请帮忙字模索引
2842|1
 楼主| yxxcf 发表于 2011-3-19 23:11 | 显示全部楼层 |阅读模式
// ------------------  汉字字模的数据结构定义 ------------------------ //
typedef struct typFNT_GB16                 // 汉字字模数据结构
       signed char Index[2];               // 汉字内码索引
       char Msk[32];                       // 点阵码数据
// 汉字字模表                                                          //
// 汉字库: 宋体16.dot 纵向取模下高位,数据排列:从左到右从上到下         //
struct typFNT_GB16 code GB_16[] =          // 数据表
"中", 0x00,0xF8,0x08,0x08,0x08,0x08,0x08,0xFF,
      0x08,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,
      0x00,0x03,0x01,0x01,0x01,0x01,0x01,0xFF,
      0x01,0x01,0x01,0x01,0x01,0x03,0x00,0x00,
"华", 0x00,0x40,0x20,0x10,0xFC,0x03,0x40,0x20,
      0x10,0xFF,0x08,0x04,0x06,0xC0,0x00,0x00,
      0x04,0x04,0x04,0x04,0x05,0x04,0x04,0xFF,
      0x04,0x04,0x05,0x05,0x05,0x05,0x04,0x00,
"人", 0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x7F,
      0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,
      0x03,0x0C,0x10,0x20,0x40,0xC0,0x40,0x00,
"民", 0x00,0xFE,0x22,0x22,0x22,0x22,0xE2,0x22,
      0x22,0x22,0x22,0x3F,0x82,0x00,0x00,0x00,
      0x00,0xFF,0x41,0x21,0x11,0x01,0x03,0x0D,
      0x11,0x21,0x41,0x41,0x81,0x81,0xE0,0x00,
"共", 0x00,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,
      0x10,0x10,0xFF,0x10,0x18,0x10,0x00,0x00,
      0x04,0x04,0x84,0x44,0x27,0x34,0x04,0x04,
      0x04,0x14,0x27,0x64,0xC4,0x06,0x04,0x00,
"和", 0x20,0x24,0x24,0xA4,0xFC,0x22,0x33,0x22,
      0xF0,0x10,0x10,0x10,0x10,0xF8,0x10,0x00,
      0x10,0x08,0x06,0x01,0xFF,0x01,0x06,0x00,
      0x3F,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,
"国", 0x00,0xFE,0x02,0x0A,0x8A,0x8A,0x8A,0xFA,
      0x8A,0xCA,0x8E,0x0A,0x02,0xFF,0x02,0x00,
      0x00,0xFF,0x40,0x50,0x50,0x50,0x50,0x5F,
      0x50,0x52,0x54,0x50,0x40,0xFF,0x00,0x00
例:uchar code s1[]="共和国";
液晶字模如上,请问:
如何利用内码索引确认字符串中每个字在字模表中的位置?
airwill 发表于 2011-3-20 07:34 | 显示全部楼层
这个简单, 做过索引表嘛.
比如:
    uint code table[]={};  // 依次填入所有汉字的内码.
然后, 要找字模的时候, 根据汉字内码到这个表里搜索到它的位置, 也就知道在字模表的位置了.
当然, 如果想搜索得快些, 可以把 "中华人民共和国"重新排序后再建字模表和对应的汉字内码表. 然后可以用二分法来查找了.
