modelsim的问题希望可以得到解决
3327|3
 楼主| wangjun403 发表于 2011-3-6 12:33 | 显示全部楼层 |阅读模式
用modelsim6.5 se搞后仿真的问题
altera的库我几经按网上的教程编译好了,
仿真的时候提示如下,求指点
  1. # Compile of lfsr4.vhd was successful.
  2. # Compile of lfsr4_tb.vhd was successful.
  3. vsim -sdftyp /tb=C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo -novopt work.lfsr4_tb
  4. # vsim -sdftyp /tb=C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo -novopt work.lfsr4_tb
  5. # Loading std.standard
  6. # Loading ieee.std_logic_1164(body)
  7. # Loading ieee.std_logic_arith(body)
  8. # Loading ieee.std_logic_unsigned(body)
  9. # Refreshing C:\modeltech_6.5\examples\A_study\lfsr4\work.lfsr4_tb(behavioral)
  10. # Loading work.lfsr4_tb(behavioral)
  11. # SDF 6.5 Compiler 2009.01 Jan 22 2009
  12. #
  13. # Refreshing C:\modeltech_6.5\examples\A_study\lfsr4\work.lfsr4(behaviorial)
  14. # Loading work.lfsr4(behaviorial)
  15. # Loading instances from C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo
  16. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(39): Failed to find INSTANCE '\clk~I\'.
  17. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(39): Failed to find INSTANCE 'asynch_inst'.
  18. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(48): Failed to find INSTANCE '\clk~clkctrl\'.
  19. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(57): Failed to find INSTANCE 'extena0_reg'.
  20. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(210): Failed to find INSTANCE '\random[0]~I\'.
  21. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(210): Failed to find INSTANCE 'asynch_inst'.
  22. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(220): Failed to find INSTANCE '\random[1]~I\'.
  23. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(220): Failed to find INSTANCE 'asynch_inst'.
  24. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(230): Failed to find INSTANCE '\random[2]~I\'.
  25. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(230): Failed to find INSTANCE 'asynch_inst'.
  26. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(240): Failed to find INSTANCE '\random[3]~I\'.
  27. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(240): Failed to find INSTANCE 'asynch_inst'.
  28. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(83): Failed to find INSTANCE '\reset~I\'.
  29. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(83): Failed to find INSTANCE 'asynch_inst'.
  30. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(92): Failed to find INSTANCE '\reset~clkctrl\'.
  31. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(101): Failed to find INSTANCE 'extena0_reg'.
  32. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(194): Failed to find INSTANCE '\temp[0]\'.
  33. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(184): Failed to find INSTANCE '\temp[0]~feeder\'.
  34. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(168): Failed to find INSTANCE '\temp[1]\'.
  35. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(158): Failed to find INSTANCE '\temp[1]~feeder\'.
  36. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(142): Failed to find INSTANCE '\temp[2]\'.
  37. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(132): Failed to find INSTANCE '\temp[2]~feeder\'.
  38. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(116): Failed to find INSTANCE '\temp[3]\'.
  39. # ** Error: (vsim-SDF-3250) C:/modeltech_6.5/examples/A_study/lfsr4/lfsr4_vhd.sdo(72): Failed to find INSTANCE '\temp[3]~11\'.
  40. # ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
  41. # Error loading design
 楼主| wangjun403 发表于 2011-3-6 16:51 | 显示全部楼层
求帮助啊
 楼主| wangjun403 发表于 2011-3-6 19:57 | 显示全部楼层
 楼主| wangjun403 发表于 2011-3-7 22:32 | 显示全部楼层
wait on help;
