[技术问答]
M051串口1和串口0,程序中串口0能进中断,串口1不行
883|1
yexinyuan1212|  楼主 | 2017-12-22 21:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//==== M05xx ¹¤³ÌÄ£°å˵Ã÷ ===============================================================
// 22MHzÓÉPLL±¶Æµµ½ 49.7664MHz. ÁíÍ⻹ÅäÖÃÁËTimer3, UART0, ADC, PWM, GPIO
// Copyright reserved by Nuvoton (SH) Ltd.  All right reserved.
// Author : Angus Wang. Date : 2013/12/27
#include "M05xxDx.h"
#define  unFosc    12000000
#define  Baud      115200
#define  unFosc1    12000000
#define  Baud1      115200
#define  beep      P00
uint32_t TMR_Tick = 0;
uint32_t Tem_count = 0,flag_1ms = 0,buff1;
uint8_t TMR_Select_Flag = 0;
uint8_t TMR_Mode_Select_Flag = 0;
/*  ÑÓʱ ms ºÁÃë  */
void delay_ms(uint32_t ms)
        while(ms > 0) {
                flag_1ms = 0;
                while(!flag_1ms);
                ms--;
void BEEP(uint32_t ms)
        beep = 0;
        delay_ms(ms);
        beep = 1;
void UartSend(uint8_t  pBuf[],uint8_t unNumOfBytes)
        uint8_t  i;;
        for(i=0; i<unNumOfBytes; i++)
    UART0->THR = pBuf[i];
    while ((UART0->FSR & TX_FIFO_EMPTY) != 0x00);         //¼ì²é·¢Ë͵ÄFIFOÊÇ·ñΪ¿Õ
void UartSend1(uint8_t  pBuf1[],uint8_t unNumOfBytes1)
        uint8_t  i;;
        for(i=0; i<unNumOfBytes1; i++)
    UART1->THR = pBuf1[i];
    while ((UART1->FSR & TX_FIFO_EMPTY) != 0x00);         //¼ì²é·¢Ë͵ÄFIFOÊÇ·ñΪ¿Õ
void UnlockReg(void)
  while((GCR->REGWRPROT & 1) == 0){                        // ·ÀÖ¹±»´ò¶Ï½âËø²»³É¹¦
    GCR->REGWRPROT = 0x59 ;
    GCR->REGWRPROT = 0x16 ;
    GCR->REGWRPROT = 0x88 ;
void SysClk_Init(void)                    // PLL:  (22.1184M/2)*9 = 2 * 49.7664MHz
  UnlockReg() ;
  CLK->PWRCON |= CLKSTA_EXT_STABLE ;
  while((CLK->CLKSTATUS & CLKSTA_EXT_STABLE) == 0) ;       // µÈÆäÎȶ¨
  CLK->CLKSEL0 = CLKS0_HCLK_EXT_0_ ;
  LOCKREG() ;                                              // ÉÏËø
//// Timer1, 1MHz Á¬Ðø¼ÆÊý, ÓÃÓÚͨÓö¨Ê±, ÖÜÆÚ16.77Ãë ///////////////////////////////////
// дTimer ¼Ä´æÆ÷Ðè2¸öTimerʱÖÓºó²ÅÓÐЧ, TimerʱÖÓÈôºÜµÍ,дÍêºóÒªÑÓʱ,²ÅÄܶÁ
void Timer3Init(void)
  TIMER3->TCSR  = T_DEBUG_WORK | T_IE | T_MODE_CONTINUOUS  // 2¸ö 25MHz ʱÖÓºó²ÅÄÜÔÙ¶Á
                | T_CRST | T_TDR_EN + 49 ;                 // ¸´Î», 50·ÖƵ, 1us ¼ÆÊý
  TIMER3->TCMPR = 0 ;
