[国产单片机] SN2501B读写24C02问题,兄弟们看看
4010|4
 楼主| jakey0225 发表于 2011-6-29 14:32 | 显示全部楼层 |阅读模式
#define SDA FP23
#define SCL FP24
void start(void)
// 开始位
SDA = 1;
NOP(2);
SCL = 1;
NOP(4);
SDA = 0;
NOP(4);
SCL = 0;
void stop(void)
// 停止位
SDA = 0;
NOP(2);
SCL = 1;
NOP(4);
SDA = 1;
unsigned char shin(void)
// 从AT24Cxx移入数据到MCU
unsigned char i,read_data;
SDA=1;
FP23M=0;
for(i = 0; i < 8; i++)
  SCL = 1;
  NOP(2);
  read_data <<= 1;
  read_data |= (unsigned char)SDA;
  SCL = 0;
  NOP(3);
FP23M=1;
return(read_data);
unsigned char  shout(unsigned char write_data)
// 从MCU移出数据到AT24Cxx
unsigned char i;
//bit ack_bit;
for(i = 0; i < 8; i++)  // 循环移入8个位
  if((write_data & 0x80)==1)
   SDA = 1;
  else SDA = 0;
  NOP(5);
  SCL = 1;
  NOP(4);
  write_data <<= 1;
  SCL = 0;
  NOP(2);
SDA=1;
FP23M=0;   // 读取应答
NOP(4);
SCL = 1;
NOP(4);
i = SDA;
SCL = 0;
FP23M=1;
return i;   // 返回AT24Cxx应答位
void write_byte(unsigned char addr, unsigned char write_data)
// 在指定地址addr处写入数据write_data
{ unsigned char i=0;;
start();
do
  {i=shout(0xa0);}
    while(i!=0);
do
  {i=shout(addr);}
while(i!=0);
do
  {i=shout(write_data);}
while(i!=0);
stop();
//delayms(10);  // 写入周期
for(i=0;i<250;i++)NOP(1);
unsigned char read_current(void)
// 在当前地址读取
unsigned char read_data;
start();
shout(0xa1);
read_data = shin();
stop();
return read_data;
unsigned char read_random(unsigned char random_addr)
// 在指定地址读取
{ unsigned char read_data,i;
start();
do i=shout(0xa1);
while(i!=0);
do i=shout(random_addr);
while(i!=0);
start();
do i=shout(0xa1);
while(i!=0);
read_data = shin();
stop();*/
return (read_current());
每次读时无法通过循环,在发送字节地址处接收到的反馈是1不是0
老鱼探戈 发表于 2011-6-30 08:56 | 显示全部楼层
上来就一堆代码,谁有时间和心思帮你看!
还你一段代码,母体是SN2613,EEP是24c04。
whilebreak 发表于 2011-7-24 09:31 | 显示全部楼层
路过~ 支持!
kfzy6 发表于 2011-8-23 15:15 | 显示全部楼层
lfb112 发表于 2011-8-24 23:22 | 显示全部楼层
没仔细看,会不会是延时短了一点
个人签名:呵呵
25
