[产品供应] 优势供应PT4301
1637|0
 楼主| natertech 发表于 2011-4-7 22:25 | 显示全部楼层 |阅读模式
AN, TE, TI, ge, hz
     应用PT4301来做接受端功能模块,具有较高的频率稳定度,接收灵敏度极高灵敏度达-114dBm,接收距离是普通同类模块的2-3倍;有合理的接收带宽,抗干扰能力特强,适应各种环境使用;传输速率最高可达20kbps;输出为数据cmos电平信号,可直接至标准解码器或cpu解码,频率为315m~433.92m,适合与同频发射模块及遥控手柄配套,用于各种遥控器,报警器及单片机短距离数据传输.
     应用范围:各种低速率数字信号的接收;工业遥控,遥测,遥感;防盗报警器信号接收,各种家用电器的遥控等.
     The PT4301 is a very low power and highly sensitive single chip OOK/ASK super-heterodyne receiver for the 315MHz and 434MHz frequency bands that offers a high level of integration and requires only a few external components. The PT4301 consists of a low-noise amplifier (LNA), an image-rejection mixer,
an on-chip phase-locked loop (PLL) with integrated voltage-controlled oscillator (VCO) and loop filter, a 10.7MHz intermediate frequency (IF) limiting amplifier stage with received-signal-strength indicator (RSSI), and analog baseband data recovery circuitry (data filter, peak detector, and data slicer). The PT4301 also implements a discrete one-step automatic gain control
(AGC) that reduces the LNA gain by 20dB when the RF input signal is greater than -47dBm. The PT4301 is available in a 24-pin SSOP package.
Features
Low current consumption (5mA fully active mode at 315MHz)
2.4V to 5.5V supply voltage operation range
Optimized for 315MHz or 434MHz ISM Band
On-chip image-rejection
High dynamic range with on-chip AGC
Low power down mode current (<1μA)
High sensitivity of -114dBm (315MHz, 2Kb/s AM 99% square-wave modulation)
Applications
Remote keyless entry (RKE) systems
Remote control systems including garage door and gate openers
Alarm and security systems
Wireless sensors
个人签名:WiFi模块/网络交换方案配套 QQ:42142951 MP:13510620050
129