  NVIC_SetPriority(TMR3_IRQn, 2) ;                         // ÖжÏÓÅÏȼ¶Îª 2
  NVIC->ISER[0] = 1<<TMR3_IRQn ;                                       // ´ò¿ªÖжÏÏòÁ¿
  TIMER3->TCSR |= T_CEN ;                                  // Æô¶¯Timer, Õâ¸öÊǶÁ¸ÄдָÁî
        GCR->IPRSTC2  |=  RST_T3 ;
        GCR->IPRSTC2  &=  ~ RST_T3 ;
        CLK->APBCLK   |=  CLK_TMR3_EN ;
        CLK->CLKSEL1  =  CLKS1_TMR3_EXT_0 ;
        TIMER3->TCSR |= T_MODE_PERIODIC ;
        //TIMER3->TCSR |= T_MODE_ONCE_0 ;
        TIMER3->TCSR &= 0xFFFFFF00;  ;
  TIMER3->TCMPR = 1200 ;
  TIMER3->TCSR |= T_IE ;
void Delayus(uint32_t Tim)                                 // ²ÎÊý×î´ó0xFFFFFF, Ô¼16.77Ãë
  uint32_t Tick = TIMER3->TDR ;
  while(((TIMER3->TDR - Tick)&0xFFFFFF) <= Tim) ;
void UART0_Init(void)
        CLK->APBCLK   |=  CLK_UART0_EN ;              //´®¿Ú0ʱÖÓʹÄÜ
        CLK->CLKSEL1   =  CLKS1_UART_EXT_0 ;   //´®¿ÚʱÖÓµ÷ΪÍⲿ¾§Õñ
        CLK->CLKDIV   &= ~(15<<8) ;                   //´®¿ÚʱÖÓ·ÖÆµÎª0
        GCR->IPRSTC2  |=  RST_UART0 ;          //¸´Î»´®¿Ú0
        GCR->IPRSTC2  &=  ~ RST_UART0 ;                     //¸´Î»½áÊø
        UART0->FCR |= TX_RESET ;                     //·¢ËÍFIFO¼Ä´æÆ÷¸´Î»
        UART0->FCR |= RX_RESET ;               //½ÓÊÕFIFO¼Ä´æÆ÷¸´Î»
        UART0->LCR    = WORD_LEN_8BIT ;      //УÑ鹦ÄÜÈ¡Ïû£¬8¸öÊý¾Ý룬һ¸öֹͣλ
  UART0->BAUD   |= DIV_X_EN | DIV_X_ONE ;         //ÉèÖò¨ÌØÂ浀ᅮµ
  UART0->BAUD   |= ((unFosc / Baud) -2);    //²¨ÌØÂÊÊÇ115200£¬Íⲿ¾§ÕñÊÇ12M
  UART0->IER    = 1 ;                             //½ÓÊÕÊý¾ÝÖжÏʹÄÜ
        NVIC_EnableIRQ(UART0_IRQn) ;
void UART1_Init(void)
        CLK->APBCLK   |=  CLK_UART1_EN ;              //´®¿Ú1ʱÖÓʹÄÜ
        GCR->IPRSTC2  |=  RST_UART1 ;          //¸´Î»´®¿Ú0
        GCR->IPRSTC2  &=  ~ RST_UART1 ;                     //¸´Î»½áÊø
        //UART1->FCR |= TX_RESET ;                     //·¢ËÍFIFO¼Ä´æÆ÷¸´Î»
        //UART1->FCR |= RX_RESET ;               //½ÓÊÕFIFO¼Ä´æÆ÷¸´Î»
        UART1->LCR    = WORD_LEN_8BIT ;      //УÑ鹦ÄÜÈ¡Ïû£¬8¸öÊý¾Ý룬һ¸öֹͣλ
  UART1->BAUD   |= DIV_X_EN | DIV_X_ONE ;         //ÉèÖò¨ÌØÂ浀ᅮµ
  UART1->BAUD   |= ((unFosc1 / Baud1) -2);    //²¨ÌØÂÊÊÇ115200£¬Íⲿ¾§ÕñÊÇ12M
  UART1->IER    = 1 ;                             //½ÓÊÕÊý¾ÝÖжÏʹÄÜ
        NVIC_EnableIRQ(UART1_IRQn) ;
void PWM_Init(void)
