<table class=ubb cellspacing=0><TR><td class=ubb>TI 德州仪器> 电压电流基准 </td></TR><TR><td class=ubb>Texas Instruments 美国 TI 德州仪器半导体公司 电压基准与电流基准 </td></TR><TR><td class=ubb><b>产品概述</b> <br />并联电压基准 <br />串联电压基准 <br />电流基准 </td></TR></table><br />非隔离式开关 DC/DC 调节器 产品概述 <table class=ubb cellspacing=0><TR><td class=ubb><b>Part Number </b></td><td class=ubb><b>Description </b> 当前页面搜索:Ctrl+F</td></TR><TR><td class=ubb>并联电压基准</td></TR><TR><td class=ubb>LM236-2.5</td><td class=ubb>LM236-2.5 2.5V 集成参考电路</td></TR><TR><td class=ubb>LM285-1.2</td><td class=ubb>LM285-1.2 微功耗电压参考</td></TR><TR><td class=ubb>LM285-2.5</td><td class=ubb>LM285-2.5 微功耗电压参考</td></TR><TR><td class=ubb>LM336-2.5</td><td class=ubb>LM336-2.5 2.5V 集成参考电路</td></TR><TR><td class=ubb>LM336B-2.5</td><td class=ubb>LM336B-2.5 精密电压参考</td></TR><TR><td class=ubb>LM385-1.2</td><td class=ubb>LM385-1.2 微功耗电压参考</td></TR><TR><td class=ubb>LM385-2.5</td><td class=ubb>LM385-2.5 微功耗电压参考</td></TR><TR><td class=ubb>LM385B-1.2</td><td class=ubb>LM385B-1.2 微功耗电压参考</td></TR><TR><td class=ubb>LM385B-2.5</td><td class=ubb>LM385B-2.5 微功耗电压参考</td></TR><TR><td class=ubb>LM4040A10</td><td class=ubb>LM4040A10 10V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A20</td><td class=ubb>LM4040A20 2.048V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A25</td><td class=ubb>LM4040A25 2.5V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A30</td><td class=ubb>LM4040A30 3V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A41</td><td class=ubb>LM4040A41 4.096V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A50</td><td class=ubb>LM4040A50 5V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040A82</td><td class=ubb>LM4040A82 8.192V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4040B10</td><td class=ubb>LM4040B10 10V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B20</td><td class=ubb>LM4040B20 2.048V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B25</td><td class=ubb>LM4040B25 2.5V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B30</td><td class=ubb>LM4040B30 3V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B41</td><td class=ubb>LM4040B41 4.096V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B50</td><td class=ubb>LM4040B50 5V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040B82</td><td class=ubb>LM4040B82 8.192V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4040C10</td><td class=ubb>LM4040C10 10V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C20</td><td class=ubb>LM4040C20 2.048V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C25</td><td class=ubb>LM4040C25 2.5V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C30</td><td class=ubb>LM4040C30 3V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C41</td><td class=ubb>LM4040C41 4.096V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C50</td><td class=ubb>LM4040C50 5V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040C82</td><td class=ubb>LM4040C82 8.192V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4040D10</td><td class=ubb>LM4040D10 10V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4040D20</td><td class=ubb>LM4040D20 2.048V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4040D25</td><td class=ubb>LM4040D25 2.5V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4040D30</td><td class=ubb>LM4040D30 3V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4040D50</td><td class=ubb>LM4040D50 5V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4040D82</td><td class=ubb>LM4040D82 8.192V 精密微功耗并联电压参考,1% 精确度</td></TR><TR><td class=ubb>LM4041A12</td><td class=ubb>LM4041A12 1.2V 精密微功耗并联电压参考,0.1% 精确度</td></TR><TR><td class=ubb>LM4041B</td><td class=ubb>LM4041B 可调节精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4041B12</td><td class=ubb>LM4041B12 1.2V 精密微功耗并联电压参考,0.2% 精确度</td></TR><TR><td class=ubb>LM4041C</td><td class=ubb>LM4041C 可调节精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4041C12</td><td class=ubb>LM4041C12 1.2V 精密微功耗并联电压参考,0.5% 精确度</td></TR><TR><td class=ubb>LM4041D</td><td class=ubb>LM4041D 可调节精密微功耗并联电压参考,1.0% 精确度</td></TR><TR><td class=ubb>LM4041D12</td><td class=ubb>LM4041D12 1.2V 精密微功耗并联电压参考,1.0% 精确度</td></TR><TR><td class=ubb>LT1004-1.2</td><td class=ubb>LT1004-1.2 微功耗集成精确电压基准</td></TR><TR><td class=ubb>LT1004-2.5</td><td class=ubb>LT1004-2.5 微功耗集成精密电压参考</td></TR><TR><td class=ubb>LT1009</td><td class=ubb>LT1009 2.5V 集成参考电路</td></TR><TR><td class=ubb>REF1004-1.2</td><td class=ubb>REF1004-1.2 微功耗电压参考</td></TR><TR><td class=ubb>REF1004-2.5</td><td class=ubb>REF1004-2.5 微功耗电压参考</td></TR><TR><td class=ubb>REF1112</td><td class=ubb>REF1112 采用 SOT23-3 封装的 1uA 静态电流 10ppm/℃ 漂移并联电压参考</td></TR><TR><td class=ubb>TL1431</td><td