[产品供应]
PT4452正在批量供应
1498|0
natertech|  楼主 | 2011-4-7 22:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, ST, AN, TI, se
PT4452(低电压UHF OOK/ASK/FSK发射器).
      PT4452使用晶振作为基频,使得频率偏移可以降至最低.在250~450MHz的操作频带中,3.0V的工作电压即可输出+10dBm功率,很适合低电压应用.PT4452是市面上相同方案中外围零件最少者,可以减少PCB所需面积,让终端产品在造型有更多发挥的空间,采用SOP-8封装
Description
      PT4452 is a high performance OOK/ASK/FSK transmitter for the Remote Keyless Entry (RKE) systems. It consists of a power amplifier, one-shot
circuit and phase-locked loop with internal voltage controlled oscillator and loop filter. The one-shot circuit controls the phase-locked loop and power amplifier to have fast start-up time in operation.
Features
Highly integrated OOK/ASK/FSK transmitter
High output power, 3 V /+12 dBm /27 mA
Low supply voltage, 2.2 V to 3.6 V operation range
Low external component cost.
PLL-based transmitter with frequency range from 250MHz to 450MHz
On-chip one-shot circuit
60 dB RF on-off ratio for OOK/ASK modulation
Applications
Keyless entry systems
Remote control systems
Garage door openers
Alarm systems
Security systems
Wireless sensors
个人签名:WiFi模块/网络交换方案配套 QQ:42142951 MP:13510620050
128
