[产品供应] UPA807T-T1-A绝对价格优势.....
3373|0
 楼主| renaly 发表于 2011-3-15 10:19 | 显示全部楼层 |阅读模式
ip, tc, ps, AC, AD
深圳市洪源电子有限公司
http://szhongyuandz.cn.alibaba.com
0755-83651607 罗智
品名
S1D13521B01B200
S1F75540(SCI7500f0a)
TPG018A(LC98500)
HX8633APD400
HX8902MB
HX8904-C02ATAG
HX8904TB
JBT6L88-AS
JBT6LA2-AS
JBT6L75F-AS
T6A11A
T6N21
T6A39
IR3Y29BM
PCF2103EU
PCF8563T
PCF8563T
PCF8574
PCF8578T
PCF8579T
AK4182AVN-L
AK4182AVN-L
AKM4182-AKM
AK4183VT-E2
TSC2003Izqcr TI 16PIN
TSC2046IRGVR
UPD161950P
LMS283GF02 LCM 2.8 TOUCH QVGA 24 BIT RGB 31g
ICL7667CBA
GT5G103
GT8G131-TE12L-Q
GT25G102
CT25ASJ-8-T13 IGBT
Si4404DY 30V 15A 1.6W SOP-8
SI7705D
AP20G45H SMD
FFPF06F150S 6A/1500V
FDS4501h
FDD6030L
FDC6036P 1.8V MOSFET
FDD6296
FDB6670AL
FDD6670A
FDD6690A
FDS6900AS
FDS8958A
RSS090N03L02TB
NJD47T4G
NTD110N02R-001G
MR2835S
BSC022N03S G MOSFET 30V 50A
BSO604NS2
BSC052N03SG N MOS 30V 50A
BSC079N03SG
BSC090N03MSG
HAT1128R-EL-E
RTQ035P02
STD55NH2LL-1-E
STD90N02L
BU931Z D2  10A/500V
PQA200N03FD5TB
PQA130N03FD5TB
FMMT491ATA
FMMT497ata
FMMT458TA
ZTX1149A
ZTX749TOA
ZXMN6A09DN8TA
IRFR5505 IRFR5505 18A/55V
IRF6617
STN3NF06L
TIP142T
2SC4226 (R24)
2SC4228-T2 R44
2SC4228-T2 R44
UPA807T-T1-A
mt6L58ae
BSH103
PMK35EP
EMG8
FM5822-AL
ir0530csptrpbf
ON5230
G5281RC1U
ma2s372
ma2s374
MA3J1470GL
2SB1462J-S
IPB05N03LA
2SC1173-Y
ME1302AT3
AOL1448
NP8101
MRX1533LT
VDA2310CN
SPN3414S23RG
PL3520G-P 30A/200V
PL6020J-N 60A/200V
STL11NH3L
BPW34
GP1S093HCZ0F
GP1S093HCZ0F
GP1S096HCZ
GP2W0118YP0F
GP2W0118YP0F
GP2S60B PR
RPI-222
ON2170
TS-2418-L
RPM-22PB
TCN75AVUA713
TPS613C
TPS851
AN20112A
PC410L0NIP
PS8101QFN48G Level
UP05C8GF0L
S101D01
SEDS-9981
TLE4945-2G
TSL201R
VSP6823AZRCR
TCD41B1DNABXD1 pp
TFBS4711-TR1
TCS3BB6A0BC7
GH6D410B5A1
CXD4805GA CCD
ET-TVT0310B-0AN
DL-8190-213KH
QTLP670
LOE-67B-U2AA-24-1-Z
SN9C230BJG
LM9831CCVJD
MN39472
HBFP-0420-TR1
VO1400
KE454U2220WFP
LC82210-LA2
SIP-2290IHD-SH B1
NAND128W3A
OV161AG
vx1818
L2150
MD156
MTD2005-4101
SB2020P33372AR
STK66083
SLA7033M(LF871)