class=ubb>TL1431 精密可调节(可编程)并联参考</td></TR><TR><td class=ubb>TL430</td><td class=ubb>TL430 可调节并联稳压器</td></TR><TR><td class=ubb>TL431</td><td class=ubb>TL431 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL431A</td><td class=ubb>TL431A 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL431A-Q1</td><td class=ubb>TL431A-Q1 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL431B</td><td class=ubb>TL431B 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL431B-Q1</td><td class=ubb>TL431B-Q1 Automotive Catalog Adjustable Precision Shunt Regulator</td></TR><TR><td class=ubb>TL432</td><td class=ubb>TL432 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL432A</td><td class=ubb>TL432A 可调节精密并联稳压器</td></TR><TR><td class=ubb>TL432B</td><td class=ubb>TL432B 可调节精密并联稳压器</td></TR><TR><td class=ubb>TLV431</td><td class=ubb>TLV431 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLV431A</td><td class=ubb>TLV431A 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLV431B</td><td class=ubb>TLV431B 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLVH431</td><td class=ubb>TLVH431 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLVH431A</td><td class=ubb>TLVH431A 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLVH431B</td><td class=ubb>TLVH431B 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLVH432</td><td class=ubb>TLVH432 低电压可调节精密并联稳压器</td></TR><TR><td class=ubb>TLVH432A</td><td class=ubb>TLVH432A 低电压可调节精度并联稳压器</td></TR><TR><td class=ubb>TLVH432B</td><td class=ubb>TLVH432B 低电压可调节精度并联稳压器</td></TR><TR><td class=ubb>UC3910</td><td class=ubb>UC3910 4 位 DAC 和电压监视器</td></TR><TR><td class=ubb>串联电压基准 </td></TR><TR><td class=ubb>REF2912</td><td class=ubb>REF2912 采用 SOT23-3 系统封装的 1.25V 输出 100ppm/℃ 漂移 50uA 静态电流的(带隙)电压基准系列</td></TR><TR><td class=ubb>REF3112</td><td class=ubb>REF3112 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100uA 的电压参考系列</td></TR><TR><td class=ubb>REF3012</td><td class=ubb>REF3012 采用 SOT23-3 封装的 1.25V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3212</td><td class=ubb>REF3212 采用 SOT23-6 封装的 1.25V 输出 4ppm/°C 温漂静态电流为 100uA 的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF102</td><td class=ubb>REF102 精密电压参考</td></TR><TR><td class=ubb>REF2920</td><td class=ubb>REF2920 采用 SOT23-3 封装的 2.048V 输出 100ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3120</td><td class=ubb>REF3120 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100µA 的电压参考系列</td></TR><TR><td class=ubb>REF3020</td><td class=ubb>REF3020 采用 SOT23-3 封装的 2.048V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3220</td><td class=ubb>REF3220 采用 SOT23-6 封装的 2.048V 输出 4ppm/C 漂移 100uA 系列(带隙)电压参考</td></TR><TR><td class=ubb>REF2925</td><td class=ubb>REF2925 采用 SOT23-3 封装的 2.5V 输出 100ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3125</td><td class=ubb>REF3125 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100uA 的电压参考系列</td></TR><TR><td class=ubb>REF3025</td><td class=ubb>REF3025 采用 SOT23-3 封装的 2.5V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3225</td><td class=ubb>REF3225 采用 SOT23-6 封装的 2.5V 输出 4ppm/C 漂移 100uA 系列(带隙)电压参考</td></TR><TR><td class=ubb>REF2930</td><td class=ubb>REF2930 采用 SOT23-3 封装的 3.0V 100ppm/℃,50uA 系列(带隙)电压基准</td></TR><TR><td class=ubb>REF3130</td><td class=ubb>REF3130 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100uA 的电压参考系列</td></TR><TR><td class=ubb>REF3030</td><td class=ubb>REF3030 采用 SOT23-3 封装的 3.0V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3230</td><td class=ubb>REF3230 采用 SOT23-6 封装的 3.0V 输出 4ppm/C 漂移 100uA 系列(带隙)电压参考</td></TR><TR><td class=ubb>REF2933</td><td class=ubb>REF2933 采用 SOT23-3 封装的 3.3V 输出 100ppm/C 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3133</td><td class=ubb>REF3133 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100µA 的电压参考系列</td></TR><TR><td class=ubb>REF3033</td><td class=ubb>REF3033 采用 SOT23-3 封装的 3.3V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3233</td><td class=ubb>REF3233 采用 SOT23-6 封装的 3.3V 输出 4ppm/°C 温漂静态电流为 100uA 的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF2940</td><td class=ubb>REF2940 采用 SOT23-3 封装的 4.096V 输出 100ppm/C 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3140</td><td class=ubb>REF3140 采用 SOT23-3 封装最大漂移 20ppm/℃ 静态电流 100uA 的电压参考系列</td></TR><TR><td class=ubb>REF3040</td><td class=ubb>REF3040 采用 SOT23-3 封装的 4.096V 输出 50ppm/℃ 漂移 50uA 静态电流的(带隙)电压参考系列</td></TR><TR><td class=ubb>REF3240</td><td class=ubb>REF3240 采用 SOT23-6 封装的 4.096V 输出 4ppm/C 漂移 100uA 系列(带隙)电压参考</td></TR><TR><td class=ubb>REF02</td><td class=ubb>REF02 +5V 精密电压参考</td></TR><TR><td class=ubb>电流基准 </td></TR><TR><td class=ubb>REF200</td><td class=ubb>REF200 双路电流源/电流吸入器</td></TR></table>
