[STM32F4] f407zg 外部晶振起振问题
1315|6
 楼主| happytong 发表于 2017-10-11 18:55 | 显示全部楼层 |阅读模式
个位大侠 弱弱的问一下,STM32F407ZG 外部晶振是要程序启动还是MCU上电即可起振(MCU没有写任何程序),在线等
sky.sun.zz 发表于 2017-10-11 19:00 | 显示全部楼层
 楼主| happytong 发表于 2017-10-11 19:02 | 显示全部楼层
你当然要配置STM32F407ZG在 外部晶振模式了。
意思是还是要在程序中启动 外部晶振才能起振?
sky.sun.zz 发表于 2017-10-11 19:06 | 显示全部楼层
请参考2楼图片
sky.sun.zz 发表于 2017-10-11 19:08 | 显示全部楼层
  1. void SystemClock_Config(void)
  3.   RCC_OscInitTypeDef RCC_OscInitStruct;
  4.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  5.     /**Configure the main internal regulator output voltage
  6.     */
  7.   __HAL_RCC_PWR_CLK_ENABLE();
  8.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  9.     /**Initializes the CPU, AHB and APB busses clocks
  10.     */
  11.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  12.   RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  13.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  14.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  15.   RCC_OscInitStruct.PLL.PLLM = 4;
  16.   RCC_OscInitStruct.PLL.PLLN = 168;
  17.   RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  18.   RCC_OscInitStruct.PLL.PLLQ = 4;
  19.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  20.   {
  21.     _Error_Handler(__FILE__, __LINE__);
  22.   }
  23.     /**Initializes the CPU, AHB and APB busses clocks
  24.     */
  25.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  26.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  27.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  28.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  29.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  30.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  31.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
  32.   {
  33.     _Error_Handler(__FILE__, __LINE__);
  34.   }
  35.     /**Configure the Systick interrupt time
  36.     */
  37.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  38.     /**Configure the Systick
  39.     */
  40.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  41.   /* SysTick_IRQn interrupt configuration */
  42.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  43. }
ningling_21 发表于 2017-10-12 09:31 | 显示全部楼层
没错
 楼主| happytong 发表于 2017-10-12 09:56 | 显示全部楼层