ST1151A
X9116WM8-2.7 10Kohm
NSQ03A03L
EJ630
FSA2257L10X
HN7G05FU
UDA1380HN
AD6522
LMX3268XBH
PI74ST1G32CEX GP TAP 5PIN
LC22096B-LK5
ML60851CGA
CT-48303A-B-O
1605MELD
RC1587M33T
ST1155A
MIP2E1DMUL
MC13024DW
AN13201A-NL
ZSR500CL
VPS14
A3966SLBTR-XH
AMS1503
FDW254P
UPD16805
VV5351AT001
GF4800
GBPC2506AIR
S6RM10510
MSD6100
TN1215-600C
PBYR2010OCTB
CXD9799
CXD9627n-e2
m5237ml
SE555CN
SA508
TLC556CN
OPA237NA
BH6526FV-E2
STMUX1000L
IBM36
FQD20N06LETM
TDA1308TM
TDA1308TM
TDA9321H
TDA9332H
TDA9592H
TDA9361/PS/N3/3/1598
TDA9361/PS/N3/3/1740
AN5650
UPD6125
T60403-L5002-B
MM1538xq
74CBT6800
LA4533M-TE-L-E
LM1801N
MTW355
ST5410CJIB
CD8030N
NW6003AS
CXA1484AN-T4
PQ050DN01ZP
TAS5110CIB
TSA5511AT
CXA1992AR
53C896
STB80NF03L
EZ1580CMTR
LA6510
LA7356M-TLM
AP20N03S
KSM-2003TN2EIRM
TSOP36240TT
FM-6038LM-5A
TR/3216FF2.5-R 2.5A/32V
TR/3216TD4-R 4A 32V
TR/3216TD4-R 4A 32V
minISMDC160f-2
MINISMDC050-2
MINISMDC110F
R451010
SMD1206P150TS
SMD2920P185TS
SMD2920P250TF
SMDC020F SMD
1812L160PRT
SMD035F-2 SMD
SMAJ30A-TR
GL1D
EM85447
AM3443P-T1-PF
SM6T18CA
TVM0G5R5 5.5V/30V 0.02J 4A力勤
V5.5MLA0603 5.5V 30A SMD SMA TR
SDV1005E180C150NPT顺络
VSL1005U05NR 三和
EZJZ0V80010 0402 1PF
EZJZ0V800AA 0402 3pF
ESDA6V1-4BC6
STF201-22.TCT GP TUBE
NUF6401MN
NFM21PC474R1C3D
ESD5Z5.0T1G
RClamp0502B
uclamp0505A TCT
IP4220CZ6
CM1409-08DE
PACDN04
CSPESD304G
NUP5120x6t1gL/APP?
ECS-3.327-6-17
MCI-2012-900
HCB2012KF-420T40
IP4058CX8 800MHZ 50Ω
ESDFILICVE21184E070R100 10Ω 7.5PF
IP4062CX18 COMPOSANTS
ICVE21054E250R101FR
CM1621B
T520V227M2R5ATE015
GJM1555C1H6R8BB01E
CL31A106MAHNNNE MLCC X5R 10uF 25V 1206
MLCC X5R 0.1uF 16V 20% 0402
C1608X5R105KDT X5R 1uF 10V
JMK105BJ105MV-FSMD MLCC X5R 1uF 6.3V
JMK107BJ475KA-T MLCC X5R 4.7uF 6.3V
PSLD0J337M(25)  3330uF 6.3V 20%
SMD MLCC X7R 0.1uF 50V 10% 0603
SMD MLCC X5R 0.1uF 6.3V 10% 0402
CL21A475KAQNNNE  X5R 4.7uF 25V
CL21A475KPFNNNE X5R 4.7uF 10V
HKQ0603S1N2S-T
MLK0603L22NJ
MLF1608A1ROJT
HN16022CG
HN16212CG
DO1606T-103 10UH 1A
CDRH3D18NP-330NC
