调试通过的模拟串口及打印机驱动程序
6059|5
 楼主| 古道热肠 发表于 2011-4-3 23:33 | 显示全部楼层 |阅读模式
因串口要运行Mon51进行仿真调试,故选一空闲IO模拟串口的TXD信号引脚,硬件为SST89E516,晶振为18.432,12时钟周期的单片机.
相关代码如下:
sbit TXD1 = P2^3; //定义模拟输出脚
//sbit RXD1 = P1^1;   //定义模拟输入脚
bdata unsigned char SBUF1;   //定义一个位操作变量
sbit SBUF1_bit0 = SBUF1^0;
sbit SBUF1_bit1 = SBUF1^1;
sbit SBUF1_bit2 = SBUF1^2;
sbit SBUF1_bit3 = SBUF1^3;
sbit SBUF1_bit4 = SBUF1^4;
sbit SBUF1_bit5 = SBUF1^5;
sbit SBUF1_bit6 = SBUF1^6;
sbit SBUF1_bit7 = SBUF1^7;
bit UART1_RI;
#if 1
void delay_bps()
unsigned char data uci;
  for (uci = 0; uci < 19;uci++);
} //波特率9600
void delay_Halfbps()
//  for (uci = 0; uci < 6;uci++);  _nop_();_nop_();
  for (uci = 0; uci <50 ;uci++);
} //波特率9600
#endif
#if 0
void delay_bps()
  for (uci = 0; uci < 6*9+8;uci++);
} //波特率19200
  for (uci = 0; uci <25 ;uci++);
} //波特率19200
#endif
//unsigned char getchar2() //从缓冲区内读取一个字节数据
void putchar2(unsigned char input)    //向发送缓冲区内写入一个数据
    SBUF1 = input;
    TXD1 = 0;  //起始位
    delay_bps();
    TXD1 = SBUF1_bit0;  //0
    delay_bps();
    TXD1 = SBUF1_bit1;  //1
    delay_bps();
    TXD1 = SBUF1_bit2;  //2
    delay_bps();
    TXD1 = SBUF1_bit3;  //3
    delay_bps();
    TXD1 = SBUF1_bit4;  //4
    delay_bps();
    TXD1 = SBUF1_bit5;  //5
    delay_bps();
    TXD1 = SBUF1_bit6;  //6
    delay_bps();
    TXD1 = SBUF1_bit7;  //7
    delay_bps();
    TXD1 = 1;       //停止位
    delay_bps();
#define SendCharToPrint(x) putchar2(x)
void ChangePrintModeToChinese(void)
SendCharToPrint(0x1C);
SendCharToPrint(0x26);
void ChangePrintModeToEnglish(void)
SendCharToPrint(0x2E);
void PrintFeedPaper(uchar ucLineCount)
SendCharToPrint(0x1B);
SendCharToPrint(0x4A);
SendCharToPrint(ucLineCount);
void PrintString(uchar *ucString)
uchar ucStringLen;
ucStringLen = strlen(ucString);
while(ucStringLen--)
  SendCharToPrint(*ucString++);
void TestPrint(void)
ChangePrintModeToChinese();
PrintString("2011年4月3日 21时20分50秒\n\r");
应用程序中用到的相关代码如下:
PrintString("----------------------------\n\r");
PrintString("  智能开关机记录仪启动\n\r");
Read_RTC_PCF8563(ucRTCBuff);
//将BCD码转换成16进制数据
for(ucCount=0; ucCount<7; ucCount++)
  ucTemp = ucRTCBuff[ucCount];
  ucRTCBuff[ucCount] = (ucTemp>>4)*10+(ucTemp&0x0F);
sprintf(ucTempBuff,"20%02d年%02d月%02d日 ",(uint)ucRTCBuff[6],(uint)ucRTCBuff[5],(uint)ucRTCBuff[3]);
PrintString(ucTempBuff);
sprintf(ucTempBuff,"%02d时%02d分%02d秒\n\r",(uint)ucRTCBuff[2],(uint)ucRTCBuff[1],(uint)ucRTCBuff[0]);
PrintFeedPaper(50);
效果图如下:
还有一段代码如下:
//打印当前记录
  uchar ucCount;
  uchar ucTemp;
  uchar xdata ucTempBuff[19];
  //将BCD码转换成16进制数据
  sprintf(ucTempBuff,"通道号:%02d 事件:",(uint)ucRecordNumber);
  if(ucActionType == 0)
   PrintString("开机\n\r");
  else
   PrintString("关机\n\r");
  PrintString("***********************\n\r");
  PrintFeedPaper(15);
效果图如下:
 楼主| 古道热肠 发表于 2011-4-3 23:41 | 显示全部楼层
良好的程序分格应熟练使用字符串进行各种功能的实现,
sprintf和<string.h>中的相关函数值得好好学,好好用.
原野之狼 发表于 2011-4-4 01:29 | 显示全部楼层
呵呵 记得原来用打印机打印曲线 还是蛮好玩的
hotpower 发表于 2011-4-4 18:41 | 显示全部楼层
晕,老顽固,什么年代了,还模拟串口???
 楼主| 古道热肠 发表于 2011-4-4 20:36 | 显示全部楼层
呵呵,谢谢版主送裤子.
 楼主| 古道热肠 发表于 2011-4-4 20:40 | 显示全部楼层
任何年代,"坚苦朴素"的作风不能丢."花小钱办实事"的技巧不能废.
个人签名:以VS1003B和山景SOC芯片为背景,倾心研制数字化语音录放产品. 排忧邮箱:xg_2004_sy@126.com 得意之作是做了个AVR高压编程器,用起来爽歪歪, 串口MP3录放音模块,全面进入数字录放音时代
284
