DSP28335 eCAN跟usbcan通讯问题
1537|11
 楼主| Mattheww 发表于 2017-9-18 09:41 | 显示全部楼层 |阅读模式
硬件:DSP28335的eCAN-B与vp230连接,USBcan采用的是周立功的usbcan-i与上位机连接。
出现的问题是上位机上的监控软件没法接受到DSP的eCAN模块发过来的数据。
下面是代码:
void main(void)
   struct ECAN_REGS ECanbShadow;
   InitSysCtrl();//开启系统时钟和外设时钟
   InitECanGpio();//这里用到的是ecan-b的GPIO12和GPIO13
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
    MessageReceivedCount = 0;
    EALLOW;
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
    EDIS;
    ECanbRegs.CANME.all = 0;
    ECanbMboxes.MBOX0.MSGID.all = 0x01C40000;//发送 标准帧
    ECanbMboxes.MBOX1.MSGID.all = 0x18040000;//接受
    ECanbRegs.CANMD.all=0x00000002;//1->RX 0->tx
    ECanbRegs.CANME.all = 0x00000003;
    ECanbMboxes.MBOX0.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX1.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX0.MSGCTRL.bit.RTR = 0;
    ECanbMboxes.MBOX1.MSGCTRL.bit.RTR = 0;
    ECanbMboxes.MBOX0.MDL.all = 0x9555AAA0;
    ECanbMboxes.MBOX0.MDH.all = 0x89ABCDEF;
    EALLOW;
    ECanbRegs.CANMIM.all = 0xFFFFFFFF;
    ECanbRegs.CANMIL.all = 0;
    ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
    ECanbShadow.CANMC.bit.CCR = 1;
    ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
    EDIS;
    // Wait for CCE bit to be set..
    do
      ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    } while(ECanbShadow.CANES.bit.CCE != 1 );
    // Configure the eCAN timing
    EALLOW;
    ECanbShadow.CANBTC.all = ECanbRegs.CANBTC.all;
    ECanbShadow.CANBTC.bit.BRPREG = 9;    // (BRPREG + 1) = 1
    ECanbShadow.CANBTC.bit.TSEG2REG = 1 ; // to the CAN module
    ECanbShadow.CANBTC.bit.TSEG1REG = 6;  // Bit time = 2us,则为500kbps
    ECanbShadow.CANBTC.bit.SAM = 1;
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
    ECanbShadow.CANMC.bit.CCR = 0;
    EDIS;
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );
    // Configure the eCAN for self test mode
    // Enable the enhanced features of the eCAN.
    EALLOW;
    ECanbShadow.CANMC.bit.ABO = 1;
    ECanbShadow.CANMC.bit.STM = 0;    // Configure CAN for self-test mode
    ECanbShadow.CANMC.bit.SCB = 1;    // eCAN mode (reqd to access 32 mailboxes)
    EDIS;
    // Begin transmitting
    for(;;)
       ECanbRegs.CANTRS.all = 0x00000001;  // Set TRS for all transmit mailboxes,MX0开始发送
       while(ECanbRegs.CANTA.all != 0x00000001 ) {}  // Wait for all TAn bits to be set..发送完成后对应的位被置1
       ECanbRegs.CANTA.all = 0x0000FFFF;   // Clear all TAn
       MessageReceivedCount++;
       //Read from Receive mailboxes and begin checking for data */
我的想法是邮箱0设为发送邮箱,邮箱1设为接受。系统频率为100Mhz,can波特率为500k.程序运行后一直等待在while(ECanbRegs.CANTA.all != 0x00000001 ) {}这一步,也就是说没有发送完成等待置位
Erichk 发表于 2017-9-18 11:18 | 显示全部楼层
正常发送时,程序死在这个while循环,很可能是硬件造成的,如果程序曾正常工作过,当没有节点响应接收时,就会死在这个while里。
chybeyond 发表于 2017-9-18 19:57 | 显示全部楼层
检查波特率是否按照公式计算
迪卡 发表于 2017-9-18 20:49 | 显示全部楼层
可能是CAN高低接反,收发器使用错误,CAN线上无终端电阻导致CAN电平错误等。
冰河w 发表于 2017-9-18 21:01 | 显示全部楼层
一般程序要避免死在这个while里,一定要能退出这个while。
Thorald 发表于 2017-9-18 21:41 | 显示全部楼层
这自发自收,还是参考下TI的例子吧
Bjorn 发表于 2017-9-18 21:56 | 显示全部楼层
500k波特率的话,150M频率,我用的的值是9,2,10;100M的话,这几个值好像不对,
TSEG2REG最小也是2
uptown 发表于 2017-9-18 22:06 | 显示全部楼层
这个代码没有吗
uptown 发表于 2017-9-18 22:09 | 显示全部楼层
Rollo 发表于 2017-9-18 22:16 | 显示全部楼层
这种配置最好还是用官方的好,毕竟人家做的芯片,最熟不过了
Rangar 发表于 2017-9-19 12:00 | 显示全部楼层
怎么用示波器测的波特率,不是发送不成功,怎么还能测试到信号?
Soraka 发表于 2017-9-19 16:35 | 显示全部楼层
波特率可以看示波器的时间,HS-CAN,500kbps, 1bit 2 us.
有些示波器还支持简单消息分析。