CMD4D13-TAP 15UH-20%
CDRH2D11-4R7NC
CDRH2D18/LD-100MC
CDRH5D28-8R2 8.2UH
CDRH6D12-4R2NC 4.2UH-30%
CDRH6D28 GP 10UH SUM
CDRH6D28-TAP 15UH-30%
FDVE0630-H-1R5M=P3
FDVE0630-H-3R3M=P3
A916CY-3R3M=P3
#A918BY-1R2N=P3 1.2UH 30%
#A918CY-2R0M=P3  2.0UH 20%
FDU1050D-1R5M 1.5UH 20%
A920CY-100M=P3
PMD5D11-100M
TPRH6D38-330M
TR04111A
86A-6256B-R SMD
SD52-220
SILM4015H 4.7UH 30% 1.4A
SILM4015 10UH 20% 0.5A
SILM4015 47UH 20% 0.25A
SILM4015 6.8UH 30% 0.8A
SIL104R-100APF
SIL730-100APF
LYS6S38-150M
SCDS127T-150M-N
SBCB65603F-501
MSCDRI-103R-220M
MSCDRI-4D28-100N
MSCDR16-8R2M
IHLP-5050CE-01  1UH
FP10302-R47M-A01
FP10302-R10M-A01
AGPI5D12100NT 10uH 25% 0.34R
GTSD32P-3R3W
SU30220YLB
FR50320-R47M4AC1
HSW453232-2R2M
C12-7R    5.6uh
TLE1010-r25cn
HM00-04597LF
P11711.142NLT 1.4UH
PF0465.502NLT 5UH普思
PG0437.601NL 0.6UH 18A
PF0560.382NLT 3.8UH
PG0006.312NLT 3.1UH
HMU1370-5R0-R 5uh
HM66-70100LFTR13 10uh
NHL7022FR-100M
SRSQ104-5R2N CHOKE 5.2UH 30% 5.5A SRSQ104-5R2N
SRSQ104-2R2N CHOKE 2.2uH 30% 8A 0.015R 10.3*10.4
FDV1040-2R2M=P3 COIL INDUCTOR 2.2UH 20%
DTVS205ER201A
DTVS205EH201A
G6J-2FL-Y-DC4.5  SMD
BRS-1534P08
E-57S08CN
KR-292-01
DSX321G-25M-9PF
KSX-35-19500K8A-QD0R
TSX-3225-26MHZ
TAS-3225A 26mhz
TAS-3225A 40mhz
CXC6X260000GHVRB02帕特仑
NX5032SA 13.580625MHZ
H130B-40.000-8-NS2
NX5032SG 40MHZ
NX5032SG 40MHZ
9C49300012 XTAL 49.3811MHz 30ppm 12PF
LFB2H2G60BB1B973 3.5G
LFB312G45SW1A626
DFCB25G80LBHAB 5.8G
DEA165375BT-2121A1
DEA202450BT-7115JB
BP22SQ001AR3 DBF 2.4GHz
04023J0R2ABSTR Accu-P
SAFC926.4M
V1311AZ0867
EFCH1960TCA1
EFCH881MTCA1
EFCH836MTDE1
EFCH942MTCA7 5V 50Ω 942.5MHZ 100NH
EFCH1842TCA7 5V 50Ω 1842.50MHZ 15NH
B39182-B4133-U510 EPCOS
B39182-B7721-C910 1842.5MHz EPCOS
B39182-B7821-C710
B7821 942.5MHz
B7822 1842.5MHz
B39182-B7852-K410-S09
B39202-B7825-C710-S09 1960MHz
B7825 EPCOS
B7826 1960MHz
B39202-B7851-K410 EPCOS
B39371-b3677-u310 BALUN
B39941-B7820-C710 942.5
B39941-B7837-K410 EPCOS
WF755G0942PD 942MHZ
WF754G1842PD 1842MHZ
856409 1842.5M 1.5dB 2.0 CSP6
