8*8LED点阵 扫描问题!!
3588|9
 楼主| funfactory 发表于 2011-5-13 21:10 | 显示全部楼层 |阅读模式
假设P3 = table[i+j];  i是行扫描时的数组变量,j是列扫描。为什么是i+j而不是直接P3=table[j]   ???
 楼主| funfactory 发表于 2011-5-13 21:34 | 显示全部楼层
研究了两天led点阵,貌似懂了,坐骑实物来发现自己什么都不懂啊!!
NE5532 发表于 2011-5-13 21:36 | 显示全部楼层
一行程序,能懂者,仙人也。
 楼主| funfactory 发表于 2011-5-13 23:24 | 显示全部楼层
#include <reg52.h>
typedef  unsigned char   uint8;
typedef  unsigned int    uint16;
typedef  unsigned long   uint32;
code uint8 graph[] = {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
                                          0xFF,0xC3,0xE7,0xE7,0xE7,0xE7,0xC3,0xFF,
                                          0xFF,0x99,0x00,0x00,0x00,0x81,0xC3,0xE7,
                                          0xFF,0x99,0x99,0x99,0x99,0x81,0xC3,0xFF,
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
uint8 i= 0,counter = 0;
void timer1_init()
        TMOD |= 0x10;
        TMOD &= 0xdf;
        TH1   = 0xFC;
        TL1   = 0x67;
        TR1   = 1;
void int_init()
        ET1 = 1;
        EA  = 1;
void refresh_led()
          static uint8 j = 0;
                switch(j)
                   case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;break;
                case 6: ADDR0 = 0;ADDR1 = 1;ADDR2 = 1;break;
                case 7: ADDR0 = 1;ADDR1 = 1;ADDR2 = 1;break;
                default: break;
                P0 = graph[i + j];
                if(7 == j++) j = 0;
main()
        ENLED = 0; ADDR3 = 0;
        timer1_init();
        int_init();
        while(1);
void interrupt_timer1()        interrupt 3
          TH1 = 0xFC;
          TL1 = 0x67;
          counter++;
          if(counter == 200)
                         counter = 0;
                        i++;
                        if(i>=32){i=0;}
          refresh_led();
szshawn2010 发表于 2011-5-14 16:34 | 显示全部楼层
关注一下。
 楼主| funfactory 发表于 2011-5-15 13:09 | 显示全部楼层
怎么没人来回答一下啊!!
大家不要太谦虚啊,知道什么说什么。一起讨论啊!!
kyy173 发表于 2011-5-15 13:15 | 显示全部楼层
joyme 发表于 2011-5-16 09:24 | 显示全部楼层
只是一个移动图像(文字)显示
ayb_ice 发表于 2011-5-16 10:41 | 显示全部楼层
就是行,列嘛
做成二维数组你就懂了
不过算法好象不对,应该是i*8+j,不过也没有仔细研究具体代码,随便说说
