[STM8] IAR STM8 1.2 直接使用__eeprom关键字访问EEPROM
8225|4
 楼主| CC2530 发表于 2011-3-21 22:41 | 显示全部楼层 |阅读模式
STM8L15X:
#include "stm8l15x_conf.h"
void __eeprom_write_8(unsigned short addr_eep,unsigned char data)
  FLASH_WaitForLastOperation(FLASH_MemType_Data);
  FLASH_Unlock(FLASH_MemType_Data);
  FLASH_ProgramByte(addr_eep, data);
  FLASH_Lock(FLASH_MemType_Data);
void __eeprom_write_16(unsigned short addr_eep,unsigned short data)
  FLASH_ProgramByte(addr_eep,   data/256);
  FLASH_ProgramByte(addr_eep+1, data%256);
void __eeprom_write_32(unsigned short addr_eep,unsigned long data)
  FLASH_ProgramByte(addr_eep,   (unsigned char)(data>>24));
  FLASH_ProgramByte(addr_eep+1, (unsigned char)(data>>16));
  FLASH_ProgramByte(addr_eep+2,   (unsigned char)(data>>8));
  FLASH_ProgramByte(addr_eep+3, (unsigned char)(data>>0));
void __eeprom_write_many(unsigned short addr_eep,unsigned short size,unsigned short dummy,unsigned short addr_ram)
  for(unsigned short i=0;i<size;i++)
     FLASH_ProgramByte(addr_eep+i,   *((unsigned char *)(addr_ram)+i));
STM8S:
#include "stm8s_conf.h"
  FLASH_WaitForLastOperation(FLASH_MEMTYPE_DATA);
  FLASH_Unlock(FLASH_MEMTYPE_DATA);
  FLASH_Lock(FLASH_MEMTYPE_DATA);
主程序测试:
volatile __eeprom __no_init char  eep_u8;
volatile __eeprom __no_init short eep_u16;
volatile __eeprom __no_init long  eep_u32;
void main( void )
  eep_u8=123;
  eep_u16=12345;
  eep_u32=123456789;
  while(1);
seawwh 发表于 2011-3-24 11:51 | 显示全部楼层
我目前在使用 STM8L101, 你提供的办法可以用在STM8L101 ?
我试验了一下发现一个错误:
Error[Lc36]: no block or place matches the pattern "zi section .eeprom.noinit in Main.o"
 楼主| CC2530 发表于 2011-3-24 11:55 | 显示全部楼层
STM8L101 没有EEPROM
seawwh 发表于 2011-3-24 12:18 | 显示全部楼层
我使用的是 STM8L101F3P6 ,Flash应该是8K,根据手册应该有EEPROM,在0x9800
看下面的表述(RM0013),其中有些矛盾:TSSOP20 4.4 x 6.4封装的STM8L101F3P6 到底有没有EEPROM ?
gegegegeda 发表于 2013-2-14 15:22 | 显示全部楼层
马克,以后用