856387 942.5M 1.5dB 1.9 CSP6
FAR-F5EA-942M50-D27F 942MHZ 50Ω -30+85℃
FAR-F5EB-942M50-B28E FOR FILTER SAW 942.5MHz EGSM900  5PIN
FAR-F5EB-881M50-B28Z FOR GSM LR FILTER SAW 881.5MHz  5PIN
FAR-F5CP-836M50-D203-J
FAR-F6EA-1G8425-D2ABA 1880MHZ 50Ω -20+65℃
FAR-F6EB-1G8425-B2BG DCSband(5-pin )
FAR-F6EB-1G8425-B2BG  FOR GSM FILTER SAW 1842.5MHz GSM1800
G6KE-1G8425-Y4QG-Z    3000
SAFEB881MFM0F00R14
SAFEH942MFN0F00R002.6dB 50/150Ω SMD-10/85C
LFB182G45SG9A213
LFB182G45SG9A293
SAFED1G96FA0F00R12
SAFEH1G96FB0F00R00
TFS924B
ALA621C4
PA1575mz50J4G-15-16 1.589MHZ 15%15*4
PA1575MK4G-182-21)
GPS132N-S3-00-A21.5*15*6.5m
PA502FMG
PW3078Z
LM-T615S3-C
LM-D615S4-C
LSHS-L245WN W/8P GND PAD
HWXN304
HWXR571A
CXG1189AXR
SHS-M090TK
B30144-D1016-Q619
EFSD836MD2S2 PANASONIC FOR  SAW LTCC 836.5/881.5MHz  13PIN
GPS196N-S3-09-A
HWS466
HWS486??? SWITCH
HWS505 WLAN SWITCH
N650P-00? (NPS-650AB ??A)
CWA2-1000-10-TYS1 1000W CWA2-1000-10-TYS1 S1E COLDWATT 1KW-RL SINGLE 12V PSU
P2M-6600P ASSY 600W B001150016 ZIPPY 2U SINGLE POWER SUPPLY
MS-156NB
MHC-310
MHC-188A TACT TP
CPU775  775 cpu插座
DMM9-S240fc-1N-FC(t)DDR2 240P 1.0MM ST H14.45MM
DDR2 240P 1.0MM ST
DVI&D-SUB(2 IN 1) R/A DIP15 G/F
DVI-D DIP24 1241-440-1E4-3B GOLD3u"
DVI-D DIP24 1241-440-1EJ-3B Gold3u"
HDMI DIP19 R/A 5300-519-091-E1 GOLD
QT800121-1110SR-F
BTBM5-02005-TP21
BTBF5-02005-TPF1
BTBF5-S1005-TPF0
BTBM5-S1005-TPF0
SM-JAK06-005
5602(CON24 5602 024 000 829 SMD24PIN P=0.4 Height=1.5mm Board To Board)
QT012003-1120J-8F BTB HD SMD2*100 P=0.5MM
AEA-BTB-023-T80 BTB HD
B-C CONNECTOR DIP4 1.25mm TIN R/A L/F
B-C CONNECTOR DIP2 1.25mm TIN R/A L/F
CONN B-F 7151-E15N-00R P=1mm R/A TIN
CONN W-B SMD2  P=1.25mm R/A TIN
CONN W-B SMD3P  P=1.25mm R/A TIN
CONN SMD30 GOLD AFN300-N2G11 P-TWO
88503-4001
FC25608-AP
FPC DIP15 R/A P=1mm 5F2.2426B TIN
254001MB003G205ZR 3P P2.5 TP
SM-BAT03-003
HB-2P003S-Z000 TP
P2035-62
HB-2P003S-Z000 TP
100002PR004G216ZL
100002FR008G215ZL
SS-6446-NF-OST
3010655800 DIP8 8P8C GOLD 6U
EPJ1-5-A-T
