请求香主帮助,STM32f103 芯片Core is locked-up!
5772|10
 楼主| lwj006 发表于 2011-3-30 11:05 | 显示全部楼层 |阅读模式
香水城版主,请问我下载调试时突然出现Core is locked-up!,具体如下面,这种情况,应该不是程序的事,换个程序也下不了,换个keil也下不了,我原来是iar的软件,换个仿真器也不行,,,这种情况怎么办啊? 谢谢!
Wed Mar 30 10:45:53 2011: JLINK command: ProjectFile = E:\stm32_lianxi\led\project\EWARMv5\settings\led_delay_Debug.jlink, return = 0
Wed Mar 30 10:45:53 2011: JLINK command: device = STM32F10xxB, return = 0
Wed Mar 30 10:45:53 2011: DLL version: V4.14e, compiled Jun 30 2010 14:36:44
Wed Mar 30 10:45:53 2011: Firmware: J-Link ARM V8 compiled Dec  1 2009 11:42:48
Wed Mar 30 10:45:53 2011: JTAG speed is initially set to: 32 kHz
Wed Mar 30 10:45:53 2011: TotalIRLen = 9, IRPrint = 0x0011
Wed Mar 30 10:45:53 2011: Found Cortex-M3 r1p1, Little endian.
Wed Mar 30 10:45:53 2011: TPIU fitted.
Wed Mar 30 10:45:53 2011:   FPUnit: 6 code (BP) slots and 2 literal slots
Wed Mar 30 10:45:54 2011: Hardware reset with strategy 0 was performed
Wed Mar 30 10:45:54 2011: Initial reset was performed
Wed Mar 30 10:45:54 2011: Found 2 JTAG devices, Total IRLen = 9:
Wed Mar 30 10:45:54 2011:  #0 Id: 0x3BA00477, IRLen:  4, IRPrint: 0x1 CoreSight JTAG-DP
Wed Mar 30 10:45:54 2011:  #1 Id: 0x16410041, IRLen:  5, IRPrint: 0x1 STM32 Boundary Scan
Wed Mar 30 10:45:54 2011: 1096 bytes with download suppressed
Wed Mar 30 10:45:54 2011: Loaded debugee: E:\stm32_lianxi\led\project\EWARMv5\Debug\Exe\led_delay.out
Wed Mar 30 10:45:54 2011: TotalIRLen = 9, IRPrint = 0x0011
Wed Mar 30 10:45:54 2011: Found Cortex-M3 r1p1, Little endian.
Wed Mar 30 10:45:54 2011: TPIU fitted.
Wed Mar 30 10:45:54 2011:   FPUnit: 6 code (BP) slots and 2 literal slots
Wed Mar 30 10:45:54 2011: Target reset
Wed Mar 30 10:45:55 2011: Core is locked-up!
Wed Mar 30 10:45:55 2011: CPU halted
 楼主| lwj006 发表于 2011-3-30 11:31 | 显示全部楼层
好使了,哈哈:P,没人回复,也感谢!哈哈
airwill 发表于 2011-3-30 12:35 | 显示全部楼层
锁定了, 是 FLASH 锁定加密了, 要解锁哦
 楼主| lwj006 发表于 2011-3-30 14:11 | 显示全部楼层
不是,我可能是弄错了boot1和boot0.
 楼主| lwj006 发表于 2011-3-30 14:13 | 显示全部楼层
继续问,谁能给我推荐STM32的学习板,物美价廉的,呵呵:P
acgean 发表于 2011-3-30 17:04 | 显示全部楼层
要看你想玩些啥功能咯, 根据功能, 上淘宝吧, 那里有很多选择的呢
CrazyST 发表于 2011-3-30 19:26 | 显示全部楼层
万利,金牛火牛红牛,大虾(没卖了),正点原子,奋斗,神舟,安富莱等等。。。
当然还包括官方评估板,假如你很有米的话。。。
CrazyST 发表于 2011-3-30 19:43 | 显示全部楼层
现在STM32/8的产品越来越多,学的人也越来越多,滚雪球一样越滚越大,期待有一专栏专晒stm32/8为核心的产品,给我们初学者长长见识,增大动力,释放激情!
baidudz 发表于 2011-3-30 20:16 | 显示全部楼层
上淘宝逛逛吧
 楼主| lwj006 发表于 2011-3-31 12:52 | 显示全部楼层
继续问,V2.0版本的驱动库与V3.0版本的有哪些改动啊?学习那种比较好?比较易上手?谢谢!
香水城 发表于 2011-3-31 14:21 | 显示全部楼层
驱动库的release note中说明了做了哪些改动,你可以看看。
