请教大家往flash中下载nios程序需多少时间
2271|0
 楼主| two-robots 发表于 2011-3-7 20:02 | 显示全部楼层 |阅读模式
Info: 2011-3-7 19:27:41 - (良好) sof2flash: Starting
Info: Info: *******************************************************************
Info: Info: Running Quartus II Convert_programming_file
Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=E:/Graduation_project/test/software/app_bsp/flash/test_epcs.opt E:/Graduation_project/test/test.sof E:/Graduation_project/test/software/app_bsp/flash/test_epcs.pof
Info: Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Info: Peak virtual memory: 131 megabytes
Info: Info: Processing ended: Mon Mar 07 19:27:44 2011
Info: Info: Elapsed time: 00:00:02
Info: Info: Total CPU time (on all processors): 00:00:02
Info: Info: Command: quartus_cpf --no_banner --convert E:/Graduation_project/test/software/app_bsp/flash/test_epcs.pof E:/Graduation_project/test/software/app_bsp/flash/test_epcs.rpd
Info: Info: Peak virtual memory: 130 megabytes
Info: Info: Processing ended: Mon Mar 07 19:27:48 2011
Info: Info: Elapsed time: 00:00:04
Info: Info: Total CPU time (on all processors): 00:00:03
Info: 2011-3-7 19:27:48 - (良好) sof2flash: Done
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
为什么我的卡在这不动,现在已经半小时了
