryBaseAddr to the decrement buffer */
DMA1_Channel2->CMAR = (u32)SRC_Buffer_DEC;
/* Define the DMA_BufferSize */
DMA1_Channel2->CNDTR = BufferSize;
DMA1_Channel2->CCR |= ((u32)0x00000001);
/* Enable TIM2 DMA request */
TIM2->DIER |= TIM_DMA_Update;
/* Disable SysTick Counter */
SysTick->CTRL &= 0xFFFFFFFE;
/* Clear SysTick Counter */
SysTick->VAL = ((u32)0x00000000);
acceleration = SET;
void DMA1_Channel2_IRQHandler(void)
/* Disable TIM2 DMA */
TIM2->DIER &= ~TIM_DMA_Update;
/* Disable DMA Channel2 request */
DMA1_Channel2->CCR &= ((u32)0xFFFFFFFE);
if(acceleration == SET)
DMA1_Channel2->CMAR =(u32)SRC_Buffer_INC;
/* Enable DMA Channel2 */
acceleration = RESET;
else
Systick_Config();
#if 0
/* SysTick end of count event each 8ms */
/* Setup SysTick Timer for 1 msec interrupts */
if (SysTick_Config(72000000 / 8000)) /* SystemFrequency is defined in
“system_stm32f10x.h” and equal to HCLK frequency */
/* Capture error */
while (1);
#endif
acceleration = SET;
/* Clear DMA1 Channel2 Transfer Complete pending bit */
DMA1->IFCR = DMA1_FLAG_TC2;
不能够正常运行的相应设置为:
中断服务程序配置
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel5_IRQChannel ;
#define TIM1_ARR_Address TIM1_BASE+0x2c//0x4000002C//
定时器与DMA设置
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
/* GPIOA Configuration:TIM1 Channel1 in Output */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
#if 0
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
#endif
TIM_DeInit(TIM1);
/* TIM1 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
TIM1 Configuration: Output Compare Toggle Mode:
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
//TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
//TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM1, ENABLE);
/* TIM1 enable counter */
TIM_Cmd(TIM1, ENABLE);
DMA1 configuration
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
DMA_DeInit(DMA1_Channel5);
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_ARR_Address;
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
/* Enable DMA1 Channel5 Transfer Complete interrupt */
DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE);
/* Enable DMA1 Channel5 */
DMA_Cmd(DMA1_Channel5, ENABLE);
/* Enable TIM1 DMA update request */
TIM_DMACmd(TIM1,TIM_DMA_Update, ENABLE);
中断服务程序
DMA1_Channel5->CMAR = (u32)SRC_Buffer_DEC;
DMA1_Channel5->CNDTR = BufferSize;
DMA1_Channel5->CCR |= ((u32)0x00000001);
/* Enable TIM1 DMA request */
TIM1->DIER |= TIM_DMA_Update;
acceleration = SET;
void DMA1_Channel5_IRQHandler(void)
/* Disable TIM1 DMA */
TIM1->DIER &= ~TIM_DMA_Update;
/* Disable DMA Channel5 request */
DMA1_Channel5->CCR &= ((u32)0xFFFFFFFE);
DMA1_Channel5->CMAR =(u32)SRC_Buffer_INC;
else
Systick_Config();
#if 0
/* Capture error */
while (1);
#endif
acceleration = SET;
/* Clear DMA1 Channel5 Transfer Complete pending bit */
DMA1->IFCR = DMA1_FLAG_TC5;
谢谢了!@ |
