[嵌入式linux] 急!!Android_Linux_Kernel_2_6_32移植出现问题!!平台是DM37x
2400|1
 楼主| 289746999 发表于 2011-3-15 12:07 | 显示全部楼层 |阅读模式
在终端打印出来的信息:::
Warning: unable to open an initial console.
init: cannot open '/init**.rle'
CMEMK module: built on Jan 20 2011 at 16:49:53
  Reference Linux version 2.6.32
  File /build/a0271908/rowboat-froyo/external/ti-dsp/ti-dvsdk_dm3730-evm_4_01_00
_09/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
CMEM Range Overlaps Kernel Physical - allowing overlap
CMEM phys_start (0x84700000) overlaps kernel (0x80000000 -> 0x8c700000)
allocated heap buffer 0xd1000000 of size 0x1200000
heap fallback enabled - will try heap if pool buffer is not available
cmemk initialized
DSPLINK Module (1.65.00.02) created on Date: Jan 21 2011 Time: 00:44:39
SDMAK module: built on Jan 20 2011 at 16:49:55
_09/linuxutils_2_25_05_11/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
 楼主| 289746999 发表于 2011-3-15 12:22 | 显示全部楼层
自己顶下
