STM32 USB 转串口 改进版本,实现文件发送
6382|13
 楼主| TRUE_ARM 发表于 2011-7-5 13:39 | 显示全部楼层 |阅读模式
专业信号处理学习板例程介绍.pdf (984.06 KB, 下载次数: 334)
更改思路,使用队列来处理。
更改1
void USB_To_USART_Send_Data(u8* data_buffer, u8 Nb_bytes)
//polling ?
/* 原来官方的例程:这里使用查询的方式把USB 接收到的数据发送出去
u32 i;
for (i = 0; i < Nb_bytes; i++)
USART_SendData(USART1, *(data_buffer + i));
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
//原来官方的例程,使用查询方式,效率低,
//int: 改进的处理:使用队列加缓冲加中断来处理USB 接收到的数据
Uart1SendPushBuf(data_buffer,
Nb_bytes);
更改2
void USART_To_USB_Send_Data(void)
//CALLED by int?
{//write data to END-point
//called by uart_rxe_int:
u16 i,j;
if (linecoding.datatype == 7)
//buffer_in[count_in] = USART_ReceiveData(USART1) & 0x7F;
usb_buf[usbIdIn] = USART_ReceiveData(USART1) & 0x7F;
else if (linecoding.datatype == 8)
//buffer_in[count_in] = USART_ReceiveData(USART1);
usb_buf[usbIdIn] =
if(++usbIdIn>=2048)usbIdIn=0;
usb_len ++;
count_in++;
UserToPMABufferCopy(buffer_in, ENDP1_TXADDR, count_in);
SetEPTxCount(ENDP1, count_in);
SetEPTxValid(ENDP1);
//if usb -in_enp free now? start send?
if(
count_in == 0 )
{//free now? start send...
//j=(usb_len >= VIRTUAL_COM_PORT_DATA_SIZE)?VIRTUAL_COM_PORT_DATA_SIZE:usb_len;
if(usb_len > VIRTUAL_COM_PORT_DATA_SIZE)
j=VIRTUAL_COM_PORT_DATA_SIZE;
usb_len -=j;
else
j=usb_len;
usb_len =0;
for(i=0;i<j;i++)
buffer_in = usb_buf[usbIdOut];
if(++usbIdOut>=2048)usbIdOut=0;
count_in = j;
//else just save to buffer,waiting usb-nak
yioy 发表于 2011-7-5 20:50 | 显示全部楼层
先下载看看
不发表评论暂
 楼主| TRUE_ARM 发表于 2011-7-5 22:00 | 显示全部楼层
注意:
主循环部分:
while (1)
    if ((count_out != 0) && (bDeviceState == CONFIGURED))
      if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_8))
      { //PB.8
        GPIO_ResetBits(GPIOB, GPIO_Pin_9);
        GPIO_ResetBits(GPIOB, GPIO_Pin_8);
        GPIO_ResetBits(GPIOB, GPIO_Pin_7);
      else{
        GPIO_SetBits(GPIOB, GPIO_Pin_9);
        GPIO_SetBits(GPIOB, GPIO_Pin_8);
        GPIO_SetBits(GPIOB, GPIO_Pin_7);
      //接收USB 的数据,分析
      USB_To_USART_Send_Data(&buffer_out[0], count_out);
      count_out = 0;
      //Add send to PC using USB:write ENP:
//端点中断:
void EP3_OUT_Callback(void)
  count_out = GetEPRxCount(ENDP3);
  PMAToUserBufferCopy(buffer_out, ENDP3_RXADDR, count_out);
  SetEPRxValid(ENDP3);
在用串口调试助手debug时发现官方例程的接收完全没问题,发送部分有很大问题,当发送的数据很大时就会出现很严重的丢包.
后来我将EP3_OUT_Callback函数改成下面的,将main函数里的USB_To_USART_Send_Data注释掉就OK了,分析了一下,觉得问题可能
是当发送大量数据时main函数的USB_To_USART_Send_Data还没处理完,后面的数据就过来了,将buffer_out里面的数据覆盖掉了.
当我将USB_To_USART_Send_Data移到EP3_OUT_Callback后,只有当前数据处理完才会允许下一次传输.修改后的例程我试过通过
com口给别的板子升级firmware完全没问题.
//这里把数据处理完毕,再允许端口3
  count_out = 0;
 楼主| TRUE_ARM 发表于 2011-7-14 09:02 | 显示全部楼层
Virtual_COM_Port_Profession.rar (1.87 MB, 下载次数: 1453)
完整工程上传。
xsgy123 发表于 2011-7-14 10:02 | 显示全部楼层
先分析一下,楼主还是很有想法的
wowewo 发表于 2011-7-14 14:10 | 显示全部楼层
下载看看
火箭球迷 发表于 2011-7-14 15:11 | 显示全部楼层
楼主的确是很有想法,鼓励多思考
 楼主| TRUE_ARM 发表于 2011-7-28 22:09 | 显示全部楼层
好像建议不多啊?
zzwj5120 发表于 2011-8-21 16:28 | 显示全部楼层
这个版本,连发数据不行的,找个200K的文件自发自收测试下就知道了。
wucs1 发表于 2012-9-10 10:27 | 显示全部楼层
试试看。
pjdu 发表于 2012-9-13 10:26 | 显示全部楼层
试试看。。。
试试看。。。
pjdu 发表于 2012-9-13 10:27 | 显示全部楼层
试试看。。。