AR-616E4-50-CON'N 4P
AR-616MS4-50/170-M3 4P4C
AR-616MS4-50/170-M3 4P4C BK
AR-616PF-4 4P4C BK
MJ-616E4-70-CON'N
KPJ2547-D6-SMT TP
TC18-013-22 BK
JACK 1*3 JR11030(Y/W/R) R/A DIP6/F
JACK 2*2-1 R/A 5105-855-272-C6 DIP5
RCA JACK 2*2-1 DIP5 5J1.2411E-14466.203
Ph.Jack 5J1.2C11F-21126.104 DIP5 (Black)
JACK 5102-E6R-022-52 DIP5F
JACK R/A DIP9 5104-002-323-61
R7235-BNDT 高频插座
TNC-800T  高频头连接器
Ph.Jack 5102-B4R-022-52 DIP5(Black) TK
Jack 5102-B6R-022-52 DIP5(Lime)
2DC-0005D100 DC POWER JACK D=2mm
sm-jak06-001
CONN SMD5 R/A WAFER P=1.0mm TIN ARC
CONN DIP16 R/A 5W1.2521B-11400.116 TIN
CONN FEMALE R/A DIP8P P=2.54mm G/F ARC
CONN FEMALE R/A DIP8P P=2.54mm Brass
CONN DIP16 R/A P=1mm 7101-E16N-00C TIN
CONN DIP16 FEMALE P=2.54mm R/A G/F L/F
CONN USB B TYPE DIP4 BLACK R/A GOLD
CONN USB B TYPE DIP4F 30U GOLD ARC
10031567-001CLF ASRECEPTACLESMD29P30UGOLDCAP
10029065-001CLF ATARECEPTACLE22PSMTGOLD
SASF3112672TR ASRECEPTACLE29PP=1.27MM15UAU
SATA-111-0165-2 ATA7+15PSMTRECEPTACLE15uAU
SASF313-018-1-C ASRECEPTACLESMT29P0.76UM
WKUB1015-011
CHS-08TB(20)
SKRKAHE010
HEAT SINK 28*28*7.9MM散热片
Heat Sink 28*28*7.9mm散热片
HEAT SINK 7.5*7.5 mm散热片
Cable Assy 2*4P L8 76mmLIPS AD数据线
GPS129N-N3-00-A
LS20023
GPD14B01
CST-DT60A-IM
ISDB-T TM001
MA820
LBMA465DG3-125
DFBM-CS320-FI1R 50Ω INTERFACE USB  DELTA FOR
QBTM300-01V
Wireless 3945ABG-MoW 2
4965AGNMM1GN
MP-RC102BULK/809
MD560(B)
WM3B2915ABGEU
WMP-G09
WS-NP7256-I 模块IEEE 802.16d+ OFDM PHY
LR802UWG-1A2
SSK-ALLIN1-0533
QBTM300-01V
QBTM400
DMD2022IN
WLG-1801
WM3236AQ
APM6828
BTTM46C2SA
SWL-2455C/S
WLAN6064EBC3-HL MODULE
GC8601
LC6311+
MCIMX357DJQ5C
BA3842F
TA8493AF
NT68521AXF
DA82562EM
SAA7185
RG82845E
RG82845G
RG82845GV
AD8091ART-REEL7
2SC5065-Y
A276308-70
MAX3160C
ST93CS46M1
TL431C
LM1877N-9
16410BA(4UC-51-IF5B)
PCD50953H/E82
2N5064
ADD8704ARUZ
RTQ035P02
BAV99TA
BJ8P156AP
SJ2313L
RFCMF3216090M1T 1206
XTAL 32.768KHZ 20PPM 6PF ECX-306
MM1615A
NC7S08M5X
NJM2125F
BAW56-7-F
AO8822
MSQA6V1W5T2
LB1233M-TLM-E
74HC4066PW
