xilinx CPLD 相关
3157|14
 楼主| hjjnet 发表于 2011-4-27 13:43 | 显示全部楼层 |阅读模式
UARTs in Xilinx CPLDs
 楼主| hjjnet 发表于 2011-4-27 13:44 | 显示全部楼层
CoolRunner CPLD I2C Bus Controller
Implementation
CoolRunner-II CPLD I2C Bus Controller
Implementation
 楼主| hjjnet 发表于 2011-4-27 13:45 | 显示全部楼层
Implementing Keypad Scanners with
CoolRunner-II
CoolRunner-II Character LCD Module
Interface
 楼主| hjjnet 发表于 2011-4-27 13:46 | 显示全部楼层
Xilinx CPLD Applications
Handbook
Manchester Encoder-Decoder for Xilinx
CPLDs
 楼主| hjjnet 发表于 2011-4-27 13:47 | 显示全部楼层
IrDA and UART Design in a CoolRunner
CPLD
CoolRunner XPLA3 SMBus Controller
Implementation
等会再更新。
 楼主| hjjnet 发表于 2011-4-27 13:48 | 显示全部楼层
争取在这个帖子上吧xilinx CPLD的应用做个全方位的介绍和总结把
AutoESL 发表于 2011-4-27 16:08 | 显示全部楼层
太多了,呵呵,看不过来
ty新气象 发表于 2011-4-28 14:01 | 显示全部楼层
给力。
ladygaga 发表于 2011-6-26 22:45 | 显示全部楼层
嗯,非常给力。:D
明空 发表于 2011-6-27 00:57 | 显示全部楼层
看到hjj这么给力,我上个全的
This Chapter contains the following topics:
• IrDA and UART Design in a CoolRunner CPLD
• Serial ADC Interface Using a CoolRunner CPLD
• Wireless Transceiver for the CoolRunner CPLD
• CoolRunner-II Smart Card Reader
• CoolRunner-II CPLD I2C Bus Controller Implementation
• CoolRunner-II Serial Peripheral Interface Master
• Design of a Digital Camera with CoolRunner-II CPLDs
• CompactFlash Card Interface for CoolRunner-II CPLDs
• Interfacing to Mobile SDRAM with CoolRunner-II CPLDs
• An SMBus/I2C-Compatible Port Expander
• Driving LEDs with Xilinx CPLDs
• CoolRunner-II CPLDs in Cell Phone Handsets/Terminals
• Implementing Keypad Scanners with CoolRunner-II
• Level Translation Using Xilinx CoolRunner-II CPLDs
• CoolRunner-II Character LCD Module Interface
• Using Xilinx CPLDs to Interface to a NAND Flash Memory Device
• Cell Phone Security Demoboard On The Fly Reconfiguration Technique
• Using CoolRunner-II with OMAP, XScale, i.MX & Other Chipsets
• Connecting Intel PXA27x Processors to Hard-Disk Drives with a CoolRunner-II CPLD
• A Low-Power IDE Controller Design Using a CoolRunner-II CPLD
• Using a Xilinx CoolRunner-II CPLD as a Data Stream Switch
• Supporting Multiple SD Devices with CoolRunner-II CPLDs
个人签名:Devere Hu E-mail: deverehu@comtech.com.cn Tel: 027-87568667 Mobile  :13545000634 Comtech (Wuhan), Xilinx FAE
170
