[STM8] STM32输出PWM波 遇到一些问题
1541|11
 楼主| zhanghqi 发表于 2017-9-26 22:38 | 显示全部楼层 |阅读模式
STM32输出PWM波 遇到一些问题
zhenykun 发表于 2017-9-26 22:40 | 显示全部楼层
楼主详细说说怎么回事啊,这么说太笼统了
 楼主| zhanghqi 发表于 2017-9-26 22:42 | 显示全部楼层
用Tim3输出PWM波。 使用PA6、PA7、PB0、PB1。能够发出占空比不同的方波。
wyjie 发表于 2017-9-26 22:44 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| zhanghqi 发表于 2017-9-26 22:45 | 显示全部楼层
代码如下:
void TIM3_PWM_Init(void)
        GPIO_InitTypeDef         GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef        TIM_OCInitStructure;
//        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3|RCC_APB2Periph_GPIOA, ENABLE); //使能TIM3时钟,GPIOA时钟
        RCC_APB1PeriphClockCmd (RCC_APB1Periph_TIM3,ENABLE);
        RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*GPIOB Configuration: TIM3 channel 3 and 4 as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period = 999;
    TIM_TimeBaseStructure.TIM_Prescaler = 0;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 750;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = 500;
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = 250;
  TIM_OC3Init(TIM3, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = 100;
  TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
jlyuan 发表于 2017-9-26 22:47 | 显示全部楼层
什么意思?不是很明白你说的什么,能再解释一下这个现象吗
 楼主| zhanghqi 发表于 2017-9-26 22:48 | 显示全部楼层
使用其他IO口,比如PA4、PA5或者PB6、PB7,在IO口处检测不到方波.
yszong 发表于 2017-9-26 22:50 | 显示全部楼层
有杂波和程序没啥关系的
dengdc 发表于 2017-9-26 22:52 | 显示全部楼层
使用其他定时器,比如Tim2,就检测不到方波。
 楼主| zhanghqi 发表于 2017-9-26 22:53 | 显示全部楼层
搞定了,呵呵,犯了低级错误……结贴啦,多谢各位
Garen2 发表于 2017-9-28 16:20 | 显示全部楼层
什么错误,是不是其他IO不能输出方波?
 楼主| zhanghqi 发表于 2019-1-4 18:45 | 显示全部楼层
int main(void)
        u32 i;
        u32 uwErrorIndex=0;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_BKPSRAM,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);
        PWR_BackupAccessCmd(ENABLE);
        PWR_BackupRegulatorCmd(ENABLE);
        while(PWR_GetFlagStatus(PWR_FLAG_BRR) == RESET);
//         for(i = 0; i < 4096; i+=4)
//                 *(__IO uint32_t *) (BKPSRAM_BASE+i) = i;
                for (i=0; i< 4096; i+= 4)
    if ((*(__IO uint32_t *) (BKPSRAM_BASE + i)) != i)
      uwErrorIndex++;
