算法——纯C语言最小二乘法曲线拟合
1358|2
 楼主| Peonys 发表于 2017-10-2 16:09 | 显示全部楼层 |阅读模式
算法——纯C语言最小二乘法曲线拟合
写完,还没来得及写注释,已通过Matlab的polyfit验证(阶数高或者数据量太大会有double数据溢出的危险,低阶的都吻合),时间有点紧,程序注释,数学推导等时间充裕一点再贴上来
// 最小二乘法拟合.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "stdlib.h"
#include "math.h"
#define ParaBuffer(Buffer,Row,Col) (*(Buffer + (Row) * (SizeSrc + 1) + (Col)))
static int GetXY(const char* FileName, double* X, double* Y, int* Amount)
        FILE* File = fopen(FileName, "r");
        if (!File)
                return -1;
        for (*Amount = 0; !feof(File); X++, Y++, (*Amount)++)
                if (2 != fscanf(File, (const char*)"%lf %lf", X, Y))
                        break;
        fclose(File);
        return 0;
static int PrintPara(double* Para, int SizeSrc)
        int i, j;
        for (i = 0; i < SizeSrc; i++)
                for (j = 0; j <= SizeSrc; j++)
                        printf("%10.6lf ", ParaBuffer(Para, i, j));
                printf("\r\n");
        printf("\r\n");
        return 0;
static int ParalimitRow(double* Para, int SizeSrc, int Row)
        int i;
        double Max, Min, Temp;
        for (Max = abs(ParaBuffer(Para, Row, 0)), Min = Max, i = SizeSrc; i; i--)
                Temp = abs(ParaBuffer(Para, Row, i));
                if (Max < Temp)
                        Max = Temp;
                if (Min > Temp)
                        Min = Temp;
        Max = (Max + Min) * 0.000005;
        for (i = SizeSrc; i >= 0; i--)
                ParaBuffer(Para, Row, i) /= Max;
        return 0;
static int Paralimit(double* Para, int SizeSrc)
        int i;
                if (ParalimitRow(Para, SizeSrc, i))
                        return -1;
        return 0;
static int ParaPreDealA(double* Para, int SizeSrc, int Size)
        int i, j;
        for (Size -= 1, i = 0; i < Size; i++)
                for (j = 0; j < Size; j++)
                        ParaBuffer(Para, i, j) = ParaBuffer(Para, i, j) * ParaBuffer(Para, Size, Size) - ParaBuffer(Para, Size, j) * ParaBuffer(Para, i, Size);
                ParaBuffer(Para, i, SizeSrc) = ParaBuffer(Para, i, SizeSrc) * ParaBuffer(Para, Size, Size) - ParaBuffer(Para, Size, SizeSrc) * ParaBuffer(Para, i, Size);
                ParaBuffer(Para, i, Size) = 0;
                ParalimitRow(Para, SizeSrc, i);
        return 0;
static int ParaDealA(double* Para, int SizeSrc)
        int i;
        for (i = SizeSrc; i; i--)
                if (ParaPreDealA(Para, SizeSrc, i))
                        return -1;
        return 0;
static int ParaPreDealB(double* Para, int SizeSrc, int OffSet)
        int i, j;
        for (i = OffSet + 1; i < SizeSrc; i++)
                for (j = OffSet + 1; j <= i; j++)
                        ParaBuffer(Para, i, j) *= ParaBuffer(Para, OffSet, OffSet);
                ParaBuffer(Para, i, SizeSrc) = ParaBuffer(Para, i, SizeSrc) * ParaBuffer(Para, OffSet, OffSet) - ParaBuffer(Para, i, OffSet) * ParaBuffer(Para, OffSet, SizeSrc);
                ParaBuffer(Para, i, OffSet) = 0;
        return 0;
static int ParaDealB(double* Para, int SizeSrc)
        int i;
                if (ParaPreDealB(Para, SizeSrc, i))
                        return -1;
                if (ParaBuffer(Para, i, i))
                        ParaBuffer(Para, i, SizeSrc) /= ParaBuffer(Para, i, i);
                        ParaBuffer(Para, i, i) = 1.0;
        return 0;
static int ParaDeal(double* Para, int SizeSrc)
        PrintPara(Para, SizeSrc);
        Paralimit(Para, SizeSrc);
        if (ParaDealA(Para, SizeSrc))
                return -1;
        if (ParaDealB(Para, SizeSrc))
                return -1;
        return 0;
static int GetParaBuffer(double* Para, const double* X, const double* Y, int Amount, int SizeSrc)
        int i, j;
                for (ParaBuffer(Para, 0, i) = 0, j = 0; j < Amount; j++)
                        ParaBuffer(Para, 0, i) += pow(*(X + j), 2 * (SizeSrc - 1) - i);
        for (i = 1; i < SizeSrc; i++)
                for (ParaBuffer(Para, i, SizeSrc - 1) = 0, j = 0; j < Amount; j++)
                        ParaBuffer(Para, i, SizeSrc - 1) += pow(*(X + j), SizeSrc - 1 - i);
                for (ParaBuffer(Para, i, SizeSrc) = 0, j = 0; j < Amount; j++)
                        ParaBuffer(Para, i, SizeSrc) += (*(Y + j)) * pow(*(X + j), SizeSrc - 1 - i);
                for (j = 0; j < SizeSrc - 1; j++)
                        ParaBuffer(Para, i, j) = ParaBuffer(Para, i - 1, j + 1);
        return 0;
int Cal(const double* BufferX, const double* BufferY, int Amount, int SizeSrc, double* ParaResK)
        double* ParaK = (double*)malloc(SizeSrc * (SizeSrc + 1) * sizeof(double));
        GetParaBuffer(ParaK, BufferX, BufferY, Amount, SizeSrc);
        ParaDeal(ParaK, SizeSrc);
        for (Amount = 0; Amount < SizeSrc; Amount++, ParaResK++)
                *ParaResK = ParaBuffer(ParaK, Amount, SizeSrc);
        free(ParaK);
        return 0;
int main(int argc, char* argv[])
        int Amount;
        double BufferX[1024], BufferY[1024], ParaK[6];
        if (GetXY((const char*)"test.txt", (double*)BufferX, (double*)BufferY, &Amount))
                return 0;
        Cal((const double*)BufferX, (const double*)BufferY, Amount, sizeof(ParaK) / sizeof(double), (double*)ParaK);
        for (Amount = 0; Amount < sizeof(ParaK) / sizeof(double); Amount++)
                printf("ParaK[%d] = %lf!\r\n", Amount, ParaK[Amount]);
        return 0;
测试test.txt里的内容
      0.995119      -7.620000
      2.001185      -2.460000
      2.999068     108.760000
      4.001035     625.020000
      4.999859    2170.500000
      6.004461    5814.580000
      6.999335   13191.840000
      7.999433   26622.060000
      9.002257   49230.220000
     10.003888   85066.500000
     11.004076  139226.280000
     12.001602  217970.140000
     13.003390  328843.860000
     14.001623  480798.420000
     15.003034  684310.000000
     16.002561  951499.980000
     17.003010 1296254.940000
     18.003897 1734346.660000
     19.002563 2283552.120000
     20.003530 2963773.500000
matlab拟合m代码:
load test.txt;
x = test(:, 1)';
y = test(:, 2)';
para = polyfit(x, y, 5);
xietingfeng 发表于 2017-10-2 22:51 | 显示全部楼层
仿真结果有图像吗?
xietingfeng 发表于 2017-10-2 22:53 | 显示全部楼层
这个跟线性拟合有什么不同吗?
