搁浅中...求帮助
2053|2
tingbaby_zj|  楼主 | 2011-5-29 16:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
调试外部中断唤醒掉电程序时,遇到一个问题;程序实现掉电唤醒时蜂鸣器鸣响切换;
#define BEEP 1<<7;
void __irq IRQ_Eint0(void)
while((EXTINT & 0X01)!=0)
  EXTINT = 0X01;
VICVectAddr =0;
int main (void)
PINSEL0 = 0X00000000;
PINSEL1 = 0X00000001;
IO0DIR  = BEEP;
IRQEnable();
VICIntSelect = 0x00000000;
    VICVectCntl0 = 0x20|14;
    VICVectAddr0 = (uint32)IRQ_Eint0;
    VICIntEnable = 1<<14;
EXTWAKE = 0x01;
EXTINT  = 0x01;
IO0SET =BEEP;
while(1)
  PCONP = 0x00;
     PCON  = 0x02;
     if((IO0SET & BEEP)==0) { IO0SET = BEEP;}
        else IO0CLR = BEEP;
    return 0;
调试时,在 if((IO0SET & BEEP)==0) { IO0SET = BEEP;}
        else IO0CLR = BEEP;
出现以下错误提示:
ERROR:(serious)C2282e:expected ‘)’-inserted before ‘;’
ERROR:(serious)C2282e:<command> expected  but found ')'
ERROR:(serious)C2282e:misplaced 'else' ignored
yan2005| | 2011-5-30 08:29 | 只看该作者
#define BEEP 1<<7;
把最后的分号";"去掉
tingbaby_zj|  楼主 | 2011-5-30 14:01 | 只看该作者
2# yan2005
谢谢已解决了呵呵