  PWMA->PPR  = PPR_PWM01_DIV(250) ;                        // PWM ʱÖÓ250·ÖƵ, µÃ200KHz
  PWMA->CSR  = CSR_DIV4_CH(0) ;                            // ͨµÀ0ÔÙ4·ÖƵ, µÃ 50KHz
  PWMA->PCR  = PCR_EN_CH(0) | PCR_PERIOD_MOD_CH(0) ;       // ʹÄÜPWM0, ÖÜÆÚģʽ
  PWMA->POE  = POE_CH(0) ;                                 // PWM Êä³öʹÄÜ
  PWMA->PIER = 0 ;                                         // ²»¿ªÖжÏ
  PWMA->CNR0 = 50000 ;                                     // ÖÜÆÚÖµ, Ô¼ 1 Ãë
  PWMA->CMR0 = 40000 ;                                     // ¸ßµçƽ  0.8 Ãë
void ADC_Init(void)
  ADC->CR = AD_EN | AD_SINGLE_MODE_0 ;                     // ADC ʹÄܵ¥´Îģʽ
//// ¼¯ÖÐÅäÖÃËùÓеÄGPIO¿Ú, Ðü¿ÕµÄGPIOÅä³É׼˫Ïò, ²¢Êä³ö1 ////////////////////////////////
void GPIO_Init(void)
  P0->DOUT    = 0xFF ;                                     // ÏÈдÊä³öÖµ
  P0->PMD     = Px7_QB | Px6_QB | Px5_QB | Px4_QB          // GPIO¹¦ÄÜÒ»Çл»¾ÍÊä³öÕýÈ·µÄÖµ
              | Px3_QB | Px2_QB | Px1_QB | Px0_OUT ;
  GCR->P0_MFP = 0 ;                                        // ÔÙÇл» GPIO ¿Ú¹¦ÄÜ
  P1->DOUT    = 0xFF ;
  P1->PMD     = Px7_QB | Px6_QB | Px5_QB | Px4_QB | Px3_QB | Px2_QB | Px1_QB | Px0_QB ;
        GCR->P1_MFP = P13_TXD1 ;                                 // UART1 ·¢ËͽÅ,
  GCR->P1_MFP = P12_RXD1 ;
  P2->DOUT    = 0xF5 ;
  P2->PMD     = Px7_QB | Px6_QB | Px5_QB | Px4_QB          // µÍËÄλ½ÓLED, Åä³ÉÊä³ö
              | Px3_OUT | Px2_OUT | Px1_OUT | Px0_OUT ;    // P20 ±»PWM½Ó¹Ü,Åä³Éʲô¶¼¿ÉÒÔ
  GCR->P2_MFP = P20_PWM0 ;                                 // P20 Åä³É PWM0 Êä³ö
                                                           // ÆäËü½ÅÅäÖÃ0, GPIO¿Ú
  P3->DOUT    = 0xFF ;
  P3->PMD     = Px7_QB | Px6_OUT | Px5_QB | Px4_QB         // Nutiny °å P36 ½ÓÁË LED
  GCR->P3_MFP = P31_TXD0 ;                                 // UART0 ·¢ËͽÅ,
  GCR->P3_MFP = P30_RXD0 ;
  P4->DOUT    = 0xFF ;
  P4->PMD     = Px7_QB | Px6_OUT | Px5_QB | Px4_QB | Px3_QB | Px2_QB | Px1_QB | Px0_QB ;
  GCR->P4_MFP = 0 ;
// ---------------------------main()----------------------------------------------
int main(void)
  uint16_t temp16 ;
  //uint32_t LED_Flash = 1 ;
  // µÚÒ»²½, ¸÷ÍâÉèʱÖÓÑ¡Ôñ,ÍâÉèʱÖÓʹÄܺó,дÍâÉè¼Ä´æÆ÷²ÅÓÐЧ ///////////////////////////
  SysClk_Init() ;
