求解救啊!!multisim仿真三运放组成的仪表放大器
6735|3
 楼主| linzuxiang 发表于 2011-4-4 01:21 | 显示全部楼层 |阅读模式
各位好心的大大们,俺这几天用NI multisim10仿真三运放组成仪表放大器,老是运行几百毫秒后,软件就中断仿真,弹出错误信息,看着错误信息,那些英文报告内容又看不懂什么意思,纠结……求大大们指导下……泪奔啊……电路功能:
1.完成把10uv直流电压放大到100uv
2.电路具备调零功能
3.具备可调放大倍数
这是电路图:
这是错误报告信息:
Instrument operation performed   (2011, April 04, Monday, 00:29:16)
|   Instrument Analysis:Transient Analysis
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions:Automatically generate initial conditions
|   |   |   Starting time (TSTART):0
|   |   |   Stop time (TSTOP):1e+030
|   |   |   Plotting increment (TSTEP):automatically calculated (less than:1e+030)
|   |   |   Maximum time step (TMAX):automatically calculated (less than:1e+030)
|   |   Perform consistency check
|   |   Variables from analysis
|   |   |   Show device values at the end of the simulation
|   |   Representation as SPICE commands
|   |   |   begin-scope page
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+012
|   |   |   -param hrange 0 1e+030
|   |   |   save
|   |   |   tran  -env-options 1e-005 1e+030 0 1e-005 auto_ic auto_tstep auto_tmax
|   |   |   if-error end-scope audit-log-show
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   Multisim Default Analysis Options
|   |   |   Truncation error overestimation factor: 7
|   |   |   Upper transient iteration limit: 100
|   |   |   Enable convergence assistance for code models
|   |   |   Shunt resistance from analog nodes to ground: 1e+012
|   Output from instrument analysis
|   |    TRAN:  Timestep too small; time = 0.0322228, timestep = 0:cause unrecorded.
|   |    doAnalyses: timestep too small
|   |   tran simulation(s) aborted
这是示波器显示:
file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/469381320/QQ/WinTemp/RichOle/ZC41IK6%60J%7DU%7B0J~6MU%60N(G1.jpg
file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/469381320/QQ/WinTemp/RichOle/ZC41IK6%60J%7DU%7B0J~6MU%60N(G1.jpgfile:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/469381320/QQ/WinTemp/RichOle/ZC41IK6%60J%7DU%7B0J~6MU%60N(G1.jpg
2009gxs 发表于 2011-7-5 00:36 | 显示全部楼层
看来multisim这东西不怎么好用,明天直接去实验室去试试去。
a12345678 发表于 2011-7-9 23:54 | 显示全部楼层
不过放大10倍,用一个自稳零运放结成差分电路形式即可,不必这样麻烦
