[i.MX] imx6D wdog1 重启卡死
1059|1
 楼主| 秋水一梦 发表于 2017-12-19 16:58 | 显示全部楼层 |阅读模式
mx, se, sd, TE, HC
各位,imx6D reboot(wdog1)后,停留在如下位置不动。3.0.35的内核是可以的。4.1.15内核不可以。
硬件没有使用WDOG_B。
20171219_09:12:39]U-Boot 2015.04-dirty (Dec 18 2017 - 18:27:09)
20171219_09:12:39]
20171219_09:12:39]CPU:   Freescale i.MX6D rev1.5 at 792 MHz
20171219_09:12:39]CPU:   Temperature 22 C
20171219_09:12:39]Reset cause: POR
20171219_09:12:39]Board: MX6-SabreSD
20171219_09:12:39]I2C:   ready
20171219_09:12:39]DRAM:  2 GiB
20171219_09:12:39]PMIC:  PFUZE100 ID=0x10
20171219_09:12:39]MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
20171219_09:12:39]*** Warning - bad CRC, using default environment
20171219_09:12:39]
20171219_09:12:39]No panel detected: default to Hannstar-XGA
20171219_09:12:39]Display: Hannstar-XGA (1024x768)
20171219_09:12:39]In:    serial
20171219_09:12:39]Out:   serial
20171219_09:12:39]Err:   serial
20171219_09:12:39]flash target is MMC:2
houyizi313 发表于 2018-1-2 15:35 | 显示全部楼层
dts中换个wdog;用wdog2;