02L1537(IBM)
PM49FL004T-33JCE 512k
AO6408L
AO3411
TDA7448
MA3X15800L
2N7002VA-7
NH82801GR/SL8FY
JG82852GME/SL8D7
TL16C550DIRHB
MAX1683EUK-T
MAX1683EUK+T
DS1810R-10
IDTQS3VH126Q
SCH5017-NW
ISL6307CRZ
ICS932S401EGLF-T
ICS9DB108AGLFT
OTI002168IT-G-B6
ICS952601EFT
ISL6565BCRZ
ISL6605CRZ
NC7S86P5X
PCA9515ADP
NC7SZ384P5X
PI5A127UX
HIP6521CBZ
DS1813R-15
IRFR3707Z
IRFR3709Z
AO4824
CEB6030L
MBRA210LT3G
SW300
MTV512GMV
RTD2523
BJ8P156AP
fm-2138sc-5cn
SI2319DS-T1
SI3433DV
CAT24C16WI-GT3
L1117D-ADJ
at24c16an-10si-2.7
lqc3225f-1r0ma-a01
lqh43mn220k03l
XC6201P302MR
XC6404FV12MR
DTC115EUA
BAS16E6327
NT68523XFG
UPD61521
RF3140
vou1810f28twc
2sd1898
rb425d
pap1301bm
R5323Z027B-TR-FD
UC3845AD8TR
RTD2523
IT8213F/AX-L
LC4064V-75T44
PEF4268T-V1.2
HT46R22
HT46R12
HT48R062
HT48R06A-1
HT48R06
HT82V736
HT45R04E
IHT935
16C550
SPLC780D-001B-C
PM49FL002T-33JCF
FM1182E-GE
BD8211EFV-E2
MC68B09CP
MC68302FC25
T6TN2XBG-0004
CXA3562AR
RJ21V3BBOET
RJ23T3BA1FT
LM4990ITLX/NOPB
1ps79sb30
IR3Y29B
CY7C1009B-20VCT
TPS72518DCQR
vou1810f28twc
2sd1898
rb425d
RF3110TR13
LTC4006EGN-6#TRPBF
MAX211ECAI+
XC9116B02AMR
SAFSD1G84FA0T00R12
W9812G6IH-75
STAC9227X5
S29AL032D70TFI030
B39182-B7852K410-S09
RF3166
MT6305BN
AT1453BP_PBF
SFECF10M7FA00-R0
SSM6N16FE(TE85L.F)
UPG2012TB-E3-A
QT1080-ISG
BP22SQ001AR3
LTC1844ES5-3.3#TR
PEF4268T-V1.2
BAS16E6327
G920CT24U
TS5A23159RSER
ATR0610-PQQ
TWL3025BZGMR
TRF6151CRHJR
D751992AZHH
WT6702F
Glamo3362
AAT1275IRN-5.0-T1
SM8121AH
VSN1005X09NR151
LMG003S-5101A
HWXP641-1 TB1208
DS2119ME+T&R
RU82566DC
SSX35BCB
R5531V002-E2-FA
LMC6032IMX
AK2001
LM63DIMAX
HYB25DC512160CE-5
P89LPC932A1FDH
STTS75M2F
SPX1004AM1-L-1.2
TPS3801K33DCKR
MX3000CS
04023J0R2ABSTR
GRM1555C1H101JD01E
AUO-003K6
NX5032SG 40MHZ
S29AL032D70TFI04
ADSP-21062CS-160
CXG1189AXR-T9
USB3316B-GJ-TR
LFB312G45SW1A626
FI-RE41S-HF-R1500?
G6J-2FL-Y-TR?
LT3481EDD#TRPBF
0451003.MRL
SAWEN1G84CB0F00R12
AAT3169IFO-T1
AAT3151BIWP-T1
SC32442B43-7081
CVGB260A 26.000MHZ
SLDA52-2R710G-S1 ?
SLDA52-2R540G-S1?
