STM的USB一个端点可以同时定义为输入端点和输出端点吗?
4474|2
 楼主| ece123 发表于 2011-4-1 17:09 | 显示全部楼层 |阅读模式
USB, STM, TE, AD, se
RT,在usb_proc.c里初始化端点5
/* Initialize Endpoint 5 */
  SetEPType(ENDP5, EP_BULK);
  SetEPTxAddr(ENDP5, ENDP5_TXADDR);
  SetEPRxAddr(ENDP5, ENDP5_RXADDR);
  SetEPTxCount(ENDP5, BULK_MAX_PACKET_SIZE);
  SetEPRxCount(ENDP5, BULK_MAX_PACKET_SIZE);
  SetEPRxStatus(ENDP5, EP_RX_VALID);
  SetEPTxStatus(ENDP5, EP_TX_NAK);
usb_endp.c
定义下面函数
void EP5_OUT_Callback(void)
//接收数据
Data_Len = USB_SIL_Read(/*ENDP5*/EP5_OUT, Bulk_Data_Buff);
void EP5_IN_Callback(void)
//发送数据
现在是能接收数据,但不能发送数据。
还有就是当HOST发了数据后在哪里设置DEVICE的响应时间?
我是在EP5_OUT_Callback里接收到数据后通过下列程序即可将Transi_Buffer里的数据发送给HOST
  UserToPMABufferCopy(Transi_Buffer, ENDP5_TXADDR, 0x0a
  SetEPTxValid(ENDP5); /* enable endpointx for transmission */
Transi_Buffer里是肯定有数据的,通过USB Monitor观察HOST没收到数据,
001722: Bulk or Interrupt Transfer (DOWN), 01.04.2011 13:50:30.218 +0.156
Pipe Handle: 0x872bf7f4 (Endpoint Address: 0x5)
Send 0xa bytes to the device
63 00 00 00 00 00 01 00 00 00                     c.........
001725: Bulk or Interrupt Transfer (UP), 01.04.2011 13:50:30.406 +0.187. Status: 0xc000000c
Pipe Handle: 0x872bf7d4 (Endpoint Address: 0x85)
Get 0x0 bytes from the device
001726: Bulk or Interrupt Transfer (DOWN), 01.04.2011 13:50:30.406 +0.0
63 00 00 00 00 00 02 00 00 00                       c........
/* EP5  */ 0x20字节
/* rx/tx buffer base address */
#define ENDP5_TXADDR        (0x120)
#define ENDP5_RXADDR        (0x140)
还需不需要其它的设置?接收是没问题的
bluesky_kun 发表于 2013-6-14 10:03 | 显示全部楼层
最近也在搞usb,同问
我做的是鼠标键盘的复合设备。usb小白啊。
bluesky_kun 发表于 2013-6-14 10:06 | 显示全部楼层
你的发送函数怎么是空的?
