dm6437管脚复用
470|0
 楼主| Plantt 发表于 2017-12-5 10:30 | 显示全部楼层 |阅读模式
dm6437管脚复用
1.  Tmer0
说明:仅仅是有Timer0 Block决定
配置:
2.  Timer1
说明:仅仅是由Timer1 Block决定的
配置:
3.  UART0
说明:UART0的配置是由2个Blocks决定的分别是
UART0 Data  Block,  and UART0  Flow  Control Block
配置:
4.  UART1
说明:UART1不同于UART0,仅仅支持数据pins而不支持溢出控制pins,所以由仅仅Timer1 Block决定
配置:
5.  PWM0
说明:仅仅是由UART0  Flow Control  Block决定
配置:
6.  PWM1
说明:仅仅是由PWM1 Block决定的
配置:
7.  PWM2
说明:仅仅是由CLKOUT Block决定的
配置:
8.  CLKOUT0
配置:
9.  PCI(巨复杂)
说明:PCI是由
Host Block
EMIFA/VPSS Block Sub-Block 0 and Sub-Block 3
PCI Data Block
GPIO Block                                               决定
配置:
Note:
The  EMIFA/VPSS Block  is  divided into  multiple  sub-blocks for  ultimate  flexibility in  pin  multiplexing to accommodate a wide variety of applications:
1.  Sub-Block 0: multiplexedbetween VPFE, EMIFA data/address/control pins, PCI, andGPIO.
2.  mSub-Block 1: multiplexedbetween VPBE, EMIFA data/address/control pins, andGPIO.
3. Sub-Block 2: no multiplexing. EMIFA control pinsEM_WAIT/(RDY/BSY), EM_OE,EM_WE.
4. Sub-Block 3: multiplexedbetween EMIFA address pins EM_A[12:6], PCI, and GPIO.
10.McBSP0
说明:Serial PortSub-Block0, and Timer0 Block
配置:
11.McBSP1
说明:Serial  Port Sub-Block1,  and  Timer0 Block
配置同上
