使用ngspice能否仿真数字电路(与门,非门,与非门等)
3825|1
 楼主| wendyfox 发表于 2011-4-20 10:07 | 显示全部楼层 |阅读模式
我使用以下manual中的例子程序,但是找不到模型d_nand,我发现不但这个d_and,d_or都是用不了.都是说d_nand是unknow model
a6 [1 2 3]  8  nand1
.model  nand1  d_nand (rise_delay =0.5e-9)
.tran 10ns 100ns
是不是要引用什么才可以用?
我在manual中看到一段话
The following digital models are supplied with XSPICE. The descriptions included below consist of an
example model Interface Specication File and a description of the model's operation. This is followed by
an example of a simulator-deck placement of the model, including the .MODEL card and the specication
of all available parameters. Note that these models have not been finalized at this time.
是不是指ngspice不提供,Xspice才提供呢?
 楼主| wendyfox 发表于 2011-4-20 11:36 | 显示全部楼层
估计在国内都比较少人用到这到,最多只是研究一下
