| #include<reg52.h> #define uchar unsigned char
 #define uint unsigned int
 #define WRITE_SECOND 0x80
 #define WRITE_MINUTE 0x82
 #define WRITE_HOUR   0x84
 #define WRITE_DATE 0x86
 #define WRITE_MONTH 0x88
 #define WRITE_DAY   0x8A
 #define WRITE_YEAR   0x8C
 #define READ_SECOND   0x81
 #define READ_MINUTE 0x83
 #define READ_HOUR    0x85
 #define READ_DATE   0x87
 #define READ_MONTH 0x89
 #define READ_DAY    0x8B
 #define READ_YEAR   0x8D
 #define WRITE_PROTECT 0x8E
 #define pos_year   L1+0
 #define pos_month L1+3
 #define pos_date   L1+6
 #define pos_day    L1+9
 #define pos_hour   L2+0
 #define pos_minute L2+3
 #define pos_sec L2+6
 #define DATA P3
 sbit RS1602=P1^0;
 sbit RW1602=P1^1;
 sbit E1602=P1^2;
 #define L1 0x80
 #define L2 0xc0
 sbit sclk=P1^3;
 sbit clk_io=P1^4;
 sbit clk_rst=P1^5;
 sbit func_key=P3^2;
 sbit inc_key=P3^1;
 sbit dec_key=P1^0;
 void delay(uchar);
 void write1602_comd(uchar);
 void write1602_data(uchar);
 void init1602_lcd();
 void keyscan();
 void Init_DS1302();
 void update_time();
 uchar flag=0;
 uchar code table1[]="09-10-30/5";
 uchar code table2[]="12:00:00";
 void init1602_lcd()
 int i;
 write1602_comd(0x01);
 write1602_comd(0x0c);
 write1602_comd(0x06);
 write1602_comd(0x3C);
 write1602_comd(0x80);
 for(i=0;i<10;i++)
 write1602_data(table1[i]);
 delay(20);
 write1602_comd(0xc0);
 for(i=0;i<8;i++)
 write1602_data(table2[i]);
 delay(20);
 void delay(uchar z)
 uchar i,j;
 for(j=z;j>0;j--)
 for(i=125;i>0;i--);
 void write1602_comd(uchar com)
 RS1602=0;
 DATA=com;
 RW1602=0;
 delay(5);
 E1602=1;
 delay(5);
 E1602=0;
 void write1602_data(uchar datatowrite)
 RS1602=1;
 DATA=datatowrite;
 RW1602=0;
 delay(5);
 E1602=1;
 delay(5);
 E1602=0;
 void writeds1602_byte(uchar dat)
 uchar i,dat_w;
 dat_w=dat;
 for(i=0;i<8;i++)
 clk_io=0;
 if(dat_w&0x01)
 {clk_io=1;}
 else
 {clk_io=0;}
 dat_w=dat_w>>1;
 sclk=0;
 sclk=1;
 sclk=0;
 uchar readds1602_byte()
 uchar i,k;
 k=0;
 for(i=0;i<8;i++)
 k=k>>1;
 if(clk_io)
 {k=k|0x80;}
 sclk=0;
 sclk=1;
 sclk=0;
 return (k);
 void Write1602(uchar add,uchar dat)
 clk_rst=0;
 sclk=0;
 clk_rst=1;
 writeds1602_byte(add);
 writeds1602_byte((dat/10<<4)|(dat%10));
 sclk=0;
 clk_rst=0;
 uchar Read1302(uchar add)
 uchar temp,dat1,dat2;
 clk_rst=0;
 sclk=0;
 clk_rst=1;
 temp=readds1602_byte();
 sclk=0;
 clk_rst=0;
 dat1=temp/16;
 dat2=temp%16;
 temp=dat1*10+dat2;
 return (temp);
 void Init_DS1302(void)
 Write1602 (WRITE_PROTECT,0X00); delay(1);
 Write1602 (WRITE_SECOND,0x00); delay(1);
 Write1602 (WRITE_MINUTE,0x00);delay(1);
 Write1602 (WRITE_HOUR,0x0C); delay(1);
 Write1602 (WRITE_DAY,0x01); delay(1);
 Write1602 (WRITE_DATE,0x12);delay(1);
 Write1602 (WRITE_MONTH,0x05); delay(1);
 Write1602 (WRITE_YEAR,0x09); delay(1);
 Write1602 (WRITE_PROTECT,0x80); delay(1);
 void read_write_date_time(uchar _1302_addr, _1602_addr)
 uchar high,low,get_data;
 Write1602 (WRITE_PROTECT,0x00);
 delay(1);
 get_data=Read1302(_1302_addr);
 high=get_data/10;
