STM8 uart printf问题
7220|1
 楼主| dfhf2007 发表于 2011-6-18 14:21 | 显示全部楼层 |阅读模式
各位大哥们。小弟初次使用stm8,用的是stm8s-discovery板子。
用固件库v2.0的例子中的uart-printf。编译通过。可是结果不对,是乱码。。大哥们给分析下,什么原因啊!!!!!!!
  * @file UART1_Printf\main.c
  * @brief This file contains the main function for: retarget the C library printf
  *        /scanf functions to the UART1 example.
  * @author  MCD Application Team
  * @version V2.0.0
  * @date    25-February-2011
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
#include "stdio.h"
  * @addtogroup UART1_Printf
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#ifdef _RAISONANCE_
#define PUTCHAR_PROTOTYPE int putchar (char c)
#define GETCHAR_PROTOTYPE int getchar (void)
#elif defined (_COSMIC_)
#define PUTCHAR_PROTOTYPE char putchar (char c)
#define GETCHAR_PROTOTYPE char getchar (void)
#else /* _IAR_ */
#define PUTCHAR_PROTOTYPE int putchar (int c)
#endif /* _RAISONANCE_ */
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void main(void)
  char ans;
  /*High speed internal clock prescaler: 1*/
  CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  UART2_DeInit();
  /* UART1 configuration ------------------------------------------------------*/
  /* UART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Receive and transmit enabled
        - UART1 Clock disabled
  UART2_Init((uint32_t)115200, UART2_WORDLENGTH_8D, UART2_STOPBITS_1, UART2_PARITY_NO,
              UART2_SYNCMODE_CLOCK_DISABLE, UART2_MODE_TXRX_ENABLE);
  UART2_Cmd(ENABLE);
  /* Output a message on Hyperterminal using printf function */
  printf("\n\rUART1 Example :retarget the C library printf()/getchar() functions to the UART\n\r");
  printf("\n\rEnter Text\n\r");
  while (1)
    ans = getchar();
    printf("%c", ans);
  * @brief Retargets the C library printf function to the UART.
  * @param c Character to send
  * @retval char Character sent
PUTCHAR_PROTOTYPE
  /* Write a character to the UART1 */
  UART2_SendData8(c);
  /* Loop until the end of transmission */
  while (UART2_GetFlagStatus(UART2_FLAG_TXE) == RESET);
  return (c);
  * @brief Retargets the C library scanf function to the USART.
  * @param None
  * @retval char Character to Read
GETCHAR_PROTOTYPE
#ifdef _COSMIC_
  char c = 0;
#else
  int c = 0;
#endif
  /* Loop until the Read data register flag is SET */
  while (UART2_GetFlagStatus(UART2_FLAG_RXNE) == RESET);
    c = UART2_ReceiveData8();
  return (c);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
stvoe 发表于 2015-6-14 15:32 | 显示全部楼层
谢谢!学习到了
