[STM32L4] rtc时间精度的问题
5004|16
 楼主| pegion1001 发表于 2017-10-11 15:28 | 显示全部楼层 |阅读模式
先上代码:
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_RTC_Init();
  MX_USART1_UART_Init();
  /* Initialize interrupts */
  MX_NVIC_Init();
gUSER_SendSec_Index = 0x00;
  /* USER CODE BEGIN 2 */
__HAL_UART_CLEAR_IDLEFLAG(&huart1);
__HAL_UART_ENABLE_IT(&huart1, UART_IT_IDLE);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  if(gUSER_SendSec_Index == 0x01)
   USER_BackInfo();
  USER_Uart_DmaRecv();
  /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
//RTC配置
static void MX_RTC_Init(void)
  RTC_TimeTypeDef sTime;
  RTC_DateTypeDef sDate;
    /**Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 0;
  hrtc.Init.SynchPrediv = 31999;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
    /**Initialize RTC and set the Time and Date
  if(HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR0) != 0x32F2){
  sTime.Hours = 0x0;
  sTime.Minutes = 0x0;
  sTime.Seconds = 0x0;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 0x1;
  sDate.Year = 0x0;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    HAL_RTCEx_BKUPWrite(&hrtc,RTC_BKP_DR0,0x32F2);
    /**Enable the WakeUp
  if (HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 0, RTC_WAKEUPCLOCK_RTCCLK_DIV16) != HAL_OK)
void HAL_RTCEx_WakeUpTimerEventCallback(RTC_HandleTypeDef *hrtc1)
gUSER_SendSec_Index = 0x01;
HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 0, RTC_WAKEUPCLOCK_CK_SPRE_16BITS);
//通过串口发送至PC机显示时间
void USER_BackInfo(void)
gUARTSendBuff[0] = '$';
gUARTSendBuff[1] = 'I';
gUARTSendBuff[2] = 'N';
gUARTSendBuff[3] = 'F';
gUARTSendBuff[4] = 'O';
gUARTSendBuff[5] = 0x00;
gUARTSendBuff[6] = 0x0E;
gUARTSendBuff[7] = ID;
gUARTTx_Len = 14;
HAL_RTC_GetTime(&hrtc, &sTime, RTC_FORMAT_BIN);
  HAL_RTC_GetDate(&hrtc, &sDate, RTC_FORMAT_BIN);
gUARTSendBuff[8] = sDate.Year;
gUARTSendBuff[9] = sDate.Month;
gUARTSendBuff[10] = sDate.Date;
gUARTSendBuff[11] = sTime.Hours;
gUARTSendBuff[12] = sTime.Minutes;
gUARTSendBuff[13] = sTime.Seconds;
USER_Uart_DataSend();
在PC机上同时显示PC机时间和通过串口收到的时间,才过了3个小时就差了30秒,这个精度很低呀,是我哪里没弄对么?
airwill 发表于 2017-10-11 17:27 | 显示全部楼层
RTC 时间的精度确实不是很高. 而这个偏差其实并不来源于 STM32.
而往往是 晶振的频率精度不高.
为此, STM32 后来增加了校准功能来进行修正, 办法是若干次周期后增删一个脉冲(调整计数器).
楼主想得到高精度计时, 除了改用高精度晶振, 还可以用好这个校准功能
htmlme 发表于 2017-10-11 18:35 | 显示全部楼层
使用外部的RTC电路。
pklong 发表于 2017-10-11 18:36 | 显示全部楼层
是不是外部的晶振有问题?
touser 发表于 2017-10-11 18:37 | 显示全部楼层
是串口发送的数据有问题吗?
htmlme 发表于 2017-10-11 18:41 | 显示全部楼层
使用DS12884试试。
pklong 发表于 2017-10-11 18:41 | 显示全部楼层
是32K的外部晶振吗
touser 发表于 2017-10-11 18:41 | 显示全部楼层
是对比的时间开始设置的一致吗?
gujiamao12345 发表于 2017-10-12 10:43 | 显示全部楼层
ds3231
试试
 楼主| pegion1001 发表于 2017-10-12 11:02 | 显示全部楼层
换成外部晶振了,目前跑了2个小时了,还是挺准的
东方教主 发表于 2017-10-12 11:16 | 显示全部楼层
计算都有问题,手册上说内部低速RC时钟40Khz,实际会在30-60Khz左右
Mattheww 发表于 2017-10-15 16:32 | 显示全部楼层
串口发送的数据有问题吗?
cirio2009 发表于 2017-10-16 05:25 | 显示全部楼层
建议用外置时钟,精度高点的,内置的不是很准
Richardd 发表于 2017-10-19 17:37 | 显示全部楼层
用高精度晶振,有源晶振
huangcunxiake 发表于 2017-10-19 21:35 | 显示全部楼层
对,有源晶振比较好,比无源晶振精度高,而且不会出现停振这种事情。
Rangar 发表于 2017-10-20 10:57 | 显示全部楼层
是不是时钟的问题,外部时钟精度高,怎么不用呢
拉克丝 发表于 2017-10-25 17:21 | 显示全部楼层
用校准功能来进行修正
