[AVR单片机] 看看这段代码如何让解码M8,8照晶振
669|0
 楼主| chuandaoxy 发表于 2017-10-19 22:07 | 显示全部楼层 |阅读模式
ISR(TIMER1_CAPT_vect)
     g_TimeBuffer = ICR1;   //读取捕捉到的时间值
     if (g_count == 0)
        TCNT1 = 0;      //初始化计数器的值,以便捕捉用
        TCCR1B |= (1<<ICES1); //设置成上升沿触发
        g_count++;
        return;
    if (g_count == 1)           //高电平触发后
        TCNT1 = 0;
        TCCR1B &= ~(1<<ICES1);    //设置成下降沿触发
        Low_cnt = g_TimeBuffer; //保存低电平的时间宽度
        g_count++;
        return;
    if (g_count == 2)           //低电平触发后
        TCNT1 = 0;
        High_cnt = g_TimeBuffer;//保存高电平的时间宽度
        g_count = 1;
//========已经接收到一个完整的低电平和搞电平时间宽度,根据宽度判断码是0或1或引导码==========
        //判断是否是引导码
        if (((Low_cnt > 8000)&&(Low_cnt < 10000))&&((High_cnt > 3500)&&(High_cnt < 5500)))
            Number_cnt = 0;
            IrData = 0;
        //判断是否是"0"码
        else if (((Low_cnt > 460)&&(Low_cnt < 660))&&((High_cnt > 460)&&(High_cnt < 660)))
            IrData >>=1;
            IrData &= ~0x80000000;
            if (Number_cnt == 31)   //判断是否是最后一个码
                g_bit_rec_complete = 1;
                Number_cnt = 0;
                g_count = 0;
                Low_cnt = 0;
                High_cnt = 0;
                return;
            Number_cnt++;
        //判断是否是"1"码
        else if (((Low_cnt > 460)&&(Low_cnt < 660))&&((High_cnt > 1590)&&(High_cnt < 1790)))
            IrData >>=1;
            IrData |= 0x80000000;
          我在这里从串口输出键码Send_Char(IrData );
                Number_cnt = 0;
                g_count = 0;
                Low_cnt = 0;
                High_cnt = 0;
                return;
            Number_cnt++;
输出一堆乱码
而且不是每次都能响应,这是个红外解码程序
