[产品供应]
北京蓝景世纪专业代理PVG310 和PVG610
1967|0
jameswangchip|  楼主 | 2011-4-28 10:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, TE, TI, IO, ST
Provigent 公司是业内一家业内领先的宽带无线传输行业的SOC 的芯片公司,有很多产品方案应用在微波设备上,其中PVG310是一款MODEM CHIP ,PVG610是一款BASEBAND SOC .北京蓝景世纪专业代理推广Provigent  的PVG610和PVG310 产品线系列。
PVG610 Baseband SoC Family
Provigent’s PVG610 family is an advanced Baseband System-on-a-Chip (SoC) solution for point-to-point wireless transmission systems. PVG610 SoCs support the complete processing chain - from user data interfaces of mixed signals through a high performance modem to carrier IF frequency. Multiple user data streams and types are encoded, modulated and converted to an analog signal for transmission. The received analog signal is digitized, demodulated, decoded and mapped to users' data streams. Innovative DSP mitigates analog impairments and allows overall system cost reduction.
The PVG610 family of SoCs offers a wide range of product types to optimize system cost for any type of application.
It includes the following main features:
General
Bit rate up to 400 Mbps
Adaptive Code and Modulation (ACM)
Redundancy through protection bus
Immunity to phase noise and phase hits
Modulation
QPSK; 16, 32, 64, 128, 256 QAM
FDD, TDD, and HFDD
Direct IF sampling and baseband sampling (I/Q)
Receiver Features
Enhanced state-of-the-art Low-Density Parity-Check (LDPC) to improve coding gain
Programmable Reed Solomon block code
XPIC
Double the wireless capacity bit rate up to 800 Mbps
Digital Cross Polarization Interference Cancellation
Operates in low XPD down to 5db
Non-synchronized radios configuration support
Playload Transport10/100/1000Mbps Ethernet MAC (MII, GMII or TBI)
PDH
SONET/SDH framers
General Purpose Interface (GPI) for user data
Overhead Management
2 wayside E1 channels
TOH insertion/extraction for STM-1/OC-3
PVG310 Modem-on-a-Chip Family
Provigent’s PVG310 family is an advanced baseband modem-on-a-chip solution for point-to-point wireless transmission systems. PVG310 chips integrate all baseband functionality required for microwave frequency bands and support various data rates with high spectral efficiency while significantly lowering overall system costs.
The PVG310 family of SoCs offers several product types to optimize system design for any type of application.
General
Integrated modulator, demodulator and FEC
Net data payload rates up to OC-6/STM-2 (311 Mbps)
Net data rate of 622 Mbps over a dual polarized channel using internal cross
polarization interference cancellation
All-digital carrier and timing recovery with fixed rate external clocks
Designed to support ETSI and FCC requirements
Modulation
Full or half duplex modes (TDD,FDD)
QPSK, 16, 32, 64, 128 and 256QAM in FDD mode; QPSK, 16 and 64QAM in TDD mode
Fast modulation change capability (supporting adaptive modulation)
Programmable symbol rates up to 47.5 Mbaud in FDD mode and 25 Mbaud in TDD mode
IF sampling or baseband sampling (I/Q) modes
Programmable pulse shaping filter (supports SRRC with alpha down to 0.15)
Forward Error Correction (FEC)
Programmable Reed Solomon block code with up to 16 correctable bytes (32 check bytes)
Concatenated convolutional, trellis or block convolutional inner code with variable rates 1/2
to 13/14
Programmable internal interleaver
Distortion Compensation
Adaptive quadrature distortion correction at transmitter and receiver
Transmitter predistortion function
Powerful decision-feedback equalizer
System Feature Enhancements
Transmit and receive digital frequency correction
Strong adjacent channel interference rejection
I/Q imbalance correction
Internal digital cross polarization interference cancellation (XPIC)
Internal byte clock to symbol clock generation
User data clock synthesis
Internal data FIFOs
Internal near and far loop back support
Internal BER tester
Performance and channel condition monitors
ADI 全线产品小批量采购服务中心
北京蓝景世纪科技开发有限责任公司
地址:北京市海淀区知春路128号泛亚大厦1892B
电话:010-51663026 ,82626934
传真:010-51664726
邮件: marketing@bluechipsemi.com
www.bluechipsemi.com
个人签名:新浪微博:阿牛哥在北京 http://www.weibo.com/brotherbull QQ:1047177125
2847
