-  * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
-  * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
-  * $Revision: 8 $
-  * $Date: 14/02/10 2:43p $
-  * [url=home.php?mod=space&uid=247401]@brief[/url]    FMC erase/program/read sample program for NUC029 series MCU
-  * @note
-  * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC029xAN.h"
- #define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK           50000000
- #define APROM_TEST_BASE             0x3000
- #define APROM_TEST_END              0x10000
- #define DATA_FLASH_TEST_BASE        (FMC->DFBADR)
- #define DATA_FLASH_TEST_END         (FMC->DFBADR + 0x1000)
- #define TEST_PATTERN                0x5A5A5A5A
- void SYS_Init(void)
-     /* Init System Clock        */
-     /* Enable External XTAL (4~24 MHz) */
-     CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
-     CLK->PLLCON = PLLCON_SETTING;
-     /* Waiting for clock ready */
-     CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk);
-     /* Switch HCLK clock source to PLL */
-     CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_PLL;
-     /* Enable IP clock */
-     CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk;
-     /* Select IP clock source */
-     CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_HXT;
-     /* Update System Core Clock */
-     /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
-     //SystemCoreClockUpdate();
-     PllClock        = PLL_CLOCK;            // PLL
-     SystemCoreClock = PLL_CLOCK / 1;        // HCLK
-     CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
-     /* Init I/O Multi-function        */
-     /* Set P3 multi-function pins for UART0 RXD and TXD  */
-     SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
- void UART_Init()
-     /* Init UART        */
-     UART_Open(UART0, 115200);
- static int  SetDataFlashBase(uint32_t u32DFBA)
-     uint32_t au32Config[1];
-     /* Read current User Configuration */
-     FMC_ReadConfig(au32Config, 1);
-     /* Just return when Data Flash has been enabled */
-     if(!(au32Config[0] & 0x1))
-         return 0;
-     /* Enable User Configuration Update */
-     FMC_EnableConfigUpdate();
-     /* Erase User Configuration */
-     FMC_Erase(FMC_CONFIG_BASE);
-     /* Write User Configuration to Enable Data Flash */
-     au32Config[0] &= ~0x1;
-     if(FMC_WriteConfig(au32Config, 1))
-         return -1;
-     printf("\nSet Data Flash base as 0x%x.\n", FMC_ReadDataFlashBaseAddr());
-     /* Perform chip reset to make new User Config take effect */
-     SYS->IPRSTC1 |= SYS_IPRSTC1_CHIP_RST_Msk;
-     return 0;
- int32_t FillDataPattern(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
-     uint32_t u32Addr;
-     for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
-         FMC_Write(u32Addr, u32Pattern);
-     return 0;
- int32_t  VerifyData(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
-     uint32_t    u32Addr;
-     uint32_t    u32Data;
-         u32Data = FMC_Read(u32Addr);
-         if(u32Data != u32Pattern)
-             printf("\nFMC_Read data verify failed at address 0x%x, read=0x%x, expect=0x%x\n", u32Addr, u32Data, u32Pattern);
-             return -1;
-     return 0;
- int32_t  FlashTest(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
-     uint32_t    u32Addr;
-     for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += FMC_FLASH_PAGE_SIZE)
-         printf("    Flash test address: 0x%x    \r", u32Addr);
-         // Erase page
-         FMC_Erase(u32Addr);
-         // Verify if page contents are all 0xFFFFFFFF
-         if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
-             printf("\nPage 0x%x erase verify failed!\n", u32Addr);
-             return -1;
-         // Write test pattern to fill the whole page
-         if(FillDataPattern(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
-             printf("Failed to write page 0x%x!\n", u32Addr);
-             return -1;
-         // Verify if page contents are all equal to test pattern
-         if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
-             printf("\nData verify failed!\n ");
-             return -1;
-             return -1;
-     printf("\r    Flash Test Passed.          \n");
-     return 0;
- int main()
-     uint32_t i, u32Data;
-     /* Unlock protected registers */
-     SYS_UnlockReg();
-     SYS_Init();
-     UART_Init();
-         This sample code is used to show how to use StdDriver API to implement ISP functions.
-     printf("\n\n");
-     printf("+----------------------------------------+\n");
-     printf("|          NUC029 FMC Sample Code          |\n");
-     SYS_UnlockReg();
-     /* Enable FMC ISP function */
-     FMC_Open();
-     if(SetDataFlashBase(DATA_FLASH_TEST_BASE) < 0)
-         printf("Failed to set Data Flash base address!\n");
-         goto lexit;
-     /* Read BS */
-     printf("  Boot Mode ............................. ");
-     if(FMC_GetBootSource() == 0)
-         printf("[APROM]\n");
-     else
-         printf("[LDROM]\n");
-         printf("  WARNING: The driver sample code must execute in AP mode!\n");
-         goto lexit;
-     u32Data = FMC_ReadCID();
-     printf("  Company ID ............................ [0x%08x]\n", u32Data);
-     u32Data = FMC_ReadDID();
-     printf("  Device ID ............................. [0x%08x]\n", u32Data);
-     u32Data = FMC_ReadPID();
-     printf("  Product ID ............................ [0x%08x]\n", u32Data);
-     for(i = 0; i < 3; i++)
-         u32Data = FMC_ReadUID(i);
-         printf("  Unique ID %d ........................... [0x%08x]\n", i, u32Data);
-     for(i = 0; i < 4; i++)
-         u32Data = FMC_ReadUCID(i);
-         printf("  Unique Customer ID %d .................. [0x%08x]\n", i, u32Data);
-     /* Read User Configuration */
-     printf("  User Config 0 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE));
-     printf("  User Config 1 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE + 4));
-     /* Read Data Flash base address */
-     u32Data = FMC_ReadDataFlashBaseAddr();
-     printf("  Data Flash Base Address ............... [0x%08x]\n", u32Data);
-     printf("\n\nLDROM test =>\n");
-     FMC_EnableLDUpdate();
-     if(FlashTest(FMC_LDROM_BASE, FMC_LDROM_BASE + FMC_LDROM_SIZE, TEST_PATTERN) < 0)
-         printf("\n\nLDROM test failed!\n");
-         goto lexit;
-     FMC_DisableLDUpdate();
-     printf("\n\nAPROM test =>\n");
-     FMC_EnableAPUpdate();
-     if(FlashTest(APROM_TEST_BASE, APROM_TEST_END, TEST_PATTERN) < 0)
-         printf("\n\nAPROM test failed!\n");
-         goto lexit;
-     FMC_DisableAPUpdate();
-     printf("\n\nData Flash test =>\n");
-     if(FlashTest(DATA_FLASH_TEST_BASE, DATA_FLASH_TEST_END, TEST_PATTERN) < 0)
-         printf("\n\nData Flash test failed!\n");
-         goto lexit;
- lexit:
-     /* Disable FMC ISP function */
-     FMC_Close();
-     /* Lock protected registers */
-     SYS_LockReg();
-     printf("\nFMC Sample Code Completed.\n");
-     while(1);
- /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