          // µÚÈý²½, GPIO¿Ú¹¦ÄÜÅäÖÃ, GPIO¿Ú¿ªÊ¼Êä³öÕýÈ·µÄÖµ /////////////////////////////////////
  GPIO_Init() ;
  // µÚ¶þ²½, ƬÄÚ¸÷ÍâÉ蹦ÄÜÅäÖà /////////////////////////////////////////////////////////
  Timer3Init() ;                                           //ÅäºÃTimer1,²ÅÄÜʹÓÃDelayus()
  PWM_Init() ;
  ADC_Init() ;
  UART0_Init() ;
  UART1_Init() ;
        // PWM0 ¿ÚÉ쵀 LED ¿ªÊ¼ÉÁ˸
        P46 = 1;
        delay_ms(500);
        //BEEP(50);
        P46 = 0;
  //UART0_Init(115200) ;
  //Tx0FillFiFo("\nUART0 is OK !   ", 16) ;                  // ´®¿ÚÅäÖúÃ, ָʾһÏ
  // Ö÷Ñ­»· /////////////////////////////////////////////////////////////////////////////
  while(1)
    //Delayus(50000) ;
   if(TMR_Select_Flag == 1)
    // P46 = ~P46 ;
                         //P46 = 1;
    if(temp16 > 3000) P23 = 0 ;
void TMR3_IRQHandler(void)
  TIMER3->TISR   = ~0 ;                                    // ÇåÖжϱêÖ¾
                if(++Tem_count >= 10)
                Tem_count = 0;
                flag_1ms = 1;
                if(++buff1 >= 10000)
                buff1 = 0;
          TMR_Select_Flag = 1;
  //TIMER3->TEXISR = ~0 ;                                    // Çå±êÖ¾Ðè2¸öTimerʱÖÓ(25M)ÖÜÆÚ
void UART0_IRQHandler(void)
        uint8_t Data, j;;
        if(UART0->ISR & RDA_INT)
                //P46 = 1;
   while(UART0->ISR & RX_DATA_IF)       //»ñÈ¡ËùÓеÄÊý¾Ý
   //P46 = 1;
                while (UART0->FSR & RX_FIFO_EMPTY);   //¼ì²éFIFOÊÇ·ñΪ¿Õ
   //P46 = 1;
                        Data = UART0->RBR;               //¶ÁÈ¡Êý¾Ý
                        UART0->THR = Data;
            UartSend(&Data,1);               //·¢ËÍÊý¾Ý
                 //if(Data == 0x11)  P46 = 1;
void UART1_IRQHandler(void)
        uint8_t ucData_1 ;
        P46 = 1;
        if(UART1->ISR & RDA_INT)              //¼ì²éÊÇ·ñ½ÓÊÕÊý¾ÝÖжÏ
   while(UART1->ISR & RX_DATA_IF)       //»ñÈ¡ËùÓеÄÊý¾Ý
                while (UART1->FSR & RX_FIFO_EMPTY);   //¼ì²éFIFOÊÇ·ñΪ¿Õ
                        ucData_1 = UART1->RBR;               //¶ÁÈ¡Êý¾Ý
                        UART1->THR = ucData_1;
            //UartSend1(&ucData_1,1);               //·¢ËÍÊý¾Ý
                  //if(ucData_1 == 0x11)  P46 = 1;
麻烦各位大哥帮小弟看看,到底是什么原因,先说声谢谢了。
734774645| | 2017-12-22 21:39 | 只看该作者
看手册里面关于串口的结构图,按顺序配置,看是不是哪儿错了。