UH7843Q
SFR881PY001
EL2244CSZ
P89LPC932A1FDH
UH7843Q
SLDA52-2R710G-S1
SLDA52-2R540G-S1
RTL8201CL
FCX-05 26.00MHZ
PIC18F63J90-I/PT
S-8261AAJMD-G2JT2G
AAT3169IFO-T1
AAT3151BIWP-T1
SAWEN1G84CB0F00R12
SFR881PY001
FDC604-NL
EL2244CSZ
04023J0R2ABSTR
G6J-2FL-Y-DC4.5
LTC1733EMSE#TRPBF
PIC18F63J90-I/PT
NX5032SG/40MHZ/10PPM/8PF
AUO-003K6
CT8930-SAS
IP178C
SIL9030CTU
CT1975-SAM
MAX1771CSA+T
CY62256LL
MC13191FC
TPA3100D2RGZR
88SE6101-NNC1
88SE6145-TFE1
STAC9271X5T48E-CA2
R5323Z027B-TR-FD
MC9328MXS
TMS320DA255ZHH
LT3481EDD#TRPBF
PI2PCIE412-CZHEX
PC82562V
VT6210L
PCM2705DBR
UC3845AD8TR
LC126A
RTD2523
IT8213F/AX-L
PIC16LF88-I
PMB2520
PM30CTJ060
LR645N5
PM6650
PM6680 LINE
PMB6812V1.62
L4973V5
L5991D013TR-2
L9826
VNQ830
USBUF01W6
TSH70CLT
CAT3604HS4-TE13
CAT7581CA
SC464AYB
SC434623CDWR2
SC406256CDWR2
MC145017P
MC14467
MC14468
MC145167P
MC33078DR2
MC3335P
MC34164P-003
TS5V330DBQ VIDEO SW  TI
TPS105124
TPS2216DBR
TPS2211AIDB
TPS3801K33DCKR
TPS61010DGSR
TPS62200DBVR
TPS62208DBVR
TPS7148QDR
TPS78601DCQR
TPS71918-12DRVR
SN105124DGSR
TL2845-33M
TL38C43
TL7705ACDR
TLV2217-33K
TLV5535PW
BQ2057CTSTRG4
BQ24022DRCR
BQ24022DRCR
MM1615A
mm3177fnre
MB3769A
MB3776A
MB3800PFV
MB3878pfv-g-bnd-er
MB3887FV-G-BND-ER
FA13843N-TE1
FA5501AN-TE1
FA5502M
R1110N251A-TR
R114Q181D-TR-FA
R3111N271
R3111N201A-TR
R5426N108CA-TR-FA
R5531V 260'C
R5426N120CA-TR-F
RV5C386A
RN5VL28AA-TR
RN5VT111AA-TL
RN5VT10CA-TR
RN5VD40AA-TR-F
RS5RM4018
RH5RE40AA-F
RH5VL23CA-T1
S-1167B33-16T2G
S-80736SN-D0-T1
S-80828ANNP
S-80830SN-DT
S-80833cnmc-b8s-t2
S-80835AMNP
S-80836CNMC-B8V-T2G
S-80922CNMC-G8S-T2
S-80923CNMC-GBTT2G
S-81112B32MC-L6R-TB
S-81215SG
S-81216SGUP-DQP-T16K
S-81224sgup-dqx-t1
S-81235SG-QI-T1
S-81333HG-KF-T1
S-814A33AMC-BCX-T2
S-8261ABRMD
S-8323C27MA
S-8328B33me
S-8333ACBC-T8T1GF
S-8333ACBC-T8T1GF
s-8354a27mc-jqmt2g
S-8520B18MC
S-190V13
ADP1653ACPZ-R7
ADP3120JRZ PWM
ADP3121JCPZ-RL
ADP3168JRUZ-REEL
ADP3188JRUZ
ADP3207A0091CPZA
ADP3208JCPZ-RL
ADP3209JCPZ-RL
ADP3611JRMZ-R
ADP3806JRUZ-12.5-R7
HIP6012CB PWM CTL
HIP6302C6Z-T
HIP6521CBZ
TLE6263
LT1004LS8-1.2-T1
LT1009CE
