这个程序哪儿错了?郁闷
2076|3
 楼主| jinlehuang 发表于 2011-3-11 20:57 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
#define dudata
#define wedata
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uint num;
uchar t;
uchar hms(uint,char)
void display(uint);
uchar fenjie(uchar,uchar);
void delay(uint);
void init()
t=0;
num=0;
EA=1;
ET0=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
void main()
init();
while(1)
  display(num);
uchar fenjie(uchar a,uchar b)
switch(b)
  case 1: return a%10;
  case 2: return a/10;
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
  for(y=0;y<100;y++);
void display(uint num)
  wela=1;
  P0=0xfe;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'h'),2)];
  dula=0;
  delay(5);
  P0=0xff;
  wela=1;
  P0=0xfd;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'h'),1)];
  dula=0;
  delay(5);
  P0=0xff;
  wela=1;
  P0=0xfb;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'m'),2)];
  dula=0;
  delay(5);
  P0=0xff;
  wela=1;
  P0=0xf7;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'m'),1)];
  dula=0;
  delay(5);
  P0=0xff;
  wela=1;
  P0=0xef;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'s'),2)];
  dula=0;
  delay(5);
  P0=0xff;
  wela=1;
  P0=0xdf;
  wela=0;
  dula=1;
  P0=table[fenjie(hms(num,'s'),1)];
  dula=0;
  delay(5);
  P0=0xff;
uchar hms(uint num,char tim)
switch(tim)
  case 'h': return num/3600;
  case 'm': return num%3600/60;
  case 's': return num%60;
void timer0() interrupt 1
t++;
sdpz 发表于 2011-3-11 21:12 | 显示全部楼层
第15行
uchar hms(uint,char);  <-少了分号
拜托以后认真审查
 楼主| jinlehuang 发表于 2011-3-11 21:22 | 显示全部楼层
嗯 谢了
zjswuyunbo 发表于 2011-3-11 21:23 | 显示全部楼层
switch case使用错误。要加break
