[MCU新闻] 新唐强大的音频M4 -- I94100
3795|10
 楼主| 09kk小熊 发表于 2018-1-27 19:42 | 显示全部楼层 |阅读模式
新产品,大家探讨下可以用在哪些产品上,深入了解可加QQ:397839840
Clock Control
– Built-in 48.0 MHz or 49.152 MHz selectable internal high speed RC oscillator (HIRC)
for system operation (Factory pre-trimmed to ±0.25% and variation < 2% at -40˚C ~
+85˚C)
– Built-in 10 kHz internal low speed RC oscillator (LIRC) for Watchdog Timer and wakeup operation
– 4~24 MHz external high speed crystal oscillator (HXT) for precise timing operation
– 32.768 kHz external low speed crystal oscillator (LXT) for RTC function and low-power
system operation
– Supports one PLL up to 500 MHz for high performance system operation, sourced
from HIRC or HXT
– Supports clock failure detection for high/low speed external crystal oscillator
– Supports exception (NMI) generation once a clock failure detected
– Supports clock output
Digital Microphone (DMIC)
– Supports up to four digital microphones.
– Provides one 32-level FIFO data buffers for receiving.
– Generates interrupt requests when buffer levels cross a programmable boundary.
– Supports PDMA transfer.
 Differential Audio PWM Output (DPWM)
– Supports left channel, right channels and sub-woofer channel.
– Supports sample rate from 16~96 kHz
– Programmable biquad filter with 10 band.
– PDMA data channel for streaming of PCM audio data.
– Supports the single precision floating point for input data and BIQ coefficient.
I94100系列
I94100系列
应用框图
应用框图
643757107 发表于 2018-1-29 13:27 | 显示全部楼层
不错,这个芯片功能真强大,性能真好
稳稳の幸福 发表于 2018-1-29 22:09 | 显示全部楼层
不错不错,还支持麦克风
xinpian101 发表于 2018-1-29 22:45 | 显示全部楼层
还没上市的吧,官方都搜不到
jerow 发表于 2018-1-30 08:46 | 显示全部楼层
一如既往的的语音方面的支持,只不过哪个49.152M是用来干嘛的,奇怪
yiy 发表于 2018-1-30 14:09 | 显示全部楼层
音频芯片貌似就新唐一直在做,还做的挺好的。
huahuagg 发表于 2018-1-30 19:10 | 显示全部楼层
PRELIMTNARY 初步,看来没有上市呢。
xinxianshi 发表于 2018-1-30 19:45 | 显示全部楼层
蓝牙音箱可以吗
 楼主| 09kk小熊 发表于 2018-1-31 12:56 | 显示全部楼层
有眼光
 楼主| 09kk小熊 发表于 2018-1-31 12:57 | 显示全部楼层
加个蓝牙模块就可以了
yiy 发表于 2018-2-10 19:42 | 显示全部楼层
一个芯片解决全套。
