[DemoCode下载]
N76E003系列通过IO触发ADC例子
1090|3
yiy|  楼主 | 2017-11-9 21:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2016
//  File Function: N76E885 ADC demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
#define Enable_ADC_AIN0                        ADCCON0&=0xF0;P17_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT0;ADCCON1|=SET_BIT0        //P17
#define Enable_ADC_AIN1                        ADCCON0&=0xF0;ADCCON0|=0x01;P30_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT1;ADCCON1|=SET_BIT0                //P30
#define Enable_ADC_AIN2                        ADCCON0&=0xF0;ADCCON0|=0x02;P07_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT2;ADCCON1|=SET_BIT0                //P07
#define Enable_ADC_AIN3                        ADCCON0&=0xF0;ADCCON0|=0x03;P06_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT3;ADCCON1|=SET_BIT0                //P06
#define Enable_ADC_AIN4                        ADCCON0&=0xF0;ADCCON0|=0x04;P05_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT4;ADCCON1|=SET_BIT0                //P05
#define Enable_ADC_AIN5                        ADCCON0&=0xF0;ADCCON0|=0x05;P04_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT5;ADCCON1|=SET_BIT0                //P04
#define Enable_ADC_AIN6                        ADCCON0&=0xF0;ADCCON0|=0x06;P03_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT6;ADCCON1|=SET_BIT0                //P03
#define Enable_ADC_AIN7                        ADCCON0&=0xF0;ADCCON0|=0x07;P11_Input_Mode;AINDIDS=0x00;AINDIDS|=SET_BIT7;ADCCON1|=SET_BIT0                //P11
#define Enable_ADC_BandGap        ADCCON0|=0x0F;ADCCON1|=SET_BIT0        //Band-gap 1.22V
#define PWM0_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
#define PWM2_FALLINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
#define PWM4_FALLINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1&=~SET_BIT2;ADCCON1|=SET_BIT1
#define PWM0_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
#define PWM2_RISINGEDGE_TRIG_ADC                ADCCON0&=~SET_BIT5;ADCCON0|=SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
#define PWM4_RISINGEDGE_TRIG_ADC                ADCCON0|=SET_BIT5;ADCCON0&=~SET_BIT4;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1
#define P04_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
#define P13_FALLINGEDGE_TRIG_ADC                ADCCON0|=0x30;ADCCON1&=0xF3;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
#define P04_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1&=~SET_BIT6
#define P13_RISINGEDGE_TRIG_ADC                        ADCCON0|=0x30;ADCCON1&=~SET_BIT3;ADCCON1|=SET_BIT2;ADCCON1|=SET_BIT1;ADCCON1|=SET_BIT6
#endif
* FUNCTION_PURPOSE: ADC interrupt Service Routine
void ADC_ISR (void) interrupt 11
    clr_ADCF;                               //clear ADC interrupt flag
                printf ("\n Value = 0x%bx",ADCRH);
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    Set_All_GPIO_Quasi_Mode;
                InitialUART0_Timer1(115200);
        ADC port trig initial setting toggle P0.4 to start ADC
                Enable_ADC_AIN0;        // Enable AIN0 P1.7 as ADC pin
                P04_FALLINGEDGE_TRIG_ADC;        // P0.4 falling edge as adc start trig signal
// find ADC result in ADC interrupt
    set_EADC;        // Enable ADC interrupt (if use interrupt)
                EA = 1;        // Enable global interrupt
//        set_ADCS;        // Trig P04 falling edge to start adc, no need set ADCS bit
                while(1);        // Wait ADC interrupt
yiy|  楼主 | 2017-11-9 21:10 | 只看该作者
发现新版的库函数BSP开发包,提供了更多的功能实现库。
大家赶紧试试吧,太给力了。
jiekou001| | 2017-11-9 22:29 | 只看该作者
这个就是按键触发嘛,按下就测一次,或者通过其他的传感器产生一个低电平触发信号。
yiy
111