LT1304cs8-3.3v#tr
LTC130433
LT1117CST#PBF
LTC1693-1IS8#TRPBF
LTC1844ES5-3.3#/tr
LT1725CGN
LTC1733EMSE#TRPBF
LTC1772BES6#TR
LTC1923EUH#TRPBF
LT1931ES5
LTC30433
LTC3406ES5#PBF
LTC3406ES5#PBF
LTC3417EDHC#TRPBF
LTC3417AEFE
LT3467ES6#TRPBF
LTC3713EG#TRPBF
LTC3727EG-1
LTC4006EGN-6#TRPBF
LTC4055EUF
LTC4211CMS#TRPBF
MAX548
MAX693ACWE
MAX810
MAX1115EKA
MAX1505XETM+T
max1508ETA+T
MAX1543ETP
MAX1565E
MAX1683EUK-T
MAX1683EUK+T
MAX1686EUK-T
MAX1801 2.7V
MAX1858EEG+T
MAX1904EA1-TG074
MAX4614csd
MAX4614CUD
MAX4889ETO+
MAX6328UR26
MAX6423XS16
MAX8561ETA+T
MAX8728ETJ+
MAX8761ETG+
LM2575T-5
LM2612ABPXNS
LM2664
ISP1105W
TL2336ML
ST7533-0D-G
ZJYS51R5-M4PAT-01
TSOP34856
CY62256LL-70ZXC
LM5642MTC
AD8356A-KG
NJM2058V(TE1)
M30624MGP-332GP
UPD703249YGC-123-8EA
LC723781N-9D22
BA7654F-E2
BA6920FP-Y
YELQ10S680M
AN2546FH-A
CS51412EDR8
S29AL008D70TFI02
ADP2108ACBZ-1.5-R7
SKY13276-334
FHW0805UC4N7KGT
CM2545X171R-10
SP3238EEA
MAX8727ETB+T
SIP-2290HD
ML414R-TT40A-TP1
SN65HVD3082EDR
RT9939GQW
TMS320DM5012DZANR
EFC4612R-TR
LM NR8040T470M
NJU7391V(TE2)
LTC3780EG#PBF
LT1399CS#TRPBF
LT6557CGN#TRPBF
SII9025CTU
OTI006888G-A9
SFHG60MQ102
NFP-2050-A3
BCM5704CKRB-P13
QG80003ESA QJ89ES
FW82443BX SL2VH
UPA807T-T1-A
HYB25DC512160CE-5
CC0805MKX5R5BB106
ICS853014BGLFT
ICS8634BY-01LFT
TPS54010PWPR
ADM1026JSTZ-REEL
ADM1191-2ARMZ-R7
LTC4352CDD#TRPBF
TPS5420DR
PS8321QFN56GTR
M25P128-VMF6TP
PCA9546APW
ADP3186JRUZ-REEL
GRM31CR70J106MA13F
INA213AIDCKT
PI3VDP411LSTZDE
CY8C21334-24PVXI
LM96163CISD
RTL8211B-GR
ISL6539CAZ
88PG8227
ADM3202ARUZ-REEL
SP3243ECA-L/TR
SN75LVCP412RTJR
PCA9557PWR
SST25VF016B-75-4I-S2AF
BSC079N03SG
BSC057N03LS G
LM95232CIMM NOPB
EMC1023-1-ACZL-TR
LT1963AES8-1.8#TRPBF
LT1054CDWR
TPS73601DBVR
ISL6614CRZ-T
MX25L2005MC-12G
10YXG220M6.3X11
IT8718F-S/HX-L
ADP3120AJRZ
AT24C04N-10SU-2.7
AT24C08BN-SH-T
ISL6612CBZA
FAN5009MX_NM2C206
NTD110N02R-001G
TPS2064DGN
M470T5663EH3-CF7
DV28EVV3
DV-28E-N93
STD90N02L
M470T2864QZ3-CF7
UJ875ABNC6-C
FDS6900AS
HYMP112S64CP6-S6
SSY2128M8-J6E
UJ880ADNC6-B
个人签名:深圳市洪源电子有限公司 http://szhongyuandz.cn.alibaba.com 0755-83651607 罗智