 low=get_data%10;
 write1602_comd(_1602_addr);
 write1602_data(high+0X40);
 write1602_data(low+0X40);
 void write_lcd(uchar cusr_addr,time_data )
 uchar hour_wei,ge_wei;
 hour_wei=time_data/10;
 ge_wei=time_data%10;
 write1602_comd(cusr_addr);
 write1602_data(hour_wei+0X40);
 write1602_data(ge_wei+0X40);
 void update_time()
 uchar xq;
 read_write_date_time(READ_HOUR,L2);
 read_write_date_time(READ_MINUTE,L2+3);
 read_write_date_time(READ_SECOND,L2+6);
 read_write_date_time(READ_YEAR,L1);
 read_write_date_time(READ_MONTH,L1+3);
 read_write_date_time(READ_DATE,L1+6);
 xq=Read1302(READ_DAY);
 write1602_comd(L1+9);
 write1602_data(xq+0X40);
 uchar first=1,num,second,minute,hour,day,date,month,year;
 void keyscan()
 if(first==1)
 second=Read1302(READ_SECOND);
 minute=Read1302(READ_MINUTE);
 hour=Read1302(READ_HOUR);
 day=Read1302(READ_DAY);
 date=Read1302(READ_DATE);
 month=Read1302(READ_MONTH);
 year=Read1302(READ_YEAR);
 first=0;
 if(func_key==0)
 delay(5);
 if(func_key==0)
 num++;
 flag=1;
 while(!func_key);
 if(num==1)
 clk_rst=0;
 write1602_comd(pos_sec);
 write1602_comd(0x0f);
 if(num==2)
 write1602_comd(pos_minute);
 if(num==3)
 write1602_comd(pos_hour);
 if(num==4)
 write1602_comd(pos_day);
 if(num==5)
 write1602_comd(pos_date);
 if(num==6)
 write1602_comd(pos_month);
 if(num==7)
 write1602_comd(pos_year);
 if(num==8)
 num=0;
 flag=0;
 clk_rst=1;
 Write1602 (WRITE_PROTECT,0x00);delay(1);
 Write1602(WRITE_SECOND,second);delay(1);
 Write1602(WRITE_MINUTE,minute); delay(1);
 Write1602(WRITE_HOUR,hour); delay(1);
 Write1602(WRITE_DAY,day); delay(1);
 Write1602(WRITE_DATE,date); delay(1);
 Write1602(WRITE_MONTH,month); delay(1);
 Write1602(WRITE_YEAR,year); delay(1);
 first=1;
 if(num!=0)
 if(inc_key==0)
 delay(1);
 if(inc_key==0)
 while(!inc_key);
 if(num==1)
 second++;
 if(second==60)
 second=0;
 write_lcd(pos_sec,second);
 if(num==2)
 minute++;
 if(minute==60)
 minute=0;
 write_lcd(pos_minute,minute);
 if(num==3)
 hour++;
 if(hour==24)
 hour=0;
 write_lcd(pos_hour,hour);
 if(num==4)
 day++;
 if(day==8)
 day=1;
 write1602_data(day+0X40);
 if(num==5)
 date++;
 if(date==32)
 date=1;
 write_lcd(pos_date,date);
 if(num==6)
 month++;
 if(month==13)
 month=1;
 write_lcd(pos_month,month);
 if(num==7)
 year++;
 if(year==99)
 hour=0;
 write_lcd(pos_year,year);
 if(dec_key==0)
 delay(1);
 if(dec_key==0)
 while(!dec_key);
 if(num==1)
 second--;
 if(second==-1)
 second=59;
 if(num==2)
 minute--;
 if(minute==-1)
 minute=59;
 if(num==3)
 hour--;
 if(hour==-1)
 hour=23;
 if(num==4)
 day--;
 if(day==0)
 day=7;
 if(num==5)
 date--;
 if(date==0)
 date=31;
 if(num==6)
 month--;
 if(month==0)
 month=12;
 if(num==7)
 year--;
 if(year==0)
 hour=15;
 void main()
 Init_DS1302();
 init1602_lcd();
 while(1)
 keyscan();
 delay(10);
 if(flag==0)
 update_time();
 这里的flag是什么意思,有什么功能?定义的是什么
 write1602_comd(_1602_addr);// 设置第二行地址指针
 write1602_data(high+0X30);
 write1602_data(low+0X30);
 这里的加0x30对吗?不是该加0x40吗?
