有关于SysTick的问题
2361|3
 楼主| zdlulu 发表于 2011-4-21 09:11 | 显示全部楼层 |阅读模式
我是STM32的初学者,现有有问题不明白,向各位询问一下
#include "stm32f10x.h"
vu32 TimingDelay;
void GPIO_Configuration(void)
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_13|GPIO_Pin_3|GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOD,&GPIO_InitStructure);
void RCC_Configuration(void)
        SystemInit();
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
void SysTick_Configuration(void)
        SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
        NVIC_SystemHandlerPriorityConfig(SystemHandler_SysTick, 3, 0);
        SysTick_SetReload(72000);
        SysTick_ITConfig(ENABLE);
void Delay(u32 nTime)
        TimingDelay = nTime;
        SysTick_CounterCmd(SysTick_Counter_Enable);
        while(TimingDelay != 0);
        SysTick_CounterCmd(SysTick_Counter_Disable);
        SysTick_CounterCmd(SysTick_Counter_Clear);
void SysTickHandler(void)
        if(TimingDelay != 0)
        TimingDelay--;
void InitAllPeriph(void)
        GPIO_Configuration();
        RCC_Configuration();
        NVIC_Configuration();
        SysTick_Configuration();
int main(void)
        InitAllPeriph();
        while(1)
           GPIO_SetBits(GPIOD,GPIO_Pin_7);
           Delay(1000);
           GPIO_ResetBits(GPIOD,GPIO_Pin_7);
           Delay(1000);
ccxlslr 发表于 2011-4-21 13:35 | 显示全部楼层
你TMD以为你是谁啊!
讨厌!这种什么都没用的贴子!
zhiyonghe 发表于 2011-4-21 14:18 | 显示全部楼层
楼主你问什么??
整个程序就是个简单的用SysTick做延时的程序……
SysTick->LOAD=72000 ,
估计楼主的时钟为72M 故SysTick每1ms中断一次
则Delay(1000)表示延时1S
zuoqingxiaohui 发表于 2011-4-22 11:28 | 显示全部楼层
