炫耀贴,stm32 boot搞定
2452|1
 楼主| coreduo 发表于 2011-6-24 21:46 | 显示全部楼层 |阅读模式
以后可以给客户发布加密的固件了。
DBOOT for STM32F105/7 1.00 Build 001
->build at Jun 24 2011,17:58:44
->Core Clock is 72MHZ
[ENV]: env 0 crc ok
[ENV]: env load at NO. 0
[ENV]: env 1 crc ok
[ENV]: env load at NO. 1
[ENV]: default env empty
->Waiting for boot delay: 3 seconds ..
dboot>printenv
aa=1
 楼主| coreduo 发表于 2011-6-24 21:48 | 显示全部楼层
目前支持功能
dboot>help
help        Printf help message
setenv        Modify or add enviroment variable
delenv        Delete enviroment variable
saveenv        Save enviroment variable to flash
printenv        Print enviroment variable
loadenv        Load default enviroment variable
df                Display flash
ef                Erase flash sector
dm                Display memory
ww                Write 16bits to memory
reset                Reset CPU
